2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~khkim/epics-base/fix-timestamp into lp:epics-base
To: [email protected]
Date: Thu, 27 May 2010 13:59:25 -0000
I see what it does.
But if you monitor the channel, you always get the matching timestamps with the data updates.
Sorry, I still don't seem to understand your intentions.
https://code.launchpad.net/~khkim/epics-base/fix-timestamp/+merge/26023
Your team EPICS Core Developers is requested to review the proposed merge of lp:~khkim/epics-base/fix-timestamp into lp:epics-base.
[Merge] lp:~khkim/epics-base/fix-timestamp into lp:epics-base Kim, Kukhee
Prev: RE: [Merge] lp:~ronaldo-mercado/epics-base/capr into lp:epics-base Ronaldo Mercado
Next: [Merge] lp:~dirk.zimoch/epics-base/non-val-attributes into lp:epics-base Dirk Zimoch
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] lp:~khkim/epics-base/fix-timestamp into lp:epics-base Kim, Kukhee
Next: [Merge] lp:~ronaldo-mercado/epics-base/capr into lp:epics-base Ronaldo Mercado
