2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~khkim/epics-base/fix-timestamp into lp:epics-base
To: [email protected]
Date: Thu, 27 May 2010 09:28:23 -0000
1. caput <PV name>.TSMD "Default"
timestamp updated every record processing.
2. caput <PV name>.TSMD "Mon Deadband"
timestamp updated when the value change exceed the monitoring deadband.
3. caput <PV name>.TSMD "Arch Deadband"
timestamp updated when the value change exceed the archiving deadband.
If you are interested to know when value changed,
you can utilize the case 2 and 3.
https://code.launchpad.net/~khkim/epics-base/fix-timestamp/+merge/26023
Your team EPICS Core Developers is requested to review the proposed merge of lp:~khkim/epics-base/fix-timestamp into lp:epics-base.
[Merge] lp:~khkim/epics-base/fix-timestamp into lp:epics-base Kim, Kukhee
Prev: Re: [Merge] lp:~ronaldo-mercado/epics-base/capr into lp:epics-base Andrew Johnson
Next: Re: [Merge] lp:~ronaldo-mercado/epics-base/capr into lp:epics-base Ronaldo Mercado
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] lp:~khkim/epics-base/fix-timestamp into lp:epics-base Ralph Lange
Next: Re: [Merge] lp:~khkim/epics-base/fix-timestamp into lp:epics-base Ralph Lange
