2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: [Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base
To: [email protected]
Date: Thu, 27 May 2010 15:33:38 -0000
Dirk Zimoch has proposed merging lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base.
Requested reviews:
  EPICS Core Developers (epics-core)
* Bugfix: writing to aai/aao via db link crashed ioc. Memory allocation / device support init_record  moved to pass 0.
* Soft device support for aai and aao added.
* Simulation mode fixed. SIOL link added. (sim handling is done in devsup!)
* Bugfix: writing to aai/aao modified NELM. Modify NORD instead.
* Hashing added to minimize monitor updates (like in waveform record)
Discussion:
Add features like RVAL->VAL conversion, scaling, smoothing, alarm limits?
https://code.launchpad.net/~dirk.zimoch/epics-base/fix-aai-and-aao/+merge/26195
Your team EPICS Core Developers is requested to review the proposed merge of lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base.
=== modified file 'src/dev/softDev/Makefile'
--- src/dev/softDev/Makefile	2008-09-24 22:40:37 +0000
+++ src/dev/softDev/Makefile	2010-05-27 15:33:37 +0000
@@ -12,6 +12,8 @@
 DBD += devSoft.dbd
+LIBSRCS += devAaiSoft.c
+LIBSRCS += devAaoSoft.c
 LIBSRCS += devAiSoft.c
 LIBSRCS += devAiSoftRaw.c
 LIBSRCS += devAoSoft.c
=== added file 'src/dev/softDev/devAaiSoft.c'
--- src/dev/softDev/devAaiSoft.c	1970-01-01 00:00:00 +0000
+++ src/dev/softDev/devAaiSoft.c	2010-05-27 15:33:37 +0000
@@ -0,0 +1,87 @@
+* Copyright (c) 2008 UChicago Argonne LLC, as Operator of Argonne
+*     National Laboratory.
+* Copyright (c) 2002 The Regents of the University of California, as
+*     Operator of Los Alamos National Laboratory.
+* EPICS BASE is distributed subject to a Software License Agreement found
+* in file LICENSE that is included with this distribution.
+/* $Id$
+ * devAaiSoft.c - Device Support Routines for soft Waveform Records
+ *      Original Author: Bob Dalesio
+ *      Current Author:  Dirk Zimoch
+ *      Date:            27-MAY-2010
+#include <stdlib.h>
+#include <stdio.h>
+#include <string.h>
+#include "alarm.h"
+#include "dbDefs.h"
+#include "dbAccess.h"
+#include "recGbl.h"
+#include "devSup.h"
+#include "cantProceed.h"
+#include "menuYesNo.h"
+#include "aaiRecord.h"
+#include "epicsExport.h"
+/* Create the dset for devAaiSoft */
+static long init_record();
+static long read_aai();
+struct {
+    long      number;
+    DEVSUPFUN report;
+    DEVSUPFUN init;
+    DEVSUPFUN init_record;
+    DEVSUPFUN get_ioint_info;
+    DEVSUPFUN read_aai;
+} devAaiSoft = {
+    5,
+    NULL,
+    NULL,
+    init_record,
+    NULL,
+    read_aai
+epicsExportAddress(dset,devAaiSoft);
+static long init_record(aaiRecord *prec)
+    /* INP must be a CONSTANT or a PV_LINK or a DB_LINK or a CA_LINK*/
+    switch (prec->inp.type) {
+    case CONSTANT:
+        prec->nord = 0;
+        break;
+    case PV_LINK:
+    case DB_LINK:
+    case CA_LINK:
+	break;
+    default :
+	recGblRecordError(S_db_badField, (void *)prec,
+	    "devAaiSoft (init_record) Illegal INP field");
+	return(S_db_badField);
+    return 0;
+static long read_aai(aaiRecord *prec)
+    long nRequest = prec->nelm;
+    dbGetLink(prec->simm == menuYesNoYES ? &prec->siol : &prec->inp,
+        prec->ftvl, prec->bptr, 0, &nRequest);
+    if (nRequest > 0) {
+        prec->nord = nRequest;
+        prec->udf=FALSE;
+        if (prec->tsel.type == CONSTANT &&
+            prec->tse == epicsTimeEventDeviceTime)
+            dbGetTimeStamp(&prec->inp, &prec->time);
+    return 0;
=== added file 'src/dev/softDev/devAaoSoft.c'
--- src/dev/softDev/devAaoSoft.c	1970-01-01 00:00:00 +0000
+++ src/dev/softDev/devAaoSoft.c	2010-05-27 15:33:37 +0000
@@ -0,0 +1,79 @@
+/* $Id$
+ * devAaoSoft.c - Device Support Routines for soft Waveform Records
+#include <stdio.h>
+#include "alarm.h"
+#include "aaoRecord.h"
+/* Create the dset for devAaoSoft */
+static long write_aao();
+struct {
+    long      number;
+    DEVSUPFUN report;
+    DEVSUPFUN init;
+    DEVSUPFUN read_aao;
+} devAaoSoft = {
+    5,
+    NULL,
+    NULL,
+    init_record,
+    NULL,
+    write_aao
+epicsExportAddress(dset,devAaoSoft);
+static long init_record(aaoRecord *prec)
+    /* OUT must be a CONSTANT or a PV_LINK or a DB_LINK or a CA_LINK*/
+    switch (prec->out.type) {
+    case CONSTANT:
+        prec->nord = 0;
+        break;
+    case PV_LINK:
+    case DB_LINK:
+    case CA_LINK:
+	break;
+    default :
+	recGblRecordError(S_db_badField, prec,
+		"devAaoSoft (init_record) Illegal OUT field");
+    return 0;
+static long write_aao(aaoRecord *prec)
+    long nRequest = prec->nord;
+    dbPutLink(prec->simm == menuYesNoYES ? &prec->siol : &prec->out,
+        prec->ftvl, prec->bptr, nRequest);
+    return 0;
=== modified file 'src/dev/softDev/devSoft.dbd'
--- src/dev/softDev/devSoft.dbd	2008-09-24 22:40:37 +0000
+++ src/dev/softDev/devSoft.dbd	2010-05-27 15:33:37 +0000
@@ -1,3 +1,5 @@
+device(aai,CONSTANT,devAaiSoft,"Soft Channel")
+device(aao,CONSTANT,devAaoSoft,"Soft Channel")
 device(ai,CONSTANT,devAiSoft,"Soft Channel")
 device(ao,CONSTANT,devAoSoft,"Soft Channel")
 device(bi,CONSTANT,devBiSoft,"Soft Channel")
=== modified file 'src/misc/base.dbd'
--- src/misc/base.dbd	2008-08-14 20:41:05 +0000
+++ src/misc/base.dbd	2010-05-27 15:33:37 +0000
@@ -8,6 +8,8 @@
 include "menuConvert.dbd"
 # Record types
+include "aaiRecord.dbd"
+include "aaoRecord.dbd"
 include "aiRecord.dbd"
 include "aoRecord.dbd"
 include "aSubRecord.dbd"
=== modified file 'src/rec/aaiRecord.c'
--- src/rec/aaiRecord.c	2009-07-08 18:14:11 +0000
+++ src/rec/aaiRecord.c	2010-05-27 15:33:37 +0000
@@ -9,7 +9,6 @@
 /* recAai.c - Record Support Routines for Array Analog In records */
  *      Original Author: Dave Barker
- *      Date:            10/24/93
  *      C  E  B  A  F
@@ -18,6 +17,8 @@
  *      Copyright SURA CEBAF 1993.
+ *      Current Author: Dirk Zimoch <[email protected]>
 #include <stddef.h>
@@ -28,14 +29,17 @@
 #include "dbDefs.h"
 #include "epicsPrint.h"
+#include "epicsString.h"
 #include "alarm.h"
+#include "dbEvent.h"
+#include "dbFldTypes.h"
 #include "dbScan.h"
-#include "dbEvent.h"
 #include "devSup.h"
 #include "errMdef.h"
 #include "recSup.h"
 #include "recGbl.h"
 #define GEN_SIZE_OFFSET
@@ -48,7 +52,7 @@
 static long init_record(aaiRecord *, int);
 static long process(aaiRecord *);
 #define special NULL
-static long get_value(aaiRecord *, struct valueDes *);
+#define get_value NULL
 static long cvt_dbaddr(DBADDR *);
 static long get_array_info(DBADDR *, long *, long *);
 static long put_array_info(DBADDR *, long);
@@ -84,43 +88,67 @@
 epicsExportAddress(rset,aaiRSET);
 struct aaidset { /* aai dset */
-    long            number;
-    DEVSUPFUN       dev_report;
-    DEVSUPFUN       init;
-    DEVSUPFUN       init_record; /*returns: (-1,0)=>(failure,success)*/
-    DEVSUPFUN       get_ioint_info;
-    DEVSUPFUN       read_aai; /*returns: (-1,0)=>(failure,success)*/
+    long      number;
+    DEVSUPFUN dev_report;
+    DEVSUPFUN init;
+    DEVSUPFUN init_record; /*returns: (-1,0)=>(failure,success)*/
+    DEVSUPFUN read_aai; /*returns: (-1,0)=>(failure,success)*/
 static void monitor(aaiRecord *);
 static long readValue(aaiRecord *);
 static long init_record(aaiRecord *prec, int pass)
-    struct aaidset *pdset;
     long status;
+    struct aaidset *pdset = (struct aaidset *)(prec->dset);
+    /* must have dset defined */
+    if (!pdset) {
+        recGblRecordError(S_dev_noDSET, prec, "aai: init_record");
+        return S_dev_noDSET;
     if (pass == 0) {
-        if (prec->nelm <= 0) prec->nelm = 1;
+        if (prec->nelm <= 0)
+            prec->nelm = 1;
+        if (prec->ftvl > DBF_ENUM)
+            prec->ftvl = DBF_UCHAR;
+        if (prec->nelm == 1) {
+            prec->nord = 1;
+        } else {
+            prec->nord = 0;
+        /* we must call pdset->init_record in pass 0
+           because it may set prec->bptr which must
+           not change after links are established before pass 1
+        if (pdset->init_record) {
+            /* init_record may set the bptr to point to the data */
+            if ((status = pdset->init_record(prec)))
+                return status;
+        if (!prec->bptr) {
+            /* device support did not allocate memory so we must do it */
+            prec->bptr = callocMustSucceed(prec->nelm, dbValueSize(prec->ftvl),
+                "aai: buffer calloc failed");
         return 0;
-    recGblInitConstantLink(&prec->siml, DBF_USHORT, &prec->simm);
-    /* must have dset defined */
-    if (!(pdset = (struct aaidset *)(prec->dset))) {
-        recGblRecordError(S_dev_noDSET, (void *)prec, "aai: init_record");
-        return S_dev_noDSET;
+    /* SIML must be a CONSTANT or a PV_LINK or a DB_LINK */
+    if (prec->siml.type == CONSTANT) {
+	recGblInitConstantLink(&prec->siml,DBF_USHORT,&prec->simm);
     /* must have read_aai function defined */
     if (pdset->number < 5 || pdset->read_aai == NULL) {
-        recGblRecordError(S_dev_missingSup, (void *)prec, "aai: init_record");
+        recGblRecordError(S_dev_missingSup, prec, "aai: init_record");
         return S_dev_missingSup;
-    if (pdset->init_record) {
-        /* init_record sets the bptr to point to the data */
-        if ((status = pdset->init_record(prec)))
-            return status;
     return 0;
@@ -132,14 +160,13 @@
     if (pdset == NULL || pdset->read_aai == NULL) {
         prec->pact = TRUE;
-        recGblRecordError(S_dev_missingSup, (void *)prec, "read_aai");
+        recGblRecordError(S_dev_missingSup, prec, "read_aai");
     if (pact) return 0;
     status = readValue(prec); /* read the new value */
-    /* check if device support set pact */
     if (!pact && prec->pact) return 0;
     prec->pact = TRUE;
@@ -151,22 +178,14 @@
     recGblFwdLink(prec);
     prec->pact = FALSE;
-    return 0;
-static long get_value(aaiRecord *prec, struct valueDes *pvdes)
-    pvdes->no_elements = prec->nelm;
-    pvdes->pvalue      = prec->bptr;
-    pvdes->field_type  = prec->ftvl;
-    return 0;
+    return status;
 static long cvt_dbaddr(DBADDR *paddr)
     aaiRecord *prec = (aaiRecord *)paddr->precord;
-    paddr->pfield         = (void *)(prec->bptr);
+    paddr->pfield         = prec->bptr;
     paddr->no_elements    = prec->nelm;
     paddr->field_type     = prec->ftvl;
     paddr->field_size     = dbValueSize(prec->ftvl);
@@ -178,7 +197,7 @@
-    *no_elements =  prec->nelm;
+    *no_elements =  prec->nord;
     *offset = 0;
     return 0;
@@ -187,7 +206,9 @@
-    prec->nelm = nNew;
+    prec->nord = nNew;
+    if (prec->nord > prec->nelm)
+        prec->nord = prec->nelm;
     return 0;
@@ -204,7 +225,7 @@
     *precision = prec->prec;
-    if (paddr->pfield == (void *)prec->bptr) return 0;
+    if (paddr->pfield == prec->bptr) return 0;
     recGblGetPrec(paddr, precision);
     return 0;
@@ -213,7 +234,7 @@
-    if (paddr->pfield == (void *)prec->bptr) {
+    if (paddr->pfield == prec->bptr) {
         pgd->upper_disp_limit = prec->hopr;
         pgd->lower_disp_limit = prec->lopr;
     } else recGblGetGraphicDouble(paddr, pgd);
@@ -224,7 +245,7 @@
         pcd->upper_ctrl_limit = prec->hopr;
         pcd->lower_ctrl_limit = prec->lopr;
     } else recGblGetControlDouble(paddr, pcd);
@@ -234,9 +255,35 @@
 static void monitor(aaiRecord *prec)
     unsigned short monitor_mask;
+    unsigned int hash = 0;
     monitor_mask = recGblResetAlarms(prec);
-    monitor_mask |= (DBE_LOG | DBE_VALUE);
+    if (prec->mpst == aaiPOST_Always)
+        monitor_mask |= DBE_VALUE;
+    if (prec->apst == aaiPOST_Always)
+        monitor_mask |= DBE_LOG;
+    /* Calculate hash if we are interested in OnChange events. */
+    if ((prec->mpst == aaiPOST_OnChange) ||
+        (prec->apst == aaiPOST_OnChange)) {
+        hash = epicsMemHash(prec->bptr,
+            prec->nord * dbValueSize(prec->ftvl), 0);
+        /* Only post OnChange values if the hash is different. */
+        if (hash != prec->hash) {
+            if (prec->mpst == aaiPOST_OnChange)
+            if (prec->apst == aaiPOST_OnChange)
+            /* Store hash for next process. */
+            prec->hash = hash;
+            /* Post HASH. */
+            db_post_events(prec, &prec->hash, DBE_VALUE);
     if (monitor_mask)
         db_post_events(prec, prec->bptr, monitor_mask);
@@ -253,21 +300,25 @@
     status = dbGetLink(&prec->siml, DBR_ENUM, &prec->simm, 0, 0);
     if (status)
-        return(status);
+        return status;
     if (prec->simm == menuYesNoNO){
-        /* Call dev support */
-        status = pdset->read_aai(prec);
-        return status;
+        return pdset->read_aai(prec);
     if (prec->simm == menuYesNoYES){
-        /* Simm processing split performed in devSup */
-        return status;
+        /* Device suport is responsible for buffer
+           which might be read-only so we may not be
+           allowed to call dbGetLink on it.
+           Maybe also device support has an advanced
+           simulation mode.
+           Thus call device now.
+        recGblSetSevr(prec, SIMM_ALARM, prec->sims);
-    status = -1;
-    recGblSetSevr(prec, SIMM_ALARM, INVALID_ALARM);
-    return status;
+    recGblSetSevr(prec, SOFT_ALARM, INVALID_ALARM);
+    return -1;
=== modified file 'src/rec/aaiRecord.dbd'
--- src/rec/aaiRecord.dbd	2002-07-12 21:35:43 +0000
+++ src/rec/aaiRecord.dbd	2010-05-27 15:33:37 +0000
@@ -7,6 +7,10 @@
 # and higher are distributed subject to a Software License Agreement found
 # in file LICENSE that is included with this distribution.
+menu(aaiPOST) {
+        choice(aaiPOST_Always,"Always")
+        choice(aaiPOST_OnChange,"On Change")
 recordtype(aai) {
 	include "dbCommon.dbd"
 	field(VAL,DBF_NOACCESS) {
@@ -82,4 +86,25 @@
 		interest(2)
 		menu(menuAlarmSevr)
+	field(SIOL,DBF_INLINK) {
+		prompt("Sim Input Specifctn")
+		promptgroup(GUI_INPUTS)
+		interest(1)
+	field(MPST,DBF_MENU) {
+                prompt("Post Value Monitors")
+                promptgroup(GUI_DISPLAY)
+                interest(1)
+                menu(aaiPOST)
+	field(APST,DBF_MENU) {
+                prompt("Post Archive Monitors")
+                interest(1)
+                menu(aaiPOST)
+	field(HASH,DBF_ULONG) {
+		prompt("Hash of OnChange data.")
+		interest(3)
=== modified file 'src/rec/aaoRecord.c'
--- src/rec/aaoRecord.c	2009-07-08 18:14:11 +0000
+++ src/rec/aaoRecord.c	2010-05-27 15:33:37 +0000
@@ -9,7 +9,6 @@
 /* recAao.c - Record Support Routines for Array Analog Out records */
- *      Date:            10/28/93
  *      C  E  B  A  F
@@ -18,6 +17,8 @@
 #include <stddef.h>
@@ -28,14 +29,17 @@
 #include "dbDefs.h"
 #include "alarm.h"
 #include "dbScan.h"
 #include "devSup.h"
+#include "errMdef.h"
 #include "recSup.h"
 #include "recGbl.h"
@@ -48,7 +52,7 @@
 static long init_record(aaoRecord *, int);
 static long process(aaoRecord *);
-static long get_value(aaoRecord *, struct valueDes *);
@@ -84,43 +88,67 @@
 epicsExportAddress(rset,aaoRSET);
 struct aaodset { /* aao dset */
-    long            number;
-    DEVSUPFUN       init;
-    DEVSUPFUN       write_aao; /*returns: (-1,0)=>(failure,success)*/
+    long      number;
+    DEVSUPFUN init;
+    DEVSUPFUN write_aao; /*returns: (-1,0)=>(failure,success)*/
 static void monitor(aaoRecord *);
 static long writeValue(aaoRecord *);
 static long init_record(aaoRecord *prec, int pass)
-    struct aaodset *pdset;
     long status;
+    struct aaodset *pdset = (struct aaodset *)(prec->dset);
-    if (pass == 0) {
-        return 0;
-    if (!(pdset = (struct aaodset *)(prec->dset))) {
-        recGblRecordError(S_dev_noDSET, (void *)prec, "aao: init_record");
+    if (!pdset) {
+        recGblRecordError(S_dev_noDSET, prec, "aao: init_record");
+    if (pass == 0) {
+            prec->nelm = 1;
+            prec->nord = 1;
+        } else {
+            prec->nord = 0;
+                return status;
+                "aao: buffer calloc failed");
+        return 0;
     /* must have write_aao function defined */
     if (pdset->number < 5 || pdset->write_aao == NULL) {
-        recGblRecordError(S_dev_missingSup, (void *)prec, "aao: init_record");
+        recGblRecordError(S_dev_missingSup, prec, "aao: init_record");
-        /* init records sets the bptr to point to the data */
-            return status;
     return 0;
@@ -132,13 +160,15 @@
     if (pdset == NULL || pdset->write_aao == NULL) {
         prec->pact = TRUE;
-        recGblRecordError(S_dev_missingSup, (void *)prec, "write_aao");
+        recGblRecordError(S_dev_missingSup, prec, "write_aao");
     if (pact) return 0;
     status = writeValue(prec); /* write the data */
+    if (!pact && prec->pact) return 0;
+    prec->pact = TRUE;
     prec->udf = FALSE;
     recGblGetTimeStamp(prec);
@@ -148,22 +178,14 @@
     prec->pact = FALSE;
-    return 0;
-static long get_value(aaoRecord *prec, struct valueDes *pvdes)
-    return 0;
+    return status;
     aaoRecord *prec = (aaoRecord *)paddr->precord;
@@ -175,7 +197,7 @@
     *offset = 0;
     return 0;
@@ -184,7 +206,9 @@
     return 0;
@@ -210,7 +234,7 @@
     } else recGblGetGraphicDouble(paddr,pgd);
@@ -221,7 +245,7 @@
-    if(paddr->pfield==(void *)prec->bptr){
+    if(paddr->pfield == prec->bptr){
     } else recGblGetControlDouble(paddr,pcd);
@@ -231,9 +255,35 @@
 static void monitor(aaoRecord *prec)
+    if (prec->mpst == aaoPOST_Always)
+    if (prec->apst == aaoPOST_Always)
+    if ((prec->mpst == aaoPOST_OnChange) ||
+        (prec->apst == aaoPOST_OnChange)) {
+            if (prec->mpst == aaoPOST_OnChange)
+            if (prec->apst == aaoPOST_OnChange)
+            /* Post HASH. */
     if (monitor_mask)
@@ -253,17 +303,20 @@
         return status;
     if (prec->simm == menuYesNoNO) {
-        status = pdset->write_aao(prec);
-        return status;
+        return pdset->write_aao(prec);
     if (prec->simm == menuYesNoYES) {
-        return status;
+           which might be write-only so we may not be
+           allowed to call dbPutLink on it.
+           simulation mode.
+        recGblSetSevr(prec, SIMM_ALARM, INVALID_ALARM);
-    status = -1;
-    return status;
+    return -1;
=== modified file 'src/rec/aaoRecord.dbd'
--- src/rec/aaoRecord.dbd	2002-07-12 21:35:43 +0000
+++ src/rec/aaoRecord.dbd	2010-05-27 15:33:37 +0000
@@ -7,6 +7,10 @@
+menu(aaoPOST) {
+        choice(aaoPOST_Always,"Always")
+        choice(aaoPOST_OnChange,"On Change")
 recordtype(aao) {
@@ -82,4 +86,25 @@
 		interest(2)
 		menu(menuAlarmSevr)
+	field(SIOL,DBF_OUTLINK) {
+		prompt("Sim Output Specifctn")
+		interest(1)
+                interest(1)
+                menu(aaoPOST)
+                interest(1)
+                menu(aaoPOST)
+		interest(3)
Re: [Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base Andrew Johnson
Re: [Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base Dirk Zimoch
Prev: [Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base Dirk Zimoch
Next: [Merge] lp:~khkim/epics-base/alarm-filter into lp:epics-base Kim, Kukhee
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base Ralph Lange
Next: Re: [Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base Andrew Johnson
