2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base
To: [email protected]
Date: Fri, 02 Jul 2010 19:37:24 -0000
Hi Ben,
Interesting point, although not relevant to the review of this particular branch.  Making that change to the records would require a corresponding modification to all device supports, so it's not something I'd want to do for 3.14.12.  I guess removing the BPTR fields completely would cause any unmodified code to fail at compile-time (which is what we'd want), so it's not an impossible idea for 3.15.
- Andrew
https://code.launchpad.net/~dirk.zimoch/epics-base/fix-aai-and-aao/+merge/26195
Your team EPICS Core Developers is requested to review the proposed merge of lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base.
[Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base Dirk Zimoch
Prev: Re: [Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base Ben F.
Next: Re: [Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base Dirk Zimoch
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
