2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base
Date: Fri, 02 Jul 2010 19:00:46 -0000
On Freitag, 2. Juli 2010, Andrew Johnson wrote:
> Do you know under what circumstances a device support might want to set
> BPTR itself?
Slightly off-topic, but I suggest removing BPTR and use VAL field instead.
VAL is not used for anything at the moment, AFAIR, and is also
DBF_NOACCESS, so this is even compatible (but not for device support, maybe
this is the reason this hasn't been done before?).
Same for waveform record, BTW.
Cheers
Ben
https://code.launchpad.net/~dirk.zimoch/epics-base/fix-aai-and-aao/+merge/26195
Your team EPICS Core Developers is requested to review the proposed merge of lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base.
Re: [Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base Andrew Johnson
Prev: Re: [Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base Andrew Johnson
Next: Re: [Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
