2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base
To: [email protected]
Date: Fri, 02 Jul 2010 17:59:29 -0000
Hi Dirk,
When SIMM=YES, the aai record is put into alarm using the SIMS field for the severity.  The aao record always goes to INVALID_ALARM in simulation mode.
Do you know under what circumstances a device support might want to set BPTR itself?  The comment about calling the pdset->init_record() in pass 0 implies that run-time changes of the device address wouldn't be possible in that case (which is in the device support's power to allow if it uses devExtend(), but prevented if it doesn't).
Have you ever seen any written documentation for the aai/aao record types?  There are no chapters for them in the Record Reference wiki yet.
I haven't started actually testing this code yet (that's my next task), but so far I think this work should be merged into R3.14.12.
- Andrew
https://code.launchpad.net/~dirk.zimoch/epics-base/fix-aai-and-aao/+merge/26195
Your team EPICS Core Developers is requested to review the proposed merge of lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base.
Re: [Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base Ben F.
[Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base Dirk Zimoch
Prev: Re: Merges: 3.14.12 vs 3.15 Andrew Johnson
Next: Re: [Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base Ben F.
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: [Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base Dirk Zimoch
