Andrew Johnson has proposed merging lp:~anj/epics-base/keywords into lp:epics-base.
Requested reviews:
EPICS Core Developers (epics-core)
This branch updates the Release Process Checklist document which hasn't been done since we moved to Bazaar and Launchpad. It adds Bazaar commands, the revised tag formats, and some steps for updating Launchpad.
There are some changes in CONFIG_BASE_VERSION and the script that generates epicsVersion.h from it to remove "CVS" from some names, although there is a compatibility definition for CVS_DATE. CVS_NAME is now a deprecated fixed string as Bazaar has no equivalent to the RCS $Name$ keyword.
Bazaar's keywords plug-in supports the $Date$ keyword, but not the more common $Id$ and $Header$ ones, so this branch replaces both of those with $Revision-Id$ (which unfortunately touches a large proportion of the source files). It also removes all $Log$ keywords, and replaces some non-ASCII space characters in the documentation files which crash the 'bzr export' command.
This branch will be merged before the 3.14.12-pre1 release.
https://code.launchpad.net/~anj/epics-base/keywords/+merge/37769
Your team EPICS Core Developers is requested to review the proposed merge of lp:~anj/epics-base/keywords into lp:epics-base.
=== modified file 'Makefile'
--- Makefile 2008-03-24 22:04:01 +0000
+++ Makefile 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
# in file LICENSE that is included with this distribution.
-# $Id$
+# $Revision-Id$
TOP = .
=== modified file 'config/CONFIG'
--- config/CONFIG 2002-07-12 21:35:43 +0000
+++ config/CONFIG 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-# $Id$
+# $Revision-Id$
# The developer may edit this file.
# assume T_A is the host arch if not specified
=== modified file 'config/CONFIG.Host.cygwin-x86'
--- config/CONFIG.Host.cygwin-x86 2006-03-16 17:29:00 +0000
+++ config/CONFIG.Host.cygwin-x86 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
# and higher are distributed subject to a Software License Agreement found
-# $Id$
+# $Revision-Id$
# cygwin-x86 is the new name for cygwin32
-include $(EPICS_BASE)/config/CONFIG.Host.cygwin32
=== modified file 'config/CONFIG.Host.darwin-ppc'
--- config/CONFIG.Host.darwin-ppc 2002-07-12 21:35:43 +0000
+++ config/CONFIG.Host.darwin-ppc 2010-10-06 18:12:40 +0000
@@ -7,6 +7,6 @@
-# $Id$
+# $Revision-Id$
-include $(EPICS_BASE)/config/CONFIG.Host.Darwin
=== modified file 'config/CONFIG.Host.darwin-ppcx86'
--- config/CONFIG.Host.darwin-ppcx86 2006-11-09 14:50:20 +0000
+++ config/CONFIG.Host.darwin-ppcx86 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
OP_SYS_CFLAGS += "-isysroot /Developer/SDKs/MacOSX10.4u.sdk -arch ppc -arch i386"
=== modified file 'config/CONFIG.Host.darwin-x86'
--- config/CONFIG.Host.darwin-x86 2006-04-08 16:36:46 +0000
+++ config/CONFIG.Host.darwin-x86 2010-10-06 18:12:40 +0000
@@ -7,6 +7,6 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG.Host.freebsd'
--- config/CONFIG.Host.freebsd 2006-12-07 20:05:20 +0000
+++ config/CONFIG.Host.freebsd 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
# EPICS BASE is distributed subject to a Software License Agreement found
-# $Id$
+# $Revision-Id$
# This file is maintained by the EPICS community.
# Sites may override these definitions in CONFIG_SITE.Host.freebsd
=== modified file 'config/CONFIG.Host.freebsd-x86'
--- config/CONFIG.Host.freebsd-x86 2006-12-07 20:05:20 +0000
+++ config/CONFIG.Host.freebsd-x86 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-# $Id$
+# $Revision-Id$
ARCH_CLASS = x86
=== modified file 'config/CONFIG.Host.freebsd-x86_64'
--- config/CONFIG.Host.freebsd-x86_64 2006-12-07 20:05:20 +0000
+++ config/CONFIG.Host.freebsd-x86_64 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-# $Id$
+# $Revision-Id$
ARCH_CLASS = x86_64
=== modified file 'config/CONFIG.Host.hpux-parisc'
--- config/CONFIG.Host.hpux-parisc 2002-10-15 14:13:35 +0000
+++ config/CONFIG.Host.hpux-parisc 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# hpux-parisc is the new name for hp700
-include $(EPICS_BASE)/config/CONFIG.Host.hp700
=== modified file 'config/CONFIG.Host.linux-ppc'
--- config/CONFIG.Host.linux-ppc 2006-11-17 22:00:03 +0000
+++ config/CONFIG.Host.linux-ppc 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
-include $(EPICS_BASE)/config/CONFIG.Host.Linux
=== modified file 'config/CONFIG.Host.linux-x86'
--- config/CONFIG.Host.linux-x86 2002-07-12 21:35:43 +0000
+++ config/CONFIG.Host.linux-x86 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# linux-x86 is the new name for linux
=== modified file 'config/CONFIG.Host.linux-x86-debug'
--- config/CONFIG.Host.linux-x86-debug 2006-11-17 22:00:03 +0000
+++ config/CONFIG.Host.linux-x86-debug 2010-10-06 18:12:40 +0000
@@ -7,6 +7,6 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG.Host.linux-x86_64'
--- config/CONFIG.Host.linux-x86_64 2006-11-20 23:11:33 +0000
+++ config/CONFIG.Host.linux-x86_64 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG.Host.linux-x86_64-debug'
--- config/CONFIG.Host.linux-x86_64-debug 2006-11-20 21:37:53 +0000
+++ config/CONFIG.Host.linux-x86_64-debug 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
-include $(EPICS_BASE)/config/CONFIG.Host.linux-x86_64
=== modified file 'config/CONFIG.Host.osf-alpha'
--- config/CONFIG.Host.osf-alpha 2002-07-12 21:35:43 +0000
+++ config/CONFIG.Host.osf-alpha 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# osf-alpha is the new name for alpha
-include $(EPICS_BASE)/config/CONFIG.Host.alpha
=== modified file 'config/CONFIG.Host.osf-alpha-gnu'
--- config/CONFIG.Host.osf-alpha-gnu 2006-12-19 16:50:54 +0000
+++ config/CONFIG.Host.osf-alpha-gnu 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG.Host.solaris-sparc'
--- config/CONFIG.Host.solaris-sparc 2002-07-12 21:35:43 +0000
+++ config/CONFIG.Host.solaris-sparc 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# solaris-sparc is the new name for solaris
-include $(EPICS_BASE)/config/CONFIG.Host.solaris
=== modified file 'config/CONFIG.Host.solaris-sparc-debug'
--- config/CONFIG.Host.solaris-sparc-debug 2003-06-19 17:33:30 +0000
+++ config/CONFIG.Host.solaris-sparc-debug 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG.Host.solaris-sparc-gnu'
--- config/CONFIG.Host.solaris-sparc-gnu 2002-12-09 20:32:43 +0000
+++ config/CONFIG.Host.solaris-sparc-gnu 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
-include $(EPICS_BASE)/config/CONFIG.Host.solarisGnu
=== modified file 'config/CONFIG.Host.solaris-sparc-staticlib'
--- config/CONFIG.Host.solaris-sparc-staticlib 2003-06-19 17:33:30 +0000
+++ config/CONFIG.Host.solaris-sparc-staticlib 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG.Host.solaris-sparc64'
--- config/CONFIG.Host.solaris-sparc64 2006-11-28 18:52:13 +0000
+++ config/CONFIG.Host.solaris-sparc64 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG.Host.solaris-sparc64-gnu'
--- config/CONFIG.Host.solaris-sparc64-gnu 2006-11-17 22:00:03 +0000
+++ config/CONFIG.Host.solaris-sparc64-gnu 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG.Host.sun4-sparc'
--- config/CONFIG.Host.sun4-sparc 2002-07-12 21:35:43 +0000
+++ config/CONFIG.Host.sun4-sparc 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# sun4-sparc is the new name for sun4
-include $(EPICS_BASE)/config/CONFIG.Host.sun4
=== modified file 'config/CONFIG.Host.win32-x86'
--- config/CONFIG.Host.win32-x86 2002-07-12 21:35:43 +0000
+++ config/CONFIG.Host.win32-x86 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# win32-x86 is the new name for WIN32
-include $(EPICS_BASE)/config/CONFIG.Host.WIN32
=== modified file 'config/CONFIG.Host.win32-x86-borland'
--- config/CONFIG.Host.win32-x86-borland 2002-07-12 21:35:43 +0000
+++ config/CONFIG.Host.win32-x86-borland 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# win32-x86-borland is the new name for Borland
-include $(EPICS_BASE)/config/CONFIG.Host.Borland
=== modified file 'config/CONFIG.Host.win32-x86-cygwin'
--- config/CONFIG.Host.win32-x86-cygwin 2006-11-28 16:57:01 +0000
+++ config/CONFIG.Host.win32-x86-cygwin 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# Sites may override these definitions in CONFIG_SITE.Host.win32-x86-cygwin
=== modified file 'config/CONFIG.Host.win32-x86-debug'
--- config/CONFIG.Host.win32-x86-debug 2006-11-17 22:00:03 +0000
+++ config/CONFIG.Host.win32-x86-debug 2010-10-06 18:12:40 +0000
@@ -7,6 +7,6 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG.Host.win32-x86-mingw'
--- config/CONFIG.Host.win32-x86-mingw 2006-12-04 17:41:15 +0000
+++ config/CONFIG.Host.win32-x86-mingw 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# Sites may override these definitions in CONFIG_SITE.Host.win32-x86-mingw
=== modified file 'config/CONFIG.Vx'
--- config/CONFIG.Vx 2004-05-17 14:38:37 +0000
+++ config/CONFIG.Vx 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# This file contains definitions for Vx builds
=== modified file 'config/CONFIG.Vx.frc40'
--- config/CONFIG.Vx.frc40 2002-07-12 21:35:43 +0000
+++ config/CONFIG.Vx.frc40 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG.Vx.hkbaja47'
--- config/CONFIG.Vx.hkbaja47 2002-07-12 21:35:43 +0000
+++ config/CONFIG.Vx.hkbaja47 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG.Vx.hkbaja60'
--- config/CONFIG.Vx.hkbaja60 2002-07-12 21:35:43 +0000
+++ config/CONFIG.Vx.hkbaja60 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG.Vx.hkv2f'
--- config/CONFIG.Vx.hkv2f 2002-07-12 21:35:43 +0000
+++ config/CONFIG.Vx.hkv2f 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG.Vx.mv147'
--- config/CONFIG.Vx.mv147 2002-07-12 21:35:43 +0000
+++ config/CONFIG.Vx.mv147 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG.Vx.mv1604'
--- config/CONFIG.Vx.mv1604 2002-07-12 21:35:43 +0000
+++ config/CONFIG.Vx.mv1604 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG.Vx.mv162'
--- config/CONFIG.Vx.mv162 2002-07-12 21:35:43 +0000
+++ config/CONFIG.Vx.mv162 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG.Vx.mv162lc'
--- config/CONFIG.Vx.mv162lc 2002-07-12 21:35:43 +0000
+++ config/CONFIG.Vx.mv162lc 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG.Vx.mv167'
--- config/CONFIG.Vx.mv167 2002-07-12 21:35:43 +0000
+++ config/CONFIG.Vx.mv167 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG.Vx.mv177'
--- config/CONFIG.Vx.mv177 2002-07-12 21:35:43 +0000
+++ config/CONFIG.Vx.mv177 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG.Vx.mv2700'
--- config/CONFIG.Vx.mv2700 2002-07-12 21:35:43 +0000
+++ config/CONFIG.Vx.mv2700 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG.Vx.ppc603'
--- config/CONFIG.Vx.ppc603 2002-12-09 20:32:43 +0000
+++ config/CONFIG.Vx.ppc603 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG.Vx.ppc603_long'
--- config/CONFIG.Vx.ppc603_long 2002-12-09 20:32:43 +0000
+++ config/CONFIG.Vx.ppc603_long 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG.Vx.ppc604'
--- config/CONFIG.Vx.ppc604 2002-12-09 20:32:43 +0000
+++ config/CONFIG.Vx.ppc604 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG.Vx.ppc604_long'
--- config/CONFIG.Vx.ppc604_long 2002-12-09 20:32:43 +0000
+++ config/CONFIG.Vx.ppc604_long 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG.Vx.vxWorks-486'
--- config/CONFIG.Vx.vxWorks-486 2002-07-12 21:35:43 +0000
+++ config/CONFIG.Vx.vxWorks-486 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# vxWorks-486 is the new R3.14 name for pc486
include $(EPICS_BASE)/config/CONFIG.Vx.pc486
=== modified file 'config/CONFIG.Vx.vxWorks-68040'
--- config/CONFIG.Vx.vxWorks-68040 2002-07-12 21:35:43 +0000
+++ config/CONFIG.Vx.vxWorks-68040 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# vxWorks-68040 is the new R3.14 name for mv167
include $(EPICS_BASE)/config/CONFIG.Vx.mv167
=== modified file 'config/CONFIG.Vx.vxWorks-68040lc'
--- config/CONFIG.Vx.vxWorks-68040lc 2002-07-12 21:35:43 +0000
+++ config/CONFIG.Vx.vxWorks-68040lc 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# vxWorks-68040lc is the new R3.14 name for mv162lc
include $(EPICS_BASE)/config/CONFIG.Vx.mv162lc
=== modified file 'config/CONFIG.Vx.vxWorks-68060'
--- config/CONFIG.Vx.vxWorks-68060 2002-07-12 21:35:43 +0000
+++ config/CONFIG.Vx.vxWorks-68060 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# vxWorks-68060 is the new R3.14 name for mv177
include $(EPICS_BASE)/config/CONFIG.Vx.mv177
=== modified file 'config/CONFIG.Vx.vxWorks-ppc603'
--- config/CONFIG.Vx.vxWorks-ppc603 2002-10-01 15:44:59 +0000
+++ config/CONFIG.Vx.vxWorks-ppc603 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# vxWorks-ppc603 is the new R3.14 name for ppc603
include $(EPICS_BASE)/config/CONFIG.Vx.ppc603
=== modified file 'config/CONFIG.Vx.vxWorks-ppc603_long'
--- config/CONFIG.Vx.vxWorks-ppc603_long 2004-01-22 15:55:06 +0000
+++ config/CONFIG.Vx.vxWorks-ppc603_long 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
include $(EPICS_BASE)/config/CONFIG.Vx.ppc603_long
=== modified file 'config/CONFIG.Vx.vxWorks-ppc604'
--- config/CONFIG.Vx.vxWorks-ppc604 2002-07-12 21:35:43 +0000
+++ config/CONFIG.Vx.vxWorks-ppc604 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# vxWorks-ppc604 is the new R3.14 name for ppc604
include $(EPICS_BASE)/config/CONFIG.Vx.ppc604
=== modified file 'config/CONFIG.Vx.vxWorks-ppc604_long'
--- config/CONFIG.Vx.vxWorks-ppc604_long 2004-01-22 15:55:06 +0000
+++ config/CONFIG.Vx.vxWorks-ppc604_long 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
include $(EPICS_BASE)/config/CONFIG.Vx.ppc604_long
=== modified file 'config/CONFIG_BASE'
--- config/CONFIG_BASE 2006-03-20 17:57:41 +0000
+++ config/CONFIG_BASE 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-# $Id$
+# $Revision-Id$
# the order of following list is important
=== modified file 'config/CONFIG_BASE_VERSION'
--- config/CONFIG_BASE_VERSION 2005-12-16 16:47:52 +0000
+++ config/CONFIG_BASE_VERSION 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-# $Id$
+# $Revision-Id$
# EPICS Version information now comes from configure...
=== modified file 'config/CONFIG_COMMON'
--- config/CONFIG_COMMON 2006-11-28 16:55:29 +0000
+++ config/CONFIG_COMMON 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-# $Id$
+# $Revision-Id$
# CONFIG_COMMON - Another EPICS BASE config file
# by Matthew Needes and Mike Bordua
=== modified file 'config/CONFIG_COMPAT'
--- config/CONFIG_COMPAT 2006-11-17 22:31:54 +0000
+++ config/CONFIG_COMPAT 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-# $Id$
+# $Revision-Id$
# Convert old HOST_ARCH environment variable
=== modified file 'config/CONFIG_ENV'
--- config/CONFIG_ENV 2002-07-12 21:35:43 +0000
+++ config/CONFIG_ENV 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# Author: Andrew Johnson
# Date: 20 April 1995
=== modified file 'config/CONFIG_HOST_ARCH.darwin-ppc'
--- config/CONFIG_HOST_ARCH.darwin-ppc 2002-07-12 21:35:43 +0000
+++ config/CONFIG_HOST_ARCH.darwin-ppc 2010-10-06 18:12:40 +0000
@@ -7,6 +7,6 @@
-# $Id$
+# $Revision-Id$
-include $(EPICS_BASE)/config/CONFIG_HOST_ARCH.Darwin
=== modified file 'config/CONFIG_HOST_ARCH.darwin-ppcx86'
--- config/CONFIG_HOST_ARCH.darwin-ppcx86 2006-11-09 14:50:20 +0000
+++ config/CONFIG_HOST_ARCH.darwin-ppcx86 2010-10-06 18:12:40 +0000
@@ -7,6 +7,6 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG_HOST_ARCH.darwin-x86'
--- config/CONFIG_HOST_ARCH.darwin-x86 2006-04-08 16:36:46 +0000
+++ config/CONFIG_HOST_ARCH.darwin-x86 2010-10-06 18:12:40 +0000
@@ -7,6 +7,6 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG_HOST_ARCH.freebsd-x86_64'
--- config/CONFIG_HOST_ARCH.freebsd-x86_64 2006-12-07 20:05:20 +0000
+++ config/CONFIG_HOST_ARCH.freebsd-x86_64 2010-10-06 18:12:40 +0000
@@ -6,6 +6,6 @@
-# $Id$
+# $Revision-Id$
-include $(EPICS_BASE)/config/CONFIG_HOST_ARCH.UnixCommon
=== modified file 'config/CONFIG_HOST_ARCH.hpux-parisc'
--- config/CONFIG_HOST_ARCH.hpux-parisc 2002-12-19 17:21:55 +0000
+++ config/CONFIG_HOST_ARCH.hpux-parisc 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
-include $(EPICS_BASE)/config/CONFIG_HOST_ARCH.hp700
=== modified file 'config/CONFIG_HOST_ARCH.hpux-parisc-gnu'
--- config/CONFIG_HOST_ARCH.hpux-parisc-gnu 2003-04-15 11:34:38 +0000
+++ config/CONFIG_HOST_ARCH.hpux-parisc-gnu 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG_HOST_ARCH.linux-ppc'
--- config/CONFIG_HOST_ARCH.linux-ppc 2006-11-17 22:00:03 +0000
+++ config/CONFIG_HOST_ARCH.linux-ppc 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
-include $(EPICS_BASE)/config/CONFIG_HOST_ARCH.Linux
=== modified file 'config/CONFIG_HOST_ARCH.linux-x86'
--- config/CONFIG_HOST_ARCH.linux-x86 2002-07-12 21:35:43 +0000
+++ config/CONFIG_HOST_ARCH.linux-x86 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG_HOST_ARCH.linux-x86-debug'
--- config/CONFIG_HOST_ARCH.linux-x86-debug 2006-11-17 22:00:03 +0000
+++ config/CONFIG_HOST_ARCH.linux-x86-debug 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG_HOST_ARCH.linux-x86_64'
--- config/CONFIG_HOST_ARCH.linux-x86_64 2006-11-20 21:37:53 +0000
+++ config/CONFIG_HOST_ARCH.linux-x86_64 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# Include definitions common to all Unix archs
=== modified file 'config/CONFIG_HOST_ARCH.linux-x86_64-debug'
--- config/CONFIG_HOST_ARCH.linux-x86_64-debug 2006-11-20 21:37:53 +0000
+++ config/CONFIG_HOST_ARCH.linux-x86_64-debug 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
include $(EPICS_BASE)/config/CONFIG_HOST_ARCH.linux-x86_64
=== modified file 'config/CONFIG_HOST_ARCH.osf-alpha'
--- config/CONFIG_HOST_ARCH.osf-alpha 2002-07-12 21:35:43 +0000
+++ config/CONFIG_HOST_ARCH.osf-alpha 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
-include $(EPICS_BASE)/config/CONFIG_HOST_ARCH.alpha
=== modified file 'config/CONFIG_HOST_ARCH.solaris-sparc'
--- config/CONFIG_HOST_ARCH.solaris-sparc 2002-07-12 21:35:43 +0000
+++ config/CONFIG_HOST_ARCH.solaris-sparc 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
-include $(EPICS_BASE)/config/CONFIG_HOST_ARCH.solaris
=== modified file 'config/CONFIG_HOST_ARCH.solaris-sparc-debug'
--- config/CONFIG_HOST_ARCH.solaris-sparc-debug 2006-11-17 22:01:09 +0000
+++ config/CONFIG_HOST_ARCH.solaris-sparc-debug 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG_HOST_ARCH.solaris-sparc-gnu'
--- config/CONFIG_HOST_ARCH.solaris-sparc-gnu 2003-06-19 17:29:16 +0000
+++ config/CONFIG_HOST_ARCH.solaris-sparc-gnu 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
-include $(EPICS_BASE)/config/CONFIG_HOST_ARCH.solarisGnu
=== modified file 'config/CONFIG_HOST_ARCH.solaris-sparc-staticlib'
--- config/CONFIG_HOST_ARCH.solaris-sparc-staticlib 2003-06-19 17:33:30 +0000
+++ config/CONFIG_HOST_ARCH.solaris-sparc-staticlib 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG_HOST_ARCH.solaris-sparc64'
--- config/CONFIG_HOST_ARCH.solaris-sparc64 2006-11-15 22:08:22 +0000
+++ config/CONFIG_HOST_ARCH.solaris-sparc64 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG_HOST_ARCH.solaris-sparc64-gnu'
--- config/CONFIG_HOST_ARCH.solaris-sparc64-gnu 2006-11-17 22:00:03 +0000
+++ config/CONFIG_HOST_ARCH.solaris-sparc64-gnu 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG_HOST_ARCH.solaris-x86-gnu'
--- config/CONFIG_HOST_ARCH.solaris-x86-gnu 2003-06-19 17:29:16 +0000
+++ config/CONFIG_HOST_ARCH.solaris-x86-gnu 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG_HOST_ARCH.sun4-sparc'
--- config/CONFIG_HOST_ARCH.sun4-sparc 2002-07-12 21:35:43 +0000
+++ config/CONFIG_HOST_ARCH.sun4-sparc 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
-include $(EPICS_BASE)/config/CONFIG_HOST_ARCH.sun4
=== modified file 'config/CONFIG_HOST_ARCH.win32-x86'
--- config/CONFIG_HOST_ARCH.win32-x86 2002-07-12 21:35:43 +0000
+++ config/CONFIG_HOST_ARCH.win32-x86 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
-include $(EPICS_BASE)/config/CONFIG_HOST_ARCH.WIN32
=== modified file 'config/CONFIG_HOST_ARCH.win32-x86-borland'
--- config/CONFIG_HOST_ARCH.win32-x86-borland 2002-07-12 21:35:43 +0000
+++ config/CONFIG_HOST_ARCH.win32-x86-borland 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
-include $(EPICS_BASE)/config/CONFIG_HOST_ARCH.Borland
=== modified file 'config/CONFIG_HOST_ARCH.win32-x86-cygwin'
--- config/CONFIG_HOST_ARCH.win32-x86-cygwin 2006-11-17 22:00:03 +0000
+++ config/CONFIG_HOST_ARCH.win32-x86-cygwin 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# Override values in CONFIG_SITE_HOST_ARCH.win32-x86-cygwin
=== modified file 'config/CONFIG_HOST_ARCH.win32-x86-debug'
--- config/CONFIG_HOST_ARCH.win32-x86-debug 2006-11-17 22:00:03 +0000
+++ config/CONFIG_HOST_ARCH.win32-x86-debug 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG_HOST_ARCH.win32-x86-mingw'
--- config/CONFIG_HOST_ARCH.win32-x86-mingw 2006-11-17 22:00:03 +0000
+++ config/CONFIG_HOST_ARCH.win32-x86-mingw 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# Override values in CONFIG_SITE_HOST_ARCH.win32-x86-mingw
=== modified file 'config/CONFIG_SITE'
--- config/CONFIG_SITE 2003-06-19 17:29:38 +0000
+++ config/CONFIG_SITE 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
# CONFIG_SITE - EPICS BASE config file
=== modified file 'config/CONFIG_SITE.Host.Borland'
--- config/CONFIG_SITE.Host.Borland 2001-03-07 21:13:50 +0000
+++ config/CONFIG_SITE.Host.Borland 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
# Site Specific Configuration Information
# Only the local epics system manager should modify this file
=== modified file 'config/CONFIG_SITE.Host.WIN32'
--- config/CONFIG_SITE.Host.WIN32 1998-05-13 14:44:21 +0000
+++ config/CONFIG_SITE.Host.WIN32 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG_SITE.Host.darwin-ppc'
--- config/CONFIG_SITE.Host.darwin-ppc 2002-03-26 18:00:13 +0000
+++ config/CONFIG_SITE.Host.darwin-ppc 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
-include $(EPICS_BASE)/config/CONFIG_SITE.Host.Darwin
=== modified file 'config/CONFIG_SITE.Host.darwin-x86'
--- config/CONFIG_SITE.Host.darwin-x86 2006-04-08 16:36:46 +0000
+++ config/CONFIG_SITE.Host.darwin-x86 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG_SITE.Host.hp700'
--- config/CONFIG_SITE.Host.hp700 2003-04-15 11:34:38 +0000
+++ config/CONFIG_SITE.Host.hp700 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG_SITE.Host.hpux-parisc'
--- config/CONFIG_SITE.Host.hpux-parisc 2002-10-15 14:13:35 +0000
+++ config/CONFIG_SITE.Host.hpux-parisc 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
-include $(EPICS_BASE)/config/CONFIG_SITE.Host.hp700
=== modified file 'config/CONFIG_SITE.Host.hpux-parisc-gnu'
--- config/CONFIG_SITE.Host.hpux-parisc-gnu 2003-04-15 11:34:38 +0000
+++ config/CONFIG_SITE.Host.hpux-parisc-gnu 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG_SITE.Host.linux-x86'
--- config/CONFIG_SITE.Host.linux-x86 2002-07-17 19:59:44 +0000
+++ config/CONFIG_SITE.Host.linux-x86 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
-include $(EPICS_BASE)/config/CONFIG_SITE.Host.Linux
=== modified file 'config/CONFIG_SITE.Host.solaris'
--- config/CONFIG_SITE.Host.solaris 2003-03-26 21:09:32 +0000
+++ config/CONFIG_SITE.Host.solaris 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG_SITE.Host.solaris-sparc'
--- config/CONFIG_SITE.Host.solaris-sparc 2000-03-28 21:53:47 +0000
+++ config/CONFIG_SITE.Host.solaris-sparc 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
-include $(EPICS_BASE)/config/CONFIG_SITE.Host.solaris
=== modified file 'config/CONFIG_SITE.Host.solaris-sparc-debug'
--- config/CONFIG_SITE.Host.solaris-sparc-debug 2003-06-19 17:33:30 +0000
+++ config/CONFIG_SITE.Host.solaris-sparc-debug 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG_SITE.Host.solaris-sparc-gnu'
--- config/CONFIG_SITE.Host.solaris-sparc-gnu 2001-04-09 14:13:28 +0000
+++ config/CONFIG_SITE.Host.solaris-sparc-gnu 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG_SITE.Host.solaris-sparc-staticlib'
--- config/CONFIG_SITE.Host.solaris-sparc-staticlib 2003-06-19 17:33:30 +0000
+++ config/CONFIG_SITE.Host.solaris-sparc-staticlib 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG_SITE.Host.solaris-sparc64'
--- config/CONFIG_SITE.Host.solaris-sparc64 2006-11-15 22:08:22 +0000
+++ config/CONFIG_SITE.Host.solaris-sparc64 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG_SITE.Host.win32-x86'
--- config/CONFIG_SITE.Host.win32-x86 2001-03-08 16:28:32 +0000
+++ config/CONFIG_SITE.Host.win32-x86 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
-include $(EPICS_BASE)/config/CONFIG_SITE.Host.WIN32
=== modified file 'config/CONFIG_SITE.Host.win32-x86-borland'
--- config/CONFIG_SITE.Host.win32-x86-borland 2002-01-07 20:46:53 +0000
+++ config/CONFIG_SITE.Host.win32-x86-borland 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
-include $(EPICS_BASE)/config/CONFIG_SITE.Host.Borland
=== modified file 'config/CONFIG_SITE.Vx.Linux'
--- config/CONFIG_SITE.Vx.Linux 2001-03-07 21:13:50 +0000
+++ config/CONFIG_SITE.Vx.Linux 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
# This file contains overrides for Vx builds
=== modified file 'config/CONFIG_SITE.Vx.Linux.mv167'
--- config/CONFIG_SITE.Vx.Linux.mv167 2001-03-07 21:13:50 +0000
+++ config/CONFIG_SITE.Vx.Linux.mv167 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG_SITE.Vx.Linux.ppc603'
--- config/CONFIG_SITE.Vx.Linux.ppc603 2002-12-05 20:39:04 +0000
+++ config/CONFIG_SITE.Vx.Linux.ppc603 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG_SITE.Vx.linux-x86'
--- config/CONFIG_SITE.Vx.linux-x86 2002-07-30 21:28:38 +0000
+++ config/CONFIG_SITE.Vx.linux-x86 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/CONFIG_SITE_ENV'
--- config/CONFIG_SITE_ENV 1998-10-12 19:58:44 +0000
+++ config/CONFIG_SITE_ENV 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
# Date: 1 May 1995
=== modified file 'config/Makefile'
--- config/Makefile 2006-03-20 19:18:35 +0000
+++ config/Makefile 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-# $Id$
+# $Revision-Id$
TOP=..
=== modified file 'config/RULES.Db'
--- config/RULES.Db 2003-07-21 23:08:36 +0000
+++ config/RULES.Db 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# Rules for making things related to databases
=== modified file 'config/RULES.Host'
--- config/RULES.Host 2006-03-09 22:30:19 +0000
+++ config/RULES.Host 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# Rules for making things specified in Makefile.Host
# Some rules for filename-massage are system specific
=== modified file 'config/RULES.Unix'
--- config/RULES.Unix 2004-05-17 14:35:18 +0000
+++ config/RULES.Unix 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
INCREC +=$(RECTYPES) $(MENUS)
INSTALL_PROD = $(PROD:%= $(INSTALL_BIN)/%)
=== modified file 'config/RULES.Vx'
--- config/RULES.Vx 2004-04-09 14:11:17 +0000
+++ config/RULES.Vx 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
ifneq ($(strip $(LIBOBJS_$(ARCH_CLASS))),)
LIBOBJS+=$(subst -nil-,,$(LIBOBJS_$(ARCH_CLASS)))
=== modified file 'config/RULES_ARCHS'
--- config/RULES_ARCHS 2004-04-09 14:11:17 +0000
+++ config/RULES_ARCHS 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-# $Id$
+# $Revision-Id$
# EPICS RULES_ARCH
# by Matthew Needes and Mike Bordua and Janet Anderson and Jeff Hill
=== modified file 'config/RULES_DIRS'
--- config/RULES_DIRS 2002-07-12 21:35:43 +0000
+++ config/RULES_DIRS 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'config/RULES_TOP'
--- config/RULES_TOP 2002-07-12 21:35:43 +0000
+++ config/RULES_TOP 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-# $Id$
+# $Revision-Id$
include $(TOP)/config/RULES_DIRS
=== modified file 'config/tools/munch.pl'
--- config/tools/munch.pl 2002-07-12 21:35:43 +0000
+++ config/tools/munch.pl 2010-10-06 18:12:40 +0000
@@ -11,7 +11,7 @@
# Creates a ctdt.c file of c++ static constructors and destructors.
-# $Id$
+# $Revision-Id$
@ctorlist = ();
@dtorlist = ();
=== modified file 'configure/CONFIG'
--- configure/CONFIG 2010-07-09 21:16:24 +0000
+++ configure/CONFIG 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'configure/CONFIG_ADDONS'
--- configure/CONFIG_ADDONS 2009-04-24 19:31:57 +0000
+++ configure/CONFIG_ADDONS 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-# $Id$
+# $Revision-Id$
# check for add-on CFLAGS and CXXFLAGS
=== modified file 'configure/CONFIG_BASE_VERSION'
--- configure/CONFIG_BASE_VERSION 2009-08-28 19:07:11 +0000
+++ configure/CONFIG_BASE_VERSION 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# Copyright (c) 2008 UChicago Argonne LLC, as Operator of Argonne
+# Copyright (c) 2010 UChicago Argonne LLC, as Operator of Argonne
# National Laboratory.
# Copyright (c) 2002 The Regents of the University of California, as
# Operator of Los Alamos National Laboratory.
@@ -7,7 +7,7 @@
# in the file LICENSE that is included with this distribution.
-# $Id$
+# $Revision-Id$
@@ -32,15 +32,15 @@
# Not included if zero
EPICS_PATCH_LEVEL = 0
-# This will end in -CVS between official releases
-EPICS_CVS_SNAPSHOT=-CVS
-#EPICS_CVS_SNAPSHOT=-pre1
-#EPICS_CVS_SNAPSHOT=-pre1-CVS
-#EPICS_CVS_SNAPSHOT=-RC1
-#EPICS_CVS_SNAPSHOT=-RC1-CVS
-#EPICS_CVS_SNAPSHOT=-RC2
-#EPICS_CVS_SNAPSHOT=-RC2-CVS
+# This will end in -DEV between official releases
+EPICS_DEV_SNAPSHOT=-DEV
+#EPICS_DEV_SNAPSHOT=-pre1
+#EPICS_DEV_SNAPSHOT=-pre1-DEV
+#EPICS_DEV_SNAPSHOT=-rc1
+#EPICS_DEV_SNAPSHOT=-rc1-DEV
+#EPICS_DEV_SNAPSHOT=-rc2
+#EPICS_DEV_SNAPSHOT=-rc2-DEV
# No changes should be needed below here
@@ -53,8 +53,12 @@
endif
EPICS_SHORT_VERSION=$(EPICS_VERSION).$(EPICS_REVISION).$(EPICS_MODIFICATION)$(EPICS_PATCH_VSTRING)
-EPICS_VERSION_NUMBER=$(EPICS_SHORT_VERSION)$(EPICS_CVS_SNAPSHOT)$(EPICS_SITE_VSTRING)
+EPICS_VERSION_NUMBER=$(EPICS_SHORT_VERSION)$(EPICS_DEV_SNAPSHOT)$(EPICS_SITE_VSTRING)
EPICS_VERSION_STRING="EPICS Version $(EPICS_VERSION_NUMBER)"
-CVS_DATE="\$$Date$$"
-CVS_TAG="\$$Name$$"
+COMMIT_DATE="\$$Date$$"
+# Provide these in case anyone is still using the old names
+EPICS_CVS_SNAPSHOT=$(EPICS_DEV_SNAPSHOT)
+CVS_DATE=$(COMMIT_DATE)
+CVS_TAG="-no-tags-"
=== modified file 'configure/CONFIG_COMMON'
--- configure/CONFIG_COMMON 2010-07-29 17:35:53 +0000
+++ configure/CONFIG_COMMON 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-# $Id$
+# $Revision-Id$
# CONFIG_COMMON
=== modified file 'configure/CONFIG_ENV'
--- configure/CONFIG_ENV 2010-08-10 21:05:46 +0000
+++ configure/CONFIG_ENV 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'configure/CONFIG_FILE_TYPE'
--- configure/CONFIG_FILE_TYPE 2008-10-07 20:33:29 +0000
+++ configure/CONFIG_FILE_TYPE 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-# $Id$
+# $Revision-Id$
# Macros and rules to create a new installation file type
=== modified file 'configure/CONFIG_SITE'
--- configure/CONFIG_SITE 2010-07-09 20:53:58 +0000
+++ configure/CONFIG_SITE 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# CONFIG_SITE - Global site configuration file
=== modified file 'configure/CONFIG_SITE_ENV'
--- configure/CONFIG_SITE_ENV 2010-01-05 17:05:05 +0000
+++ configure/CONFIG_SITE_ENV 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-# $Id$
+# $Revision-Id$
# Date: 1 May 1995
=== modified file 'configure/Makefile'
--- configure/Makefile 2008-03-24 22:05:10 +0000
+++ configure/Makefile 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-# $Id$
+# $Revision-Id$
TOP=..
=== modified file 'configure/RULES'
--- configure/RULES 2002-07-12 21:35:43 +0000
+++ configure/RULES 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
ifndef T_A
=== modified file 'configure/RULES_ARCHS'
--- configure/RULES_ARCHS 2010-09-03 15:07:17 +0000
+++ configure/RULES_ARCHS 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
all: install
=== modified file 'configure/RULES_BUILD'
--- configure/RULES_BUILD 2010-09-27 13:43:21 +0000
+++ configure/RULES_BUILD 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'configure/RULES_DIRS'
--- configure/RULES_DIRS 2010-09-03 15:07:17 +0000
+++ configure/RULES_DIRS 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'configure/RULES_FILE_TYPE'
--- configure/RULES_FILE_TYPE 2009-06-26 20:37:22 +0000
+++ configure/RULES_FILE_TYPE 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'configure/RULES_JAVA'
--- configure/RULES_JAVA 2009-06-26 20:37:22 +0000
+++ configure/RULES_JAVA 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
=== modified file 'configure/RULES_OCTAVE'
--- configure/RULES_OCTAVE 2008-03-24 22:06:26 +0000
+++ configure/RULES_OCTAVE 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# Octave definitions and rules
=== modified file 'configure/RULES_TARGET'
--- configure/RULES_TARGET 2009-06-05 16:02:26 +0000
+++ configure/RULES_TARGET 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-# $Id$
+# $Revision-Id$
# RULES_TARGET
=== modified file 'configure/RULES_TOP'
--- configure/RULES_TOP 2009-08-10 16:41:28 +0000
+++ configure/RULES_TOP 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-# $Id$
+# $Revision-Id$
include $(CONFIG)/RULES_DIRS
=== modified file 'configure/os/CONFIG.Common.RTEMS'
--- configure/os/CONFIG.Common.RTEMS 2010-08-30 14:58:24 +0000
+++ configure/os/CONFIG.Common.RTEMS 2010-10-06 18:12:40 +0000
@@ -1,7 +1,7 @@
# This file contains definitions for RTEMS builds
-# $Id$
+# $Revision-Id$
# Author: W. Eric Norum
# University of Saskatchewan
# [email protected]
=== modified file 'configure/os/CONFIG.Common.RTEMS-gen68360'
--- configure/os/CONFIG.Common.RTEMS-gen68360 2000-12-18 16:05:26 +0000
+++ configure/os/CONFIG.Common.RTEMS-gen68360 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
# Canadian Light Source
# [email protected]
=== modified file 'configure/os/CONFIG.Common.RTEMS-mcp750'
--- configure/os/CONFIG.Common.RTEMS-mcp750 2002-10-31 22:05:00 +0000
+++ configure/os/CONFIG.Common.RTEMS-mcp750 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
# [email protected]
=== modified file 'configure/os/CONFIG.Common.RTEMS-mvme167'
--- configure/os/CONFIG.Common.RTEMS-mvme167 2000-12-18 16:05:26 +0000
+++ configure/os/CONFIG.Common.RTEMS-mvme167 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
# [email protected]
=== modified file 'configure/os/CONFIG.Common.RTEMS-mvme2100'
--- configure/os/CONFIG.Common.RTEMS-mvme2100 2009-04-09 18:56:06 +0000
+++ configure/os/CONFIG.Common.RTEMS-mvme2100 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
# [email protected]
=== modified file 'configure/os/CONFIG.Common.RTEMS-mvme5500'
--- configure/os/CONFIG.Common.RTEMS-mvme5500 2009-04-09 18:56:06 +0000
+++ configure/os/CONFIG.Common.RTEMS-mvme5500 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
# Advanced Photon Source
# [email protected]
=== modified file 'configure/os/CONFIG.Common.RTEMS-pc386'
--- configure/os/CONFIG.Common.RTEMS-pc386 2009-04-09 18:56:06 +0000
+++ configure/os/CONFIG.Common.RTEMS-pc386 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
# [email protected]
=== modified file 'configure/os/CONFIG.Common.RTEMS-psim'
--- configure/os/CONFIG.Common.RTEMS-psim 2002-10-31 22:05:00 +0000
+++ configure/os/CONFIG.Common.RTEMS-psim 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
# [email protected]
=== modified file 'configure/os/CONFIG.Common.RTEMS-uC5282'
--- configure/os/CONFIG.Common.RTEMS-uC5282 2009-04-09 18:56:06 +0000
+++ configure/os/CONFIG.Common.RTEMS-uC5282 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
# [email protected]
=== modified file 'configure/os/CONFIG.Common.UnixCommon'
--- configure/os/CONFIG.Common.UnixCommon 2009-08-10 21:50:11 +0000
+++ configure/os/CONFIG.Common.UnixCommon 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.UnixCommon
-# $Id$
+# $Revision-Id$
# Contains definitions common to all Unix target archs
=== modified file 'configure/os/CONFIG.Common.cygwin-x86'
--- configure/os/CONFIG.Common.cygwin-x86 2008-07-31 21:58:37 +0000
+++ configure/os/CONFIG.Common.cygwin-x86 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.cygwin-x86
-# $Id$
+# $Revision-Id$
# This file is maintained by the build community.
# Definitions for cygwin-x86 target builds
=== modified file 'configure/os/CONFIG.Common.darwin-ppc'
--- configure/os/CONFIG.Common.darwin-ppc 2009-05-06 17:25:01 +0000
+++ configure/os/CONFIG.Common.darwin-ppc 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.darwin-ppc
-# $Id$
+# $Revision-Id$
# Definitions for darwin-ppc target builds
=== modified file 'configure/os/CONFIG.Common.darwin-ppcx86'
--- configure/os/CONFIG.Common.darwin-ppcx86 2009-05-06 17:25:01 +0000
+++ configure/os/CONFIG.Common.darwin-ppcx86 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.darwin-ppcx86
-# $Id$
+# $Revision-Id$
# Definitions for Darwin universal PowerPC + x86 target builds
=== modified file 'configure/os/CONFIG.Common.darwin-x86'
--- configure/os/CONFIG.Common.darwin-x86 2009-05-06 17:25:01 +0000
+++ configure/os/CONFIG.Common.darwin-x86 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.darwin-x86
-# $Id$
+# $Revision-Id$
# Definitions for darwin-x86 target builds
=== modified file 'configure/os/CONFIG.Common.freebsd-x86'
--- configure/os/CONFIG.Common.freebsd-x86 2006-12-06 23:31:39 +0000
+++ configure/os/CONFIG.Common.freebsd-x86 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
=== modified file 'configure/os/CONFIG.Common.freebsd-x86_64'
--- configure/os/CONFIG.Common.freebsd-x86_64 2006-11-14 19:40:47 +0000
+++ configure/os/CONFIG.Common.freebsd-x86_64 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
=== modified file 'configure/os/CONFIG.Common.freebsdCommon'
--- configure/os/CONFIG.Common.freebsdCommon 2010-07-09 20:53:58 +0000
+++ configure/os/CONFIG.Common.freebsdCommon 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
=== modified file 'configure/os/CONFIG.Common.iosCommon'
--- configure/os/CONFIG.Common.iosCommon 2010-09-22 21:26:15 +0000
+++ configure/os/CONFIG.Common.iosCommon 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.iosCommon
-# $Id$
+# $Revision-Id$
# Definitions for iOS target archs
=== modified file 'configure/os/CONFIG.Common.linux-386'
--- configure/os/CONFIG.Common.linux-386 2007-12-11 21:15:27 +0000
+++ configure/os/CONFIG.Common.linux-386 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.linux-386
-# $Id$
+# $Revision-Id$
# Definitions for linux-386 target builds
=== modified file 'configure/os/CONFIG.Common.linux-586'
--- configure/os/CONFIG.Common.linux-586 2007-12-11 21:15:27 +0000
+++ configure/os/CONFIG.Common.linux-586 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.linux-586
-# $Id$
+# $Revision-Id$
# Definitions for linux-586 target builds
=== modified file 'configure/os/CONFIG.Common.linux-686'
--- configure/os/CONFIG.Common.linux-686 2007-12-11 21:15:27 +0000
+++ configure/os/CONFIG.Common.linux-686 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.linux-686
-# $Id$
+# $Revision-Id$
# Definitions for linux-686 target builds
=== modified file 'configure/os/CONFIG.Common.linux-athlon'
--- configure/os/CONFIG.Common.linux-athlon 2007-12-11 20:58:26 +0000
+++ configure/os/CONFIG.Common.linux-athlon 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.linux-athlon
-# $Id$
+# $Revision-Id$
# Definitions for linux-athlon target builds
=== modified file 'configure/os/CONFIG.Common.linux-ppc64'
--- configure/os/CONFIG.Common.linux-ppc64 2009-12-21 20:44:19 +0000
+++ configure/os/CONFIG.Common.linux-ppc64 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.linux-ppc64
-# $Id$
+# $Revision-Id$
# Definitions for linux-ppc64 target builds
=== modified file 'configure/os/CONFIG.Common.linux-x86'
--- configure/os/CONFIG.Common.linux-x86 2007-12-11 20:56:39 +0000
+++ configure/os/CONFIG.Common.linux-x86 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.linux-x86
-# $Id$
+# $Revision-Id$
# Definitions for linux-x86 target builds
=== modified file 'configure/os/CONFIG.Common.linux-x86-borland'
--- configure/os/CONFIG.Common.linux-x86-borland 2005-10-28 21:28:00 +0000
+++ configure/os/CONFIG.Common.linux-x86-borland 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.linux-x86-borland
-# $Id$
+# $Revision-Id$
=== modified file 'configure/os/CONFIG.Common.linux-x86-debug'
--- configure/os/CONFIG.Common.linux-x86-debug 2009-05-06 15:31:09 +0000
+++ configure/os/CONFIG.Common.linux-x86-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.linux-x86-debug
-# $Id$
+# $Revision-Id$
# Definitions for linux-x86 with debug compiler flags
=== modified file 'configure/os/CONFIG.Common.linux-x86_64'
--- configure/os/CONFIG.Common.linux-x86_64 2009-12-21 19:28:02 +0000
+++ configure/os/CONFIG.Common.linux-x86_64 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.linux-x86_64
-# $Id$
+# $Revision-Id$
# Definitions for linux-x86_64 target builds
=== modified file 'configure/os/CONFIG.Common.linux-x86_64-debug'
--- configure/os/CONFIG.Common.linux-x86_64-debug 2009-07-13 20:51:44 +0000
+++ configure/os/CONFIG.Common.linux-x86_64-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.linux-x86_64-debug
-# $Id$
+# $Revision-Id$
# Definitions for linux-x86_64 with debug compiler flags
=== modified file 'configure/os/CONFIG.Common.linuxCommon'
--- configure/os/CONFIG.Common.linuxCommon 2010-07-09 20:53:58 +0000
+++ configure/os/CONFIG.Common.linuxCommon 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.linuxCommon
-# $Id$
+# $Revision-Id$
# Definitions for linux target builds
=== modified file 'configure/os/CONFIG.Common.osf-alpha'
--- configure/os/CONFIG.Common.osf-alpha 2010-07-09 20:53:58 +0000
+++ configure/os/CONFIG.Common.osf-alpha 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.osf-alpha
-# $Id$
+# $Revision-Id$
# Definitions for osf-alpha target archs
=== modified file 'configure/os/CONFIG.Common.osf-alpha-gnu'
--- configure/os/CONFIG.Common.osf-alpha-gnu 2010-07-09 20:53:58 +0000
+++ configure/os/CONFIG.Common.osf-alpha-gnu 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.osf-alpha-gnu
-# $Id$
+# $Revision-Id$
=== modified file 'configure/os/CONFIG.Common.solaris-sparc'
--- configure/os/CONFIG.Common.solaris-sparc 2010-07-09 20:53:58 +0000
+++ configure/os/CONFIG.Common.solaris-sparc 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.solaris-sparc
-# $Id$
+# $Revision-Id$
# Definitions for solaris-sparc target archs
=== modified file 'configure/os/CONFIG.Common.solaris-sparc-debug'
--- configure/os/CONFIG.Common.solaris-sparc-debug 2009-05-06 15:31:09 +0000
+++ configure/os/CONFIG.Common.solaris-sparc-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.solaris-sparc-debug
-# $Id$
+# $Revision-Id$
# Definitions for solaris-sparc with debug compiler flags
=== modified file 'configure/os/CONFIG.Common.solaris-sparc-gnu'
--- configure/os/CONFIG.Common.solaris-sparc-gnu 2008-07-10 19:45:02 +0000
+++ configure/os/CONFIG.Common.solaris-sparc-gnu 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.solaris-sparc-gnu
-# $Id$
+# $Revision-Id$
# Definitions for solaris-sparc gnu compiler target archs
=== modified file 'configure/os/CONFIG.Common.solaris-sparc64'
--- configure/os/CONFIG.Common.solaris-sparc64 2007-12-11 20:50:22 +0000
+++ configure/os/CONFIG.Common.solaris-sparc64 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.solaris-sparc64
-# $Id$
+# $Revision-Id$
# Definitions for solaris-sparc64 compiler target archs
=== modified file 'configure/os/CONFIG.Common.solaris-sparc64-gnu'
--- configure/os/CONFIG.Common.solaris-sparc64-gnu 2007-11-07 21:06:09 +0000
+++ configure/os/CONFIG.Common.solaris-sparc64-gnu 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.solaris-sparc64-gnu
-# $Id$
+# $Revision-Id$
# Definitions for solaris-sparc64 gnu compiler target archs
=== modified file 'configure/os/CONFIG.Common.solaris-x86'
--- configure/os/CONFIG.Common.solaris-x86 2010-07-09 20:53:58 +0000
+++ configure/os/CONFIG.Common.solaris-x86 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.solaris-x86
-# $Id$
+# $Revision-Id$
# Definitions for solaris-x86 target archs
=== modified file 'configure/os/CONFIG.Common.solaris-x86-gnu'
--- configure/os/CONFIG.Common.solaris-x86-gnu 2008-07-10 19:45:02 +0000
+++ configure/os/CONFIG.Common.solaris-x86-gnu 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.solaris-x86-gnu
-# $Id$
+# $Revision-Id$
# Definitions for solaris-x86 gnu compiler target archs
=== modified file 'configure/os/CONFIG.Common.solaris-x86_64'
--- configure/os/CONFIG.Common.solaris-x86_64 2007-12-11 20:50:22 +0000
+++ configure/os/CONFIG.Common.solaris-x86_64 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.solaris-x86_64
-# $Id$
+# $Revision-Id$
# Definitions for solaris-x86_64 compiler target archs
=== modified file 'configure/os/CONFIG.Common.solaris-x86_64-gnu'
--- configure/os/CONFIG.Common.solaris-x86_64-gnu 2009-03-03 19:54:19 +0000
+++ configure/os/CONFIG.Common.solaris-x86_64-gnu 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.solaris-x86_64-gnu
-# $Id$
+# $Revision-Id$
# Definitions for solaris-x86_64 gnu compiler target archs
=== modified file 'configure/os/CONFIG.Common.vxWorks-486'
--- configure/os/CONFIG.Common.vxWorks-486 2009-12-21 19:29:29 +0000
+++ configure/os/CONFIG.Common.vxWorks-486 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.vxWorks-486
-# $Id$
+# $Revision-Id$
# Definitions for vxWorks-486 target archs
=== modified file 'configure/os/CONFIG.Common.vxWorks-486-debug'
--- configure/os/CONFIG.Common.vxWorks-486-debug 2008-09-22 15:13:14 +0000
+++ configure/os/CONFIG.Common.vxWorks-486-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.vxWorks-486-debug
-# $Id$
+# $Revision-Id$
# Definitions for vxWorks-486-debug target archs
=== modified file 'configure/os/CONFIG.Common.vxWorks-68040'
--- configure/os/CONFIG.Common.vxWorks-68040 2004-11-17 19:59:20 +0000
+++ configure/os/CONFIG.Common.vxWorks-68040 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.vxWorks-68040
-# $Id$
+# $Revision-Id$
# Definitions for vxWorks-68040 target archs
=== modified file 'configure/os/CONFIG.Common.vxWorks-68040-debug'
--- configure/os/CONFIG.Common.vxWorks-68040-debug 2007-03-09 21:34:53 +0000
+++ configure/os/CONFIG.Common.vxWorks-68040-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.vxWorks-68040-debug
-# $Id$
+# $Revision-Id$
# Definitions for vxWorks-68040-debug target archs
=== modified file 'configure/os/CONFIG.Common.vxWorks-68040lc'
--- configure/os/CONFIG.Common.vxWorks-68040lc 2004-11-17 19:59:20 +0000
+++ configure/os/CONFIG.Common.vxWorks-68040lc 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.vxWorks-68040lc
-# $Id$
+# $Revision-Id$
# Definitions for vxWorks-68040lc target archs
=== modified file 'configure/os/CONFIG.Common.vxWorks-68040lc-debug'
--- configure/os/CONFIG.Common.vxWorks-68040lc-debug 2008-09-22 15:13:14 +0000
+++ configure/os/CONFIG.Common.vxWorks-68040lc-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.vxWorks-68040lc-debug
-# $Id$
+# $Revision-Id$
# Definitions for vxWorks-68040lc-debug target archs
=== modified file 'configure/os/CONFIG.Common.vxWorks-68060'
--- configure/os/CONFIG.Common.vxWorks-68060 2004-11-17 19:59:20 +0000
+++ configure/os/CONFIG.Common.vxWorks-68060 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.vxWorks-68060
-# $Id$
+# $Revision-Id$
# Definitions for vxWorks-68060 target archs
=== modified file 'configure/os/CONFIG.Common.vxWorks-68060-debug'
--- configure/os/CONFIG.Common.vxWorks-68060-debug 2008-09-22 15:13:14 +0000
+++ configure/os/CONFIG.Common.vxWorks-68060-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.vxWorks-68060-debug
-# $Id$
+# $Revision-Id$
# Definitions for vxWorks-68060-debug target archs
=== modified file 'configure/os/CONFIG.Common.vxWorks-mpc8540'
--- configure/os/CONFIG.Common.vxWorks-mpc8540 2009-12-22 23:36:56 +0000
+++ configure/os/CONFIG.Common.vxWorks-mpc8540 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
# Definitions for vxWorks-mpc8540 targets: MPC8540 CPU with >32MB RAM.
# Site-specific overrides go in CONFIG_SITE.Common.vxWorks-mpc8540
=== modified file 'configure/os/CONFIG.Common.vxWorks-mpc8540-debug'
--- configure/os/CONFIG.Common.vxWorks-mpc8540-debug 2008-09-22 15:13:14 +0000
+++ configure/os/CONFIG.Common.vxWorks-mpc8540-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.vxWorks-mpc8540-debug
-# $Id$
+# $Revision-Id$
# Definitions for vxWorks-mpc8540-debug target archs
=== modified file 'configure/os/CONFIG.Common.vxWorks-pentium'
--- configure/os/CONFIG.Common.vxWorks-pentium 2000-04-07 21:18:01 +0000
+++ configure/os/CONFIG.Common.vxWorks-pentium 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.vxWorks-pentium
-# $Id$
+# $Revision-Id$
# Definitions for vxWorks-pentium target archs
=== modified file 'configure/os/CONFIG.Common.vxWorks-pentium-debug'
--- configure/os/CONFIG.Common.vxWorks-pentium-debug 2008-09-22 15:13:14 +0000
+++ configure/os/CONFIG.Common.vxWorks-pentium-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.vxWorks-pentium-debug
-# $Id$
+# $Revision-Id$
# Definitions for vxWorks-pentium-debug target archs
=== modified file 'configure/os/CONFIG.Common.vxWorks-ppc603'
--- configure/os/CONFIG.Common.vxWorks-ppc603 2006-12-09 00:01:57 +0000
+++ configure/os/CONFIG.Common.vxWorks-ppc603 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
# Definitions for vxWorks-ppc603 targets: PPC603 and PMC8240 CPUs
# Site-specific overrides go in CONFIG_SITE.Common.vxWorks-ppc603
=== modified file 'configure/os/CONFIG.Common.vxWorks-ppc603-debug'
--- configure/os/CONFIG.Common.vxWorks-ppc603-debug 2008-09-22 15:13:14 +0000
+++ configure/os/CONFIG.Common.vxWorks-ppc603-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.vxWorks-ppc603-debug
-# $Id$
+# $Revision-Id$
# Definitions for vxWorks-ppc603-debug target archs
=== modified file 'configure/os/CONFIG.Common.vxWorks-ppc603_long'
--- configure/os/CONFIG.Common.vxWorks-ppc603_long 2006-12-09 00:01:57 +0000
+++ configure/os/CONFIG.Common.vxWorks-ppc603_long 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
# Definitions for vxWorks-ppc603 targets with >32MB of RAM
# Site-specific overrides go in CONFIG_SITE.Common.vxWorks-ppc603_long
=== modified file 'configure/os/CONFIG.Common.vxWorks-ppc603_long-debug'
--- configure/os/CONFIG.Common.vxWorks-ppc603_long-debug 2008-09-22 15:13:14 +0000
+++ configure/os/CONFIG.Common.vxWorks-ppc603_long-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.vxWorks-ppc603_long-debug
-# $Id$
+# $Revision-Id$
# Definitions for vxWorks-ppc603_long-debug target archs
=== modified file 'configure/os/CONFIG.Common.vxWorks-ppc604'
--- configure/os/CONFIG.Common.vxWorks-ppc604 2008-05-14 16:31:52 +0000
+++ configure/os/CONFIG.Common.vxWorks-ppc604 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
# Definitions for vxWorks-ppc604 targets: PPC604, MPC7xx and MPC74xx CPUs
# Site-specific overrides go in CONFIG_SITE.Common.vxWorks-ppc604
=== modified file 'configure/os/CONFIG.Common.vxWorks-ppc604-debug'
--- configure/os/CONFIG.Common.vxWorks-ppc604-debug 2008-09-22 15:13:14 +0000
+++ configure/os/CONFIG.Common.vxWorks-ppc604-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.vxWorks-ppc604-debug
-# $Id$
+# $Revision-Id$
# Definitions for vxWorks-ppc604-debug target archs
=== modified file 'configure/os/CONFIG.Common.vxWorks-ppc604_altivec'
--- configure/os/CONFIG.Common.vxWorks-ppc604_altivec 2007-04-16 19:41:07 +0000
+++ configure/os/CONFIG.Common.vxWorks-ppc604_altivec 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
# Definitions for vxWorks-ppc604 targets with an Altivec and >32MB of RAM.
# Site-specific overrides go in CONFIG_SITE.Common.vxWorks-ppc604_altivec
=== modified file 'configure/os/CONFIG.Common.vxWorks-ppc604_altivec-debug'
--- configure/os/CONFIG.Common.vxWorks-ppc604_altivec-debug 2008-09-22 15:13:14 +0000
+++ configure/os/CONFIG.Common.vxWorks-ppc604_altivec-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.vxWorks-ppc604_altivec-debug
-# $Id$
+# $Revision-Id$
# Definitions for vxWorks-ppc604_altivec-debug target archs
=== modified file 'configure/os/CONFIG.Common.vxWorks-ppc604_long'
--- configure/os/CONFIG.Common.vxWorks-ppc604_long 2007-04-16 19:45:35 +0000
+++ configure/os/CONFIG.Common.vxWorks-ppc604_long 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
# Definitions for vxWorks-ppc604 targets with >32MB of RAM
# Site-specific overrides go in CONFIG_SITE.Common.vxWorks-ppc604_long
=== modified file 'configure/os/CONFIG.Common.vxWorks-ppc604_long-debug'
--- configure/os/CONFIG.Common.vxWorks-ppc604_long-debug 2008-09-22 15:13:14 +0000
+++ configure/os/CONFIG.Common.vxWorks-ppc604_long-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.vxWorks-ppc604_long-debug
-# $Id$
+# $Revision-Id$
# Definitions for vxWorks-ppc604_long-debug target archs
=== modified file 'configure/os/CONFIG.Common.vxWorksCommon'
--- configure/os/CONFIG.Common.vxWorksCommon 2010-08-11 15:45:17 +0000
+++ configure/os/CONFIG.Common.vxWorksCommon 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.vxWorksCommon
-# $Id$
+# $Revision-Id$
# Definitions for vxWorks target archs
=== modified file 'configure/os/CONFIG.Common.win32-x86-cygwin'
--- configure/os/CONFIG.Common.win32-x86-cygwin 2008-08-27 19:07:56 +0000
+++ configure/os/CONFIG.Common.win32-x86-cygwin 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.win32-x86-cygwin
-# $Id$
+# $Revision-Id$
=== modified file 'configure/os/CONFIG.Common.win32-x86-mingw'
--- configure/os/CONFIG.Common.win32-x86-mingw 2008-07-31 21:58:37 +0000
+++ configure/os/CONFIG.Common.win32-x86-mingw 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.Common.win32-x86-mingw
-# $Id$
+# $Revision-Id$
# Definitions for win32-x86-mingw target builds
=== modified file 'configure/os/CONFIG.UnixCommon.Common'
--- configure/os/CONFIG.UnixCommon.Common 2003-03-18 22:45:03 +0000
+++ configure/os/CONFIG.UnixCommon.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.UnixCommon.Common
-# $Id$
+# $Revision-Id$
# Definitions common to unix hosts
=== modified file 'configure/os/CONFIG.aix-ppc-gnu.Common'
--- configure/os/CONFIG.aix-ppc-gnu.Common 2003-06-19 17:24:51 +0000
+++ configure/os/CONFIG.aix-ppc-gnu.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.aix-ppc-gnu.Common
-# $Id$
+# $Revision-Id$
# Definitions for aix-ppc gnu compiler host builds
=== modified file 'configure/os/CONFIG.cygwin-x86.Common'
--- configure/os/CONFIG.cygwin-x86.Common 2009-01-27 21:27:32 +0000
+++ configure/os/CONFIG.cygwin-x86.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.cygwin-x86.Common
-# $Id$
+# $Revision-Id$
# Definitions for cygwin-x86 host archs
=== modified file 'configure/os/CONFIG.cygwin-x86.cygwin-x86'
--- configure/os/CONFIG.cygwin-x86.cygwin-x86 2009-03-03 19:54:19 +0000
+++ configure/os/CONFIG.cygwin-x86.cygwin-x86 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.cygwin-x86.cygwin-x86
-# $Id$
+# $Revision-Id$
# Definitions for cygwin-x86 host - cygwin-x86 target builds
# Sites may override these definitions in CONFIG_SITE.cygwin-x86.cygwin-x86
=== modified file 'configure/os/CONFIG.cygwin-x86.cygwin-x86-debug'
--- configure/os/CONFIG.cygwin-x86.cygwin-x86-debug 2009-07-14 19:30:51 +0000
+++ configure/os/CONFIG.cygwin-x86.cygwin-x86-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.cygwin-x86.cygwin-x86-debug
-# $Id$
+# $Revision-Id$
# Definitions for cygwin-x86 host - cygwin-x86-debug target build
=== modified file 'configure/os/CONFIG.darwin-ppc.Common'
--- configure/os/CONFIG.darwin-ppc.Common 2002-03-25 17:52:14 +0000
+++ configure/os/CONFIG.darwin-ppc.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.darwin-ppc.Common
-# $Id$
+# $Revision-Id$
# Definitions for darwin-ppc host builds
=== modified file 'configure/os/CONFIG.darwin-ppc.darwin-ppc-debug'
--- configure/os/CONFIG.darwin-ppc.darwin-ppc-debug 2009-07-13 20:31:45 +0000
+++ configure/os/CONFIG.darwin-ppc.darwin-ppc-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.darwin-ppc.darwin-ppc-debug
-# $Id$
+# $Revision-Id$
# Definitions for darwin-ppc host - darwin-ppc-debug target build with debug compiler flags
=== modified file 'configure/os/CONFIG.darwin-ppcx86.Common'
--- configure/os/CONFIG.darwin-ppcx86.Common 2009-05-06 17:25:01 +0000
+++ configure/os/CONFIG.darwin-ppcx86.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.darwin-ppcx86.Common
-# $Id$
+# $Revision-Id$
# Definitions for Darwin universal PowerPC + x86 host builds
=== modified file 'configure/os/CONFIG.darwin-x86.Common'
--- configure/os/CONFIG.darwin-x86.Common 2006-01-25 21:17:15 +0000
+++ configure/os/CONFIG.darwin-x86.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.darwin-x86.Common
-# $Id$
+# $Revision-Id$
# Definitions for darwin-x86 host builds
=== modified file 'configure/os/CONFIG.darwin-x86.darwin-x86-debug'
--- configure/os/CONFIG.darwin-x86.darwin-x86-debug 2009-07-13 20:31:45 +0000
+++ configure/os/CONFIG.darwin-x86.darwin-x86-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.darwin-x86.darwin-x86-debug
-# $Id$
+# $Revision-Id$
# Definitions for darwin-x86 host - darwin-x86-debug target build with debug compiler flags
=== modified file 'configure/os/CONFIG.darwinCommon.darwinCommon'
--- configure/os/CONFIG.darwinCommon.darwinCommon 2009-11-25 17:15:47 +0000
+++ configure/os/CONFIG.darwinCommon.darwinCommon 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.darwinCommon.darwinCommon
-# $Id$
+# $Revision-Id$
# Common definitions for darwin builds
=== modified file 'configure/os/CONFIG.freebsd-x86.Common'
--- configure/os/CONFIG.freebsd-x86.Common 2006-12-06 23:31:39 +0000
+++ configure/os/CONFIG.freebsd-x86.Common 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
=== modified file 'configure/os/CONFIG.freebsd-x86.freebsd-x86'
--- configure/os/CONFIG.freebsd-x86.freebsd-x86 2007-12-11 20:23:00 +0000
+++ configure/os/CONFIG.freebsd-x86.freebsd-x86 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
# Definitions for freebsd-x86 host - freebsd-x86 target builds
# Sites may override these definitions in CONFIG_SITE.freebsd-x86.freebsd-x86
=== modified file 'configure/os/CONFIG.freebsd-x86_64.Common'
--- configure/os/CONFIG.freebsd-x86_64.Common 2006-12-06 23:31:39 +0000
+++ configure/os/CONFIG.freebsd-x86_64.Common 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
=== modified file 'configure/os/CONFIG.freebsd-x86_64.freebsd-x86_64'
--- configure/os/CONFIG.freebsd-x86_64.freebsd-x86_64 2007-12-11 20:23:00 +0000
+++ configure/os/CONFIG.freebsd-x86_64.freebsd-x86_64 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
# Definitions for freebsd-x86_64 host - freebsd-x86_64 target builds
# Sites may override these definitions in CONFIG_SITE.freebsd-x86_64.freebsd-x86_64
=== modified file 'configure/os/CONFIG.linux-ppc64.Common'
--- configure/os/CONFIG.linux-ppc64.Common 2009-12-21 20:44:19 +0000
+++ configure/os/CONFIG.linux-ppc64.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.linux-ppc64.Common
-# $Id$
+# $Revision-Id$
# Definitions for linux-ppc64 host builds
=== modified file 'configure/os/CONFIG.linux-ppc64.linux-ppc64'
--- configure/os/CONFIG.linux-ppc64.linux-ppc64 2009-12-21 20:44:19 +0000
+++ configure/os/CONFIG.linux-ppc64.linux-ppc64 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.linux-ppc64.linux-ppc64
-# $Id$
+# $Revision-Id$
# Definitions for linux-ppc64 host - linux-ppc64 target builds
# Sites may override these definitions in CONFIG_SITE.linux-ppc64.linux-ppc64
=== modified file 'configure/os/CONFIG.linux-x86-borland.Common'
--- configure/os/CONFIG.linux-x86-borland.Common 2003-09-04 20:20:13 +0000
+++ configure/os/CONFIG.linux-x86-borland.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.linux-x86-borland.Common
-# $Id$
+# $Revision-Id$
# Definitions for linux-x86-borland host builds
=== modified file 'configure/os/CONFIG.linux-x86-borland.linux-x86-borland'
--- configure/os/CONFIG.linux-x86-borland.linux-x86-borland 2009-11-25 17:36:27 +0000
+++ configure/os/CONFIG.linux-x86-borland.linux-x86-borland 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.linux-x86-borland.linux-x86-borland
-# $Id$
+# $Revision-Id$
# Definitions for linux-x86-borland host - linux-x86-borland target builds
# Sites may override these definitions in CONFIG_SITE.linux-x86-borland.linux-x86-borland
=== modified file 'configure/os/CONFIG.linux-x86-debug.Common'
--- configure/os/CONFIG.linux-x86-debug.Common 2003-12-18 15:23:24 +0000
+++ configure/os/CONFIG.linux-x86-debug.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.linux-x86-debug.Common
-# $Id$
+# $Revision-Id$
# Definitions for linux-x86 debug with debug compiler flags
=== modified file 'configure/os/CONFIG.linux-x86-debug.linux-x86-debug'
--- configure/os/CONFIG.linux-x86-debug.linux-x86-debug 2009-07-14 20:17:24 +0000
+++ configure/os/CONFIG.linux-x86-debug.linux-x86-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.linux-x86-debug.linux-x86-debug
-# $Id$
+# $Revision-Id$
# Definitions for linux-x86 host - linux-x86 target build with debug compiler flags
=== modified file 'configure/os/CONFIG.linux-x86.Common'
--- configure/os/CONFIG.linux-x86.Common 2003-09-04 19:57:34 +0000
+++ configure/os/CONFIG.linux-x86.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.linux-x86.Common
-# $Id$
+# $Revision-Id$
# Definitions for linux-x86 host builds
=== modified file 'configure/os/CONFIG.linux-x86.linux-x86'
--- configure/os/CONFIG.linux-x86.linux-x86 2009-07-09 21:52:32 +0000
+++ configure/os/CONFIG.linux-x86.linux-x86 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.linux-x86.linux-x86
-# $Id$
+# $Revision-Id$
# Definitions for linux-x86 host - linux-x86 target builds
# Sites may override these definitions in CONFIG_SITE.linux-x86.linux-x86
=== modified file 'configure/os/CONFIG.linux-x86.linux-x86-debug'
--- configure/os/CONFIG.linux-x86.linux-x86-debug 2009-07-13 20:56:33 +0000
+++ configure/os/CONFIG.linux-x86.linux-x86-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.linux-x86.linux-x86-debug
-# $Id$
+# $Revision-Id$
# Definitions for linux-x86 host - linux-x86-debug target build with debug compiler flags
=== modified file 'configure/os/CONFIG.linux-x86_64-debug.Common'
--- configure/os/CONFIG.linux-x86_64-debug.Common 2005-10-28 15:31:46 +0000
+++ configure/os/CONFIG.linux-x86_64-debug.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.linux-x86_64-debug.Common
-# $Id$
+# $Revision-Id$
# Definitions for linux-x86_64 debug with debug compiler flags
=== modified file 'configure/os/CONFIG.linux-x86_64-debug.linux-x86_64-debug'
--- configure/os/CONFIG.linux-x86_64-debug.linux-x86_64-debug 2009-07-14 20:17:24 +0000
+++ configure/os/CONFIG.linux-x86_64-debug.linux-x86_64-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.linux-x86_64-debug.linux-x86_64-debug
-# $Id$
+# $Revision-Id$
# Definitions for linux-x86_64 host - linux-x86_64 target build with debug compiler flags
=== modified file 'configure/os/CONFIG.linux-x86_64.Common'
--- configure/os/CONFIG.linux-x86_64.Common 2005-11-14 17:12:13 +0000
+++ configure/os/CONFIG.linux-x86_64.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.linux-x86_64.Common
-# $Id$
+# $Revision-Id$
# Definitions for linux-x86_64 host builds
=== modified file 'configure/os/CONFIG.linux-x86_64.linux-x86_64'
--- configure/os/CONFIG.linux-x86_64.linux-x86_64 2009-07-13 20:55:13 +0000
+++ configure/os/CONFIG.linux-x86_64.linux-x86_64 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.linux-x86_64.linux-x86_64
-# $Id$
+# $Revision-Id$
# Definitions for linux-x86_64 host - linux-x86_64 target builds
# Sites may override these definitions in CONFIG_SITE.linux-x86_64.linux-x86_64
=== modified file 'configure/os/CONFIG.linux-x86_64.linux-x86_64-debug'
--- configure/os/CONFIG.linux-x86_64.linux-x86_64-debug 2009-07-13 20:51:44 +0000
+++ configure/os/CONFIG.linux-x86_64.linux-x86_64-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.linux-x86_64.linux-x86_64-debug
-# $Id$
+# $Revision-Id$
# Definitions for linux-x86_64 host - linux-x86_64-debug target build with debug compiler flags
=== modified file 'configure/os/CONFIG.osf-alpha-gnu.Common'
--- configure/os/CONFIG.osf-alpha-gnu.Common 2006-12-20 23:25:56 +0000
+++ configure/os/CONFIG.osf-alpha-gnu.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.osf-alpha-gnu.Common
-# $Id$
+# $Revision-Id$
# Definitions for osf-alpha host archs
=== modified file 'configure/os/CONFIG.osf-alpha-gnu.osf-alpha-gnu'
--- configure/os/CONFIG.osf-alpha-gnu.osf-alpha-gnu 2009-03-03 19:54:19 +0000
+++ configure/os/CONFIG.osf-alpha-gnu.osf-alpha-gnu 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.osf-alpha-gnu.osf-alpha-gnu
-# $Id$
+# $Revision-Id$
=== modified file 'configure/os/CONFIG.osf-alpha.Common'
--- configure/os/CONFIG.osf-alpha.Common 2006-12-20 23:25:56 +0000
+++ configure/os/CONFIG.osf-alpha.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.osf-alpha.Common
-# $Id$
+# $Revision-Id$
=== modified file 'configure/os/CONFIG.osf-alpha.osf-alpha'
--- configure/os/CONFIG.osf-alpha.osf-alpha 2009-03-03 19:54:19 +0000
+++ configure/os/CONFIG.osf-alpha.osf-alpha 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.osf-alpha.osf-alpha
-# $Id$
+# $Revision-Id$
=== modified file 'configure/os/CONFIG.solaris-sparc-debug.Common'
--- configure/os/CONFIG.solaris-sparc-debug.Common 2003-03-18 20:24:18 +0000
+++ configure/os/CONFIG.solaris-sparc-debug.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solaris-sparc-debug.Common
-# $Id$
+# $Revision-Id$
# Definitions for solaris-sparc debug with debug compiler flags
=== modified file 'configure/os/CONFIG.solaris-sparc-debug.solaris-sparc-debug'
--- configure/os/CONFIG.solaris-sparc-debug.solaris-sparc-debug 2008-07-22 20:59:26 +0000
+++ configure/os/CONFIG.solaris-sparc-debug.solaris-sparc-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solaris-sparc-debug.solaris-sparc-debug
-# $Id$
+# $Revision-Id$
# Definitions for solaris-sparc host - solaris-sparc target build with debug compiler flags
=== modified file 'configure/os/CONFIG.solaris-sparc-gnu.Common'
--- configure/os/CONFIG.solaris-sparc-gnu.Common 2001-01-30 16:00:39 +0000
+++ configure/os/CONFIG.solaris-sparc-gnu.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solaris-sparc-gnu.Common
-# $Id$
+# $Revision-Id$
# Definitions for solaris-sparc gnu compiler host builds
=== modified file 'configure/os/CONFIG.solaris-sparc-gnu.solaris-sparc-gnu'
--- configure/os/CONFIG.solaris-sparc-gnu.solaris-sparc-gnu 2009-07-09 21:53:27 +0000
+++ configure/os/CONFIG.solaris-sparc-gnu.solaris-sparc-gnu 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solaris-sparc-gnu.solaris-sparc-gnu
-# $Id$
+# $Revision-Id$
# Definitions for solaris-sparc gnu compiler host - solaris-sparc gnu compiler target builds
=== modified file 'configure/os/CONFIG.solaris-sparc.Common'
--- configure/os/CONFIG.solaris-sparc.Common 2000-04-07 21:18:01 +0000
+++ configure/os/CONFIG.solaris-sparc.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solaris-sparc.Common
-# $Id$
+# $Revision-Id$
# Definitions for solaris-sparc host archs
=== modified file 'configure/os/CONFIG.solaris-sparc.solaris-sparc'
--- configure/os/CONFIG.solaris-sparc.solaris-sparc 2008-07-22 19:49:43 +0000
+++ configure/os/CONFIG.solaris-sparc.solaris-sparc 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solaris-sparc.solaris-sparc
-# $Id$
+# $Revision-Id$
=== modified file 'configure/os/CONFIG.solaris-sparc.solaris-sparc-debug'
--- configure/os/CONFIG.solaris-sparc.solaris-sparc-debug 2009-07-13 21:27:38 +0000
+++ configure/os/CONFIG.solaris-sparc.solaris-sparc-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solaris-sparc.solaris-sparc-debug
-# $Id$
+# $Revision-Id$
# Definitions for solaris-sparc host - solaris-sparc-debug target build with debug compiler flags
=== modified file 'configure/os/CONFIG.solaris-sparc.solaris-sparc-gnu'
--- configure/os/CONFIG.solaris-sparc.solaris-sparc-gnu 2004-01-16 17:36:25 +0000
+++ configure/os/CONFIG.solaris-sparc.solaris-sparc-gnu 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solaris-sparc.solaris-sparc-gnu
-# $Id$
+# $Revision-Id$
# Definitions for solaris-sparc host - solaris-sparc-gnu target build with gnu compiler
=== modified file 'configure/os/CONFIG.solaris-sparc.solaris-sparc64'
--- configure/os/CONFIG.solaris-sparc.solaris-sparc64 2007-11-07 20:26:47 +0000
+++ configure/os/CONFIG.solaris-sparc.solaris-sparc64 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solaris-sparc.solaris-sparc64
-# $Id$
+# $Revision-Id$
# Definitions for solaris-sparc host - solaris-sparc64 target build with Sun compiler
=== modified file 'configure/os/CONFIG.solaris-sparc.solaris-sparc64-gnu'
--- configure/os/CONFIG.solaris-sparc.solaris-sparc64-gnu 2007-11-07 20:32:32 +0000
+++ configure/os/CONFIG.solaris-sparc.solaris-sparc64-gnu 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solaris-sparc.solaris-sparc64-gnu
-# $Id$
+# $Revision-Id$
# Definitions for solaris-sparc host - solaris-sparc64-gnu target build with gnu compiler
=== modified file 'configure/os/CONFIG.solaris-sparc64-gnu.Common'
--- configure/os/CONFIG.solaris-sparc64-gnu.Common 2005-11-03 20:53:08 +0000
+++ configure/os/CONFIG.solaris-sparc64-gnu.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solaris-sparc64-gnu.Common
-# $Id$
+# $Revision-Id$
# Definitions for solaris-sparc64 gnu compiler host builds
=== modified file 'configure/os/CONFIG.solaris-sparc64-gnu.solaris-sparc64-gnu'
--- configure/os/CONFIG.solaris-sparc64-gnu.solaris-sparc64-gnu 2005-11-03 20:53:08 +0000
+++ configure/os/CONFIG.solaris-sparc64-gnu.solaris-sparc64-gnu 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solaris-sparc64-gnu.solaris-sparc64-gnu
-# $Id$
+# $Revision-Id$
# Definitions for solaris-sparc64 gnu compiler host - solaris-sparc64 gnu compiler target builds
=== modified file 'configure/os/CONFIG.solaris-sparc64.Common'
--- configure/os/CONFIG.solaris-sparc64.Common 2005-10-28 18:22:04 +0000
+++ configure/os/CONFIG.solaris-sparc64.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solaris-sparc64.Common
-# $Id$
+# $Revision-Id$
# Definitions for solaris-sparc Sun compiler host builds
=== modified file 'configure/os/CONFIG.solaris-sparc64.solaris-sparc64'
--- configure/os/CONFIG.solaris-sparc64.solaris-sparc64 2005-10-28 18:22:04 +0000
+++ configure/os/CONFIG.solaris-sparc64.solaris-sparc64 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solaris-sparc64.solaris-sparc64
-# $Id$
+# $Revision-Id$
# Definitions for solaris-sparc Sun compiler host - solaris-sparc Sun compiler target builds
=== modified file 'configure/os/CONFIG.solaris-sparc64.solaris-sparc64-debug'
--- configure/os/CONFIG.solaris-sparc64.solaris-sparc64-debug 2009-07-13 21:00:44 +0000
+++ configure/os/CONFIG.solaris-sparc64.solaris-sparc64-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solaris-sparc64.solaris-sparc64-debug
-# $Id$
+# $Revision-Id$
# Definitions for solaris-sparc64 host - solaris-sparc64-debug target build with debug compiler flags
=== modified file 'configure/os/CONFIG.solaris-x86-gnu.Common'
--- configure/os/CONFIG.solaris-x86-gnu.Common 2001-01-30 16:00:39 +0000
+++ configure/os/CONFIG.solaris-x86-gnu.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solaris-x86-gnu.Common
-# $Id$
+# $Revision-Id$
# Definitions for solaris-x86 gnu compiler host builds
=== modified file 'configure/os/CONFIG.solaris-x86-gnu.solaris-x86-gnu'
--- configure/os/CONFIG.solaris-x86-gnu.solaris-x86-gnu 2007-12-11 20:23:00 +0000
+++ configure/os/CONFIG.solaris-x86-gnu.solaris-x86-gnu 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solaris-x86-gnu.solaris-x86-gnu
-# $Id$
+# $Revision-Id$
# Definitions for solaris-x86 gnu compiler host - solaris-x86 gnu compiler target builds
=== modified file 'configure/os/CONFIG.solaris-x86.Common'
--- configure/os/CONFIG.solaris-x86.Common 2001-01-30 16:00:46 +0000
+++ configure/os/CONFIG.solaris-x86.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solaris-x86.Common
-# $Id$
+# $Revision-Id$
# Definitions for solaris-x86 host builds
=== modified file 'configure/os/CONFIG.solaris-x86.solaris-x86'
--- configure/os/CONFIG.solaris-x86.solaris-x86 2008-07-22 19:49:43 +0000
+++ configure/os/CONFIG.solaris-x86.solaris-x86 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solaris-x86.solaris-x86
-# $Id$
+# $Revision-Id$
# Definitions for solaris-x86 host - solaris-x86 target builds
=== modified file 'configure/os/CONFIG.solaris-x86.solaris-x86-debug'
--- configure/os/CONFIG.solaris-x86.solaris-x86-debug 2009-07-13 21:00:44 +0000
+++ configure/os/CONFIG.solaris-x86.solaris-x86-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solaris-x86.solaris-x86-debug
-# $Id$
+# $Revision-Id$
# Definitions for solaris-x86 host - solaris-x86-debug target build with debug compiler flags
=== modified file 'configure/os/CONFIG.solaris-x86.solaris-x86_64'
--- configure/os/CONFIG.solaris-x86.solaris-x86_64 2007-11-07 20:30:21 +0000
+++ configure/os/CONFIG.solaris-x86.solaris-x86_64 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solaris-x86.solaris-x86_64
-# $Id$
+# $Revision-Id$
# Definitions for solaris-x86 host - solaris-x86_64 target build with Sun compiler
=== modified file 'configure/os/CONFIG.solaris-x86_64-gnu.Common'
--- configure/os/CONFIG.solaris-x86_64-gnu.Common 2009-03-03 19:54:19 +0000
+++ configure/os/CONFIG.solaris-x86_64-gnu.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solaris-x86_64-gnu.Common
-# $Id$
+# $Revision-Id$
# Definitions for solaris-x86_64 gnu compiler host builds
=== modified file 'configure/os/CONFIG.solaris-x86_64-gnu.solaris-x86_64-gnu'
--- configure/os/CONFIG.solaris-x86_64-gnu.solaris-x86_64-gnu 2009-03-03 19:54:19 +0000
+++ configure/os/CONFIG.solaris-x86_64-gnu.solaris-x86_64-gnu 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solaris-x86_64-gnu.solaris-x86_64-gnu
-# $Id$
+# $Revision-Id$
# Definitions for solaris-x86_64 gnu compiler host - solaris-sx86_64 gnu compiler target builds
=== modified file 'configure/os/CONFIG.solaris-x86_64.Common'
--- configure/os/CONFIG.solaris-x86_64.Common 2007-11-29 18:41:33 +0000
+++ configure/os/CONFIG.solaris-x86_64.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solaris-x86_64.Common
-# $Id$
+# $Revision-Id$
# Definitions for solaris-x86_64 Sun compiler host builds
=== modified file 'configure/os/CONFIG.solaris-x86_64.solaris-x86_64-debug'
--- configure/os/CONFIG.solaris-x86_64.solaris-x86_64-debug 2009-07-13 21:00:44 +0000
+++ configure/os/CONFIG.solaris-x86_64.solaris-x86_64-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solaris-x86_64.solaris-x86_64-debug
-# $Id$
+# $Revision-Id$
# Definitions for solaris-x86_64 host - solaris-x86_64-debug target build with debug compiler flags
=== modified file 'configure/os/CONFIG.solarisCommon.solarisCommon'
--- configure/os/CONFIG.solarisCommon.solarisCommon 2009-11-25 17:15:47 +0000
+++ configure/os/CONFIG.solarisCommon.solarisCommon 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.solarisCommon.solarisCommon
-# $Id$
+# $Revision-Id$
=== modified file 'configure/os/CONFIG.win32-x86-borland.Common'
--- configure/os/CONFIG.win32-x86-borland.Common 2009-07-13 21:28:30 +0000
+++ configure/os/CONFIG.win32-x86-borland.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.win32-x86-borland.Common
-# $Id$
+# $Revision-Id$
# Definitions for win32-x86-borland host archs
=== modified file 'configure/os/CONFIG.win32-x86-borland.win32-x86-borland'
--- configure/os/CONFIG.win32-x86-borland.win32-x86-borland 2009-04-24 19:31:57 +0000
+++ configure/os/CONFIG.win32-x86-borland.win32-x86-borland 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.win32-x86-borland.win32-x86-borland
-# $Id$
+# $Revision-Id$
# Definitions for win32-x86-borland target arch when host arch is win32-x86-borland
=== modified file 'configure/os/CONFIG.win32-x86-cygwin.Common'
--- configure/os/CONFIG.win32-x86-cygwin.Common 2009-01-27 21:27:32 +0000
+++ configure/os/CONFIG.win32-x86-cygwin.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.win32-x86-cygwin.Common
-# $Id$
+# $Revision-Id$
# Definitions for win32-x86-cygwin host archs
=== modified file 'configure/os/CONFIG.win32-x86-cygwin.win32-x86-cygwin'
--- configure/os/CONFIG.win32-x86-cygwin.win32-x86-cygwin 2009-03-03 19:54:19 +0000
+++ configure/os/CONFIG.win32-x86-cygwin.win32-x86-cygwin 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.win32-x86-cygwin.win32-x86-cygwin
-# $Id$
+# $Revision-Id$
# Definitions for win32-x86-cygwin host - win32-x86-cygwin target builds
# Sites may override these definitions in CONFIG_SITE.win32-x86-cygwin.win32-x86-cygwin
=== modified file 'configure/os/CONFIG.win32-x86-cygwin.win32-x86-cygwin-debug'
--- configure/os/CONFIG.win32-x86-cygwin.win32-x86-cygwin-debug 2009-07-14 19:30:51 +0000
+++ configure/os/CONFIG.win32-x86-cygwin.win32-x86-cygwin-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.win32-x86-cygwin.win32-x86-cygwin-debug
-# $Id$
+# $Revision-Id$
# Definitions for win32-x86-cygwin compiler host - win32-x86-cygwin debug compiler target builds
=== modified file 'configure/os/CONFIG.win32-x86-debug.Common'
--- configure/os/CONFIG.win32-x86-debug.Common 2003-03-18 20:24:18 +0000
+++ configure/os/CONFIG.win32-x86-debug.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.win32-x86-debug.Common
-# $Id$
+# $Revision-Id$
# Definitions for win32-x86 debug with debug compiler flags
=== modified file 'configure/os/CONFIG.win32-x86-debug.win32-x86-debug'
--- configure/os/CONFIG.win32-x86-debug.win32-x86-debug 2008-10-08 19:51:35 +0000
+++ configure/os/CONFIG.win32-x86-debug.win32-x86-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.win32-x86-debug.win32-x86-debug
-# $Id$
+# $Revision-Id$
# Definitions for win32-x86 debug compiler host - win32-x86 debug compiler target builds
=== modified file 'configure/os/CONFIG.win32-x86-mingw.Common'
--- configure/os/CONFIG.win32-x86-mingw.Common 2009-07-10 14:42:09 +0000
+++ configure/os/CONFIG.win32-x86-mingw.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.win32-x86-mingw.Common
-# $Id$
+# $Revision-Id$
=== modified file 'configure/os/CONFIG.win32-x86-mingw.win32-x86-mingw'
--- configure/os/CONFIG.win32-x86-mingw.win32-x86-mingw 2009-03-10 16:44:28 +0000
+++ configure/os/CONFIG.win32-x86-mingw.win32-x86-mingw 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.win32-x86-mingw.win32-x86-mingw
-# $Id$
+# $Revision-Id$
# Definitions for win32-x86-mingw host - win32-x86-mingw target builds
# Sites may override these definitions in CONFIG_SITE.win32-x86-mingw.win32-x86-mingw
=== modified file 'configure/os/CONFIG.win32-x86-mingw.win32-x86-mingw-debug'
--- configure/os/CONFIG.win32-x86-mingw.win32-x86-mingw-debug 2009-07-14 19:30:51 +0000
+++ configure/os/CONFIG.win32-x86-mingw.win32-x86-mingw-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.win32-x86-mingw.win32-x86-mingw-debug
-# $Id$
+# $Revision-Id$
# Definitions for win32-x86-mingw compiler host - win32-x86-mingw debug compiler target builds
=== modified file 'configure/os/CONFIG.win32-x86.Common'
--- configure/os/CONFIG.win32-x86.Common 2009-07-10 14:42:09 +0000
+++ configure/os/CONFIG.win32-x86.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.win32-x86.Common
-# $Id$
+# $Revision-Id$
# Definitions for win32-x86 host archs
=== modified file 'configure/os/CONFIG.win32-x86.win32-x86'
--- configure/os/CONFIG.win32-x86.win32-x86 2010-08-31 16:33:37 +0000
+++ configure/os/CONFIG.win32-x86.win32-x86 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.win32-x86.win32-x86
-# $Id$
+# $Revision-Id$
# Definitions for win32-x86 target archs when host arch is win32-x86
=== modified file 'configure/os/CONFIG.win32-x86.win32-x86-debug'
--- configure/os/CONFIG.win32-x86.win32-x86-debug 2009-07-13 21:18:13 +0000
+++ configure/os/CONFIG.win32-x86.win32-x86-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.win32-x86.win32-x86-debug
-# $Id$
+# $Revision-Id$
# Definitions for win32-x86 host - win32-x86-debug target build
=== modified file 'configure/os/CONFIG.win32-x86.windows-x64'
--- configure/os/CONFIG.win32-x86.windows-x64 2009-10-13 15:54:39 +0000
+++ configure/os/CONFIG.win32-x86.windows-x64 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.win-x86.windows-x64
-# $Id$
+# $Revision-Id$
# Definitions for windows-x64 target archs when host arch is win32-x86
=== modified file 'configure/os/CONFIG.windows-x64.Common'
--- configure/os/CONFIG.windows-x64.Common 2009-10-13 15:54:39 +0000
+++ configure/os/CONFIG.windows-x64.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.windows-x64.Common
-# $Id$
+# $Revision-Id$
# Definitions for windows-x64 host archs
=== modified file 'configure/os/CONFIG.windows-x64.windows-x64'
--- configure/os/CONFIG.windows-x64.windows-x64 2009-10-13 15:54:39 +0000
+++ configure/os/CONFIG.windows-x64.windows-x64 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG.windows-x64.windows-x64
-# $Id$
+# $Revision-Id$
# Definitions for windows-x64 target archs when host arch is windows-x64
=== modified file 'configure/os/CONFIG_COMPAT'
--- configure/os/CONFIG_COMPAT 2009-04-24 20:01:52 +0000
+++ configure/os/CONFIG_COMPAT 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_COMPAT
-# $Id$
+# $Revision-Id$
# Convert old HOST_ARCH environment variable to
# new EPICS_HOST_ARCH environment variable
=== modified file 'configure/os/CONFIG_SITE.Common.cygwin-x86'
--- configure/os/CONFIG_SITE.Common.cygwin-x86 2008-07-31 21:58:37 +0000
+++ configure/os/CONFIG_SITE.Common.cygwin-x86 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.Common.cygwin-x86
-# $Id$
+# $Revision-Id$
# Site Specific definitions for cygwin-x86 target
# Only the local epics system manager should modify this file
=== modified file 'configure/os/CONFIG_SITE.Common.darwin-ppc'
--- configure/os/CONFIG_SITE.Common.darwin-ppc 2009-05-06 17:25:01 +0000
+++ configure/os/CONFIG_SITE.Common.darwin-ppc 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.Common.darwin-ppc
-# $Id$
+# $Revision-Id$
# Site override definitions for darwin-ppc target builds
=== modified file 'configure/os/CONFIG_SITE.Common.darwin-ppcx86'
--- configure/os/CONFIG_SITE.Common.darwin-ppcx86 2009-05-06 17:25:01 +0000
+++ configure/os/CONFIG_SITE.Common.darwin-ppcx86 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.Common.darwin-ppcx86
-# $Id$
+# $Revision-Id$
# Site override definitions for darwin-ppcx86 target builds
=== modified file 'configure/os/CONFIG_SITE.Common.darwin-x86'
--- configure/os/CONFIG_SITE.Common.darwin-x86 2009-05-06 17:25:01 +0000
+++ configure/os/CONFIG_SITE.Common.darwin-x86 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.Common.darwin-x86
-# $Id$
+# $Revision-Id$
# Site override definitions for darwin-x86 target builds
=== modified file 'configure/os/CONFIG_SITE.Common.iosCommon'
--- configure/os/CONFIG_SITE.Common.iosCommon 2010-09-22 21:26:15 +0000
+++ configure/os/CONFIG_SITE.Common.iosCommon 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.Common.iosCommon
-# $Id$
+# $Revision-Id$
# Site-specific settings for Apple iOS builds
=== modified file 'configure/os/CONFIG_SITE.Common.linux-x86'
--- configure/os/CONFIG_SITE.Common.linux-x86 2009-09-29 19:00:49 +0000
+++ configure/os/CONFIG_SITE.Common.linux-x86 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.Common.linux-x86
-# $Id$
+# $Revision-Id$
# Site Specific definitions for linux-x86 target
=== modified file 'configure/os/CONFIG_SITE.Common.linux-x86_64'
--- configure/os/CONFIG_SITE.Common.linux-x86_64 2009-09-29 19:00:49 +0000
+++ configure/os/CONFIG_SITE.Common.linux-x86_64 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.Common.linux-x86_64
-# $Id$
+# $Revision-Id$
# Site Specific definitions for linux-x86_64 target
=== modified file 'configure/os/CONFIG_SITE.Common.solaris-sparc'
--- configure/os/CONFIG_SITE.Common.solaris-sparc 2008-09-15 15:18:41 +0000
+++ configure/os/CONFIG_SITE.Common.solaris-sparc 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.Common.solaris-sparc
-# $Id$
+# $Revision-Id$
# Site Specific definitions for solaris-sparc target
=== modified file 'configure/os/CONFIG_SITE.Common.solaris-sparc-gnu'
--- configure/os/CONFIG_SITE.Common.solaris-sparc-gnu 2008-07-02 15:17:09 +0000
+++ configure/os/CONFIG_SITE.Common.solaris-sparc-gnu 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.Common.solaris-sparc-gnu
-# $Id$
+# $Revision-Id$
# Site Specific definitions for solaris-sparc-gnu target
=== modified file 'configure/os/CONFIG_SITE.Common.solaris-sparc64'
--- configure/os/CONFIG_SITE.Common.solaris-sparc64 2005-10-31 19:14:24 +0000
+++ configure/os/CONFIG_SITE.Common.solaris-sparc64 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.Common.solaris-sparc64
-# $Id$
+# $Revision-Id$
# Site Specific definitions for solaris-sparc64 target
=== modified file 'configure/os/CONFIG_SITE.Common.solaris-sparc64-gnu'
--- configure/os/CONFIG_SITE.Common.solaris-sparc64-gnu 2005-11-03 20:53:08 +0000
+++ configure/os/CONFIG_SITE.Common.solaris-sparc64-gnu 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.Common.solaris-sparc64-gnu
-# $Id$
+# $Revision-Id$
# Site Specific definitions for solaris-sparc64-gnu target
=== modified file 'configure/os/CONFIG_SITE.Common.solaris-x86-gnu'
--- configure/os/CONFIG_SITE.Common.solaris-x86-gnu 2009-03-03 19:54:19 +0000
+++ configure/os/CONFIG_SITE.Common.solaris-x86-gnu 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.Common.solaris-x86-gnu
-# $Id$
+# $Revision-Id$
# Site Specific definitions for solaris-x86-gnu target
=== modified file 'configure/os/CONFIG_SITE.Common.solaris-x86_64'
--- configure/os/CONFIG_SITE.Common.solaris-x86_64 2007-12-12 20:04:54 +0000
+++ configure/os/CONFIG_SITE.Common.solaris-x86_64 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.Common.solaris-x86_64
-# $Id$
+# $Revision-Id$
# Site Specific definitions for solaris-x86_64 target
=== modified file 'configure/os/CONFIG_SITE.Common.solaris-x86_64-gnu'
--- configure/os/CONFIG_SITE.Common.solaris-x86_64-gnu 2009-03-03 19:54:19 +0000
+++ configure/os/CONFIG_SITE.Common.solaris-x86_64-gnu 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.Common.solaris-x86_64-gnu
-# $Id$
+# $Revision-Id$
# Site Specific definitions for solaris-x86_64-gnu target
=== modified file 'configure/os/CONFIG_SITE.Common.vxWorks-mpc8540'
--- configure/os/CONFIG_SITE.Common.vxWorks-mpc8540 2006-12-09 00:01:57 +0000
+++ configure/os/CONFIG_SITE.Common.vxWorks-mpc8540 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
# Site Specific definitions for the vxWorks-mpc8540 target
=== modified file 'configure/os/CONFIG_SITE.Common.vxWorks-ppc603'
--- configure/os/CONFIG_SITE.Common.vxWorks-ppc603 2006-12-09 00:01:57 +0000
+++ configure/os/CONFIG_SITE.Common.vxWorks-ppc603 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
# Site Specific definitions for the vxWorks-ppc603 target
=== modified file 'configure/os/CONFIG_SITE.Common.vxWorks-ppc603_long'
--- configure/os/CONFIG_SITE.Common.vxWorks-ppc603_long 2006-12-09 00:01:57 +0000
+++ configure/os/CONFIG_SITE.Common.vxWorks-ppc603_long 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
# Site Specific definitions for the vxWorks-ppc603_long target
=== modified file 'configure/os/CONFIG_SITE.Common.vxWorks-ppc604'
--- configure/os/CONFIG_SITE.Common.vxWorks-ppc604 2006-12-09 00:01:57 +0000
+++ configure/os/CONFIG_SITE.Common.vxWorks-ppc604 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
# Site Specific definitions for the vxWorks-ppc604 target
=== modified file 'configure/os/CONFIG_SITE.Common.vxWorks-ppc604_altivec'
--- configure/os/CONFIG_SITE.Common.vxWorks-ppc604_altivec 2006-12-09 00:01:57 +0000
+++ configure/os/CONFIG_SITE.Common.vxWorks-ppc604_altivec 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
# Site Specific definitions for the vxWorks-ppc604_altivec target
=== modified file 'configure/os/CONFIG_SITE.Common.vxWorks-ppc604_long'
--- configure/os/CONFIG_SITE.Common.vxWorks-ppc604_long 2006-12-09 00:01:57 +0000
+++ configure/os/CONFIG_SITE.Common.vxWorks-ppc604_long 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
# Site Specific definitions for the vxWorks-ppc604_long target
=== modified file 'configure/os/CONFIG_SITE.Common.win32-x86-cygwin'
--- configure/os/CONFIG_SITE.Common.win32-x86-cygwin 2008-12-01 19:02:21 +0000
+++ configure/os/CONFIG_SITE.Common.win32-x86-cygwin 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.Common.win32-x86-cygwin
-# $Id$
+# $Revision-Id$
=== modified file 'configure/os/CONFIG_SITE.cygwin-x86.Common'
--- configure/os/CONFIG_SITE.cygwin-x86.Common 2004-05-13 22:34:02 +0000
+++ configure/os/CONFIG_SITE.cygwin-x86.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.cygwin-x86.Common
-# $Id$
+# $Revision-Id$
# Site override definitions for cygwin-x86 host builds
=== modified file 'configure/os/CONFIG_SITE.cygwin-x86.cygwin-x86'
--- configure/os/CONFIG_SITE.cygwin-x86.cygwin-x86 2008-07-31 21:58:37 +0000
+++ configure/os/CONFIG_SITE.cygwin-x86.cygwin-x86 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.cygwin-x86.cygwin-x86
-# $Id$
+# $Revision-Id$
# Site override definitions for cygwin-x86 host - cygwin-x86 target builds
=== modified file 'configure/os/CONFIG_SITE.darwin-ppc.Common'
--- configure/os/CONFIG_SITE.darwin-ppc.Common 2009-05-06 17:25:01 +0000
+++ configure/os/CONFIG_SITE.darwin-ppc.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.darwin-ppc.Common
-# $Id$
+# $Revision-Id$
# Site override definitions for darwin-ppc host builds
=== modified file 'configure/os/CONFIG_SITE.darwin-ppcx86.Common'
--- configure/os/CONFIG_SITE.darwin-ppcx86.Common 2009-05-06 17:25:01 +0000
+++ configure/os/CONFIG_SITE.darwin-ppcx86.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.darwin-ppcx86.Common
-# $Id$
+# $Revision-Id$
# Site override definitions for darwin-ppcx86 host builds
=== modified file 'configure/os/CONFIG_SITE.darwin-x86.Common'
--- configure/os/CONFIG_SITE.darwin-x86.Common 2010-09-22 21:26:15 +0000
+++ configure/os/CONFIG_SITE.darwin-x86.Common 2010-10-06 18:12:40 +0000
@@ -2,7 +2,7 @@
-# $Id$
+# $Revision-Id$
# Site override definitions for darwin-x86 host builds
=== modified file 'configure/os/CONFIG_SITE.linux-x86-borland.Common'
--- configure/os/CONFIG_SITE.linux-x86-borland.Common 2003-07-25 19:43:41 +0000
+++ configure/os/CONFIG_SITE.linux-x86-borland.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.linux-x86-borland.Common
-# $Id$
+# $Revision-Id$
# Site override definitions for linux-x86-borland host builds
=== modified file 'configure/os/CONFIG_SITE.linux-x86.Common'
--- configure/os/CONFIG_SITE.linux-x86.Common 2009-01-23 20:24:59 +0000
+++ configure/os/CONFIG_SITE.linux-x86.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.linux-x86.Common
-# $Id$
+# $Revision-Id$
# Site override definitions for linux-x86 host builds
=== modified file 'configure/os/CONFIG_SITE.linux-x86.UnixCommon'
--- configure/os/CONFIG_SITE.linux-x86.UnixCommon 2005-02-25 16:02:57 +0000
+++ configure/os/CONFIG_SITE.linux-x86.UnixCommon 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
# Site Specific Configuration Information
=== modified file 'configure/os/CONFIG_SITE.linux-x86.linux-arm'
--- configure/os/CONFIG_SITE.linux-x86.linux-arm 2006-12-08 23:27:18 +0000
+++ configure/os/CONFIG_SITE.linux-x86.linux-arm 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.linux-x86.linux-arm
-# $Id$
+# $Revision-Id$
# Site specific definitions for linux-x86 host - linux-arm target builds
=== modified file 'configure/os/CONFIG_SITE.linux-x86.linux-arm_eb'
--- configure/os/CONFIG_SITE.linux-x86.linux-arm_eb 2007-12-11 15:28:17 +0000
+++ configure/os/CONFIG_SITE.linux-x86.linux-arm_eb 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.linux-x86.linux-arm_eb
-# $Id$
+# $Revision-Id$
# Site specific definitions for linux-x86 host - linux-arm_eb target builds
=== modified file 'configure/os/CONFIG_SITE.linux-x86.linux-arm_el'
--- configure/os/CONFIG_SITE.linux-x86.linux-arm_el 2007-12-11 15:17:33 +0000
+++ configure/os/CONFIG_SITE.linux-x86.linux-arm_el 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.linux-x86.linux-arm_el
-# $Id$
+# $Revision-Id$
# Site specific definitions for linux-x86 host - linux-arm_el target builds
=== modified file 'configure/os/CONFIG_SITE.linux-x86.linux-x86'
--- configure/os/CONFIG_SITE.linux-x86.linux-x86 2009-01-23 20:24:59 +0000
+++ configure/os/CONFIG_SITE.linux-x86.linux-x86 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.linux-x86.linux-x86
-# $Id$
+# $Revision-Id$
# Site specific definitions for linux-x86 host - linux-x86 target builds
=== modified file 'configure/os/CONFIG_SITE.linux-x86.solaris-sparc'
--- configure/os/CONFIG_SITE.linux-x86.solaris-sparc 2002-02-07 21:54:52 +0000
+++ configure/os/CONFIG_SITE.linux-x86.solaris-sparc 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.linux-x86.solaris-sparc
-# $Id$
+# $Revision-Id$
# Site specific definitions for linux-x86 host - solaris-sparc target builds
=== modified file 'configure/os/CONFIG_SITE.linux-x86.vxWorks-68040'
--- configure/os/CONFIG_SITE.linux-x86.vxWorks-68040 2008-10-09 21:33:35 +0000
+++ configure/os/CONFIG_SITE.linux-x86.vxWorks-68040 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.linux-x86.vxWorks-68040
-# $Id$
+# $Revision-Id$
# Site specific definitions for linux-x86 host - vxWorks-68040 target builds
=== modified file 'configure/os/CONFIG_SITE.linux-x86.vxWorks-ppc603'
--- configure/os/CONFIG_SITE.linux-x86.vxWorks-ppc603 2006-12-09 00:01:57 +0000
+++ configure/os/CONFIG_SITE.linux-x86.vxWorks-ppc603 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
# Site-specific definitions for linux-x86 builds of vxWorks-ppc603
=== modified file 'configure/os/CONFIG_SITE.linux-x86.vxWorks-ppc603_long'
--- configure/os/CONFIG_SITE.linux-x86.vxWorks-ppc603_long 2006-12-09 00:01:57 +0000
+++ configure/os/CONFIG_SITE.linux-x86.vxWorks-ppc603_long 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
# Site-specific definitions for linux-x86 builds of vxWorks-ppc603_long
=== modified file 'configure/os/CONFIG_SITE.linux-x86.vxWorksCommon'
--- configure/os/CONFIG_SITE.linux-x86.vxWorksCommon 2008-10-09 21:33:35 +0000
+++ configure/os/CONFIG_SITE.linux-x86.vxWorksCommon 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.linux-x86.vxWorksCommon
-# $Id$
+# $Revision-Id$
# Definitions for linux-x86 host - vxWorks target builds
=== modified file 'configure/os/CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug'
--- configure/os/CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug 2005-10-28 15:31:46 +0000
+++ configure/os/CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug
-# $Id$
+# $Revision-Id$
# Site specific override definitions for solaris-sparc host builds
=== modified file 'configure/os/CONFIG_SITE.linux-x86_64.Common'
--- configure/os/CONFIG_SITE.linux-x86_64.Common 2005-10-28 15:31:46 +0000
+++ configure/os/CONFIG_SITE.linux-x86_64.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.linux-x86_64.Common
-# $Id$
+# $Revision-Id$
# Site override definitions for linux-x86_64 host builds
=== modified file 'configure/os/CONFIG_SITE.linux-x86_64.UnixCommon'
--- configure/os/CONFIG_SITE.linux-x86_64.UnixCommon 2007-12-12 20:01:03 +0000
+++ configure/os/CONFIG_SITE.linux-x86_64.UnixCommon 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.linux-x86_64.UnixCommon
-# $Id$
+# $Revision-Id$
# Site Specific configure override definitions
=== modified file 'configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64'
--- configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64 2007-12-11 20:23:00 +0000
+++ configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.linux-x86_64.linux-x86_64
-# $Id$
+# $Revision-Id$
# Site specific definitions for linux-x86_64 host - linux-x86_64 target builds
=== modified file 'configure/os/CONFIG_SITE.linux-x86_64.vxWorks-68040'
--- configure/os/CONFIG_SITE.linux-x86_64.vxWorks-68040 2008-10-09 21:33:35 +0000
+++ configure/os/CONFIG_SITE.linux-x86_64.vxWorks-68040 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.linux-x86_64.vxWorks-68040
-# $Id$
+# $Revision-Id$
# Site specific definitions for linux-x86_64 host - vxWorks-68040 target builds
=== modified file 'configure/os/CONFIG_SITE.linux-x86_64.vxWorks-ppc603'
--- configure/os/CONFIG_SITE.linux-x86_64.vxWorks-ppc603 2006-12-09 00:01:57 +0000
+++ configure/os/CONFIG_SITE.linux-x86_64.vxWorks-ppc603 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
# Site-specific definitions for linux-x86_64 builds of vxWorks-ppc603
=== modified file 'configure/os/CONFIG_SITE.linux-x86_64.vxWorks-ppc603_long'
--- configure/os/CONFIG_SITE.linux-x86_64.vxWorks-ppc603_long 2006-12-09 00:01:57 +0000
+++ configure/os/CONFIG_SITE.linux-x86_64.vxWorks-ppc603_long 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
=== modified file 'configure/os/CONFIG_SITE.solaris-sparc.Common'
--- configure/os/CONFIG_SITE.solaris-sparc.Common 2009-01-23 20:24:59 +0000
+++ configure/os/CONFIG_SITE.solaris-sparc.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.solaris-sparc.Common
-# $Id$
+# $Revision-Id$
=== modified file 'configure/os/CONFIG_SITE.win32-x86-borland.Common'
--- configure/os/CONFIG_SITE.win32-x86-borland.Common 2001-08-23 18:59:12 +0000
+++ configure/os/CONFIG_SITE.win32-x86-borland.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.win32-x86-borland.Common
-# $Id$
+# $Revision-Id$
# Site specific definitions for win32-x86-borland host
=== modified file 'configure/os/CONFIG_SITE.win32-x86-mingw.Common'
--- configure/os/CONFIG_SITE.win32-x86-mingw.Common 2008-12-01 16:35:40 +0000
+++ configure/os/CONFIG_SITE.win32-x86-mingw.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.win32-x86-mingw.Common
-# $Id$
+# $Revision-Id$
=== modified file 'configure/os/CONFIG_SITE.win32-x86.Common'
--- configure/os/CONFIG_SITE.win32-x86.Common 2002-10-04 15:00:52 +0000
+++ configure/os/CONFIG_SITE.win32-x86.Common 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
# CONFIG_SITE.win32-x86.Common
-# $Id$
+# $Revision-Id$
# Site specific definitions for win32-x86 host
=== modified file 'configure/os/CONFIG_SITE.win32-x86.win32-x86'
--- configure/os/CONFIG_SITE.win32-x86.win32-x86 2010-07-09 20:38:16 +0000
+++ configure/os/CONFIG_SITE.win32-x86.win32-x86 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
# If you have Visual C++ 6.0, uncomment the following override lines
# This will to eliminate warnings about unknown options /GL, /LTCG, and /w44355.
=== modified file 'documentation/BuildingR3.13AppsWithR3.14.html'
--- documentation/BuildingR3.13AppsWithR3.14.html 2004-05-17 14:25:00 +0000
+++ documentation/BuildingR3.13AppsWithR3.14.html 2010-10-06 18:12:40 +0000
@@ -15,7 +15,7 @@
<p><br>
This document describes how to modify a R3.13 vxWorks application so that it
-builds with release R3.14. It describes an easy way to modify
+builds with release R3.14. It describes an easy way to modify
applications subject to the following restrictions:</p>
<ul>
<li>The application still uses config rules rather than the configure rules
@@ -42,7 +42,7 @@
<h3>Update RELEASE</h3>
-<p>Change the <tt>EPICS_BASE</tt> definition to point to the R3.14 base
+<p>Change the <tt>EPICS_BASE</tt> definition to point to the R3.14 base
release. All hardware support and some soft support is now unbundled. For
example the sequencer is unbundled. You must obtain and build all required
unbundled products before you can build the application. The location of each
@@ -141,7 +141,7 @@
<h3>recGbl calls</h3>
-<p>You may need to add the line "<tt>#include "recGbl.h</tt>" to any source
+<p>You may need to add the line "<tt>#include "recGbl.h</tt>" to any source
files that have recGbl* calls so that the file will compile without
errors.</p>
@@ -164,9 +164,9 @@
to your application src/Makefile.
<p>You should consider changing any existing old steppermotor records to the
-new EPICS <a
+new EPICS <a
href="http://www.aps.anl.gov/upd/people/sluiter/epics/modules/mechanism/motor/index.html">motor
-record</a> module supported by Beamline Controls and Data Acquisition at
+record</a> module supported by Beamline Controls and Data Acquisition at
APS.</p>
<h3>RecDynLink.o and devPtSoft changes</h3>
@@ -178,14 +178,14 @@
<p>All hardware support (dev, drv and dbd files) has been unbundled from base
R3.14. This support includes the files <tt>symb, symb.dbd, drvHp1404a.o,
-drvEpvxiMsg.o, and drvEpvxi.o</tt>. If they are not used in your
+drvEpvxiMsg.o, and drvEpvxi.o</tt>. If they are not used in your
application, comment out references to these files in base.dbd and
baseLIBOBJS.</p>
<p>Hardware support files now exist as separate modules available for
download from the <a href="http://www.aps.anl.gov/epics/">EPICS www home page
at ANL</a>. You must now download all the hardware support modules needed for
-your application, build the modules with R3.14 base, add the appropriate
+your application, build the modules with R3.14 base, add the appropriate
module full path definitions to your application config/RELEASE file, and
change <tt>LIBOBJS</tt> location definition <tt>$(EPICS_BASE_BIN)</tt> to the
module definition bin directory in your application src directory files.</p>
@@ -201,9 +201,9 @@
<p>After a gnumake in the symb module followed by a gnumake in the
application config directory, the definitions <tt>SYMB_BIN</tt> and
-<tt>SYMB_LIB</tt> will be created, the directory $(SYMB)/include will be
-added to the include directories on the compiler command lines (in the
-<tt>INSTALL_INCLUDES</tt> definition) and the directory $(SYMB)/dbd will be
+<tt>SYMB_LIB</tt> will be created, the directory $(SYMB)/include will be
+added to the include directories on the compiler command lines (in the
+<tt>INSTALL_INCLUDES</tt> definition) and the directory $(SYMB)/dbd will be
added to the dbd search directories on the dbExpand command lines (in the
<tt>INSTALL_DBDFLAGS</tt> definition).</p>
=== modified file 'documentation/BuildingR3.13ExtensionsWithR3.14.html'
--- documentation/BuildingR3.13ExtensionsWithR3.14.html 2008-04-22 15:09:48 +0000
+++ documentation/BuildingR3.13ExtensionsWithR3.14.html 2010-10-06 18:12:40 +0000
@@ -34,7 +34,7 @@
<blockquote>
<ul>
<li>Download the latest version of the extensions/config files,
- extensionsConfig.tar.gz, from the APS EPICS www page.</li>
+ extensionsConfig.tar.gz, from the APS EPICS www page.</li>
The extensions directory can have both the base/config (for extensions with
R3.13 makefiles) and base/configure (for extensions with R3.14 makefiles)
directories.
@@ -43,7 +43,7 @@
variable.</li>
<li>Set EPICS_BASE in extensions/config/RELEASE to the full path location
of a built R3.14 base.</li>
- <li>BASE_3_14 is now defined in the base/config/CONFIG_BASE_VERSION. The
+ <li>BASE_3_14 is now defined in the base/config/CONFIG_BASE_VERSION. The
commented BASE_3_14 definition can be removed from
extensions/config/RELEASE.</li>
</ul>
@@ -77,82 +77,80 @@
removing Db), the following lines should be added to Makefile.Host.</p>
<blockquote>
- <tt>ifdef BASE_3_14</tt> <br>
- <tt>USR_LIBS += dbStaticHost</tt> <br>
- <tt>dbStaticHost_DIR = $(EPICS_BASE_LIB)</tt> <br>
- <tt>else</tt> <br>
- <tt>USR_LIBS += Db</tt> <br>
- <tt>Db_DIR = $(EPICS_BASE_LIB)</tt> <br>
- <tt>endif</tt></blockquote>
+ <pre>ifdef BASE_3_14
+USR_LIBS += dbStaticHost
+dbStaticHost_DIR = $(EPICS_BASE_LIB)
+else
+USR_LIBS += Db
+Db_DIR = $(EPICS_BASE_LIB)
+endif</pre></blockquote>
<li><b>Library dbStaticHost names changed</b></li>
- <p>Library functions have been renamed. If there are calls with old db
+ <p>Library functions have been renamed. If there are calls with old db
names, add the following lines</p>
<blockquote>
- <tt>#if EPICS_REVISION && EPICS_REVISION == 13</tt> <br>
- <tt>#define dbFindRecordType dbFindRecdes</tt> <br>
- <tt>#define dbGetNRecordTypes dbGetNRecdes</tt> <br>
- <tt>#define dbNextRecordType dbNextRecdes</tt> <br>
- <tt>#define dbFirstField dbFirstFielddes</tt> <br>
- <tt>#define dbGetRecordTypeName dbGetRecdesName</tt> <br>
- <tt>#define dbFirstRecordType dbFirstRecdes</tt> <br>
- <tt>#define dbNextField dbNextFielddes</tt> <br>
- <tt>#define dbGetMenuChoices dbGetChoices</tt><tt></tt>
+ <pre>#if EPICS_REVISION && EPICS_REVISION == 13
+#define dbFindRecordType dbFindRecdes
+#define dbGetNRecordTypes dbGetNRecdes
+#define dbNextRecordType dbNextRecdes
+#define dbFirstField dbFirstFielddes
+#define dbGetRecordTypeName dbGetRecdesName
+#define dbFirstRecordType dbFirstRecdes
+#define dbNextField dbNextFielddes
+#define dbGetMenuChoices dbGetChoices
- <p><tt>long dbReadDatabaseFP(</tt> <br>
- <tt> DBBASE **ppdbbase,FILE *fp, const char *path,const char
- *substitutions)</tt> <br>
- <tt>{</tt> <br>
- <tt> return(dbRead(*ppdbbase,fp));</tt> <br>
- <tt>}</tt> <br>
- <tt>#endif</tt></p>
- </blockquote>
- and change the the old names and function calls to the R3.14 versions:
+long dbReadDatabaseFP(DBBASE **ppdbbase,
+ FILE *fp, const char *path,const char *substitutions)
+ return(dbRead(*ppdbbase,fp));
+#endif
+</pre></blockquote>
+ and change the the old names and function calls to the R3.14 versions:
<blockquote>
- <tt>dbFindRecdes => dbFindRecordType</tt> <br>
- <tt>dbGetNRecdes => dbGetNRecordTypes</tt> <br>
- <tt>dbNextRecdes => dbNextRecordType</tt> <br>
- <tt>dbFirstFielddes => dbFirstField</tt> <br>
- <tt>dbGetRecdesName => dbGetRecordTypeName</tt> <br>
- <tt>dbFirstRecdes => dbFirstRecordType</tt> <br>
- <tt>dbNextFielddes => dbNextField</tt> <br>
- <tt>dbGetChoices => dbGetMenuChoices</tt> <br>
- <tt>dbRead(pdbbase,fp) => dbReadDatabaseFP(&pdbbase,fp,0,0)</tt>
- <p></p>
- </blockquote>
+ <pre>dbFindRecdes => dbFindRecordType
+dbGetNRecdes => dbGetNRecordTypes
+dbNextRecdes => dbNextRecordType
+dbFirstFielddes => dbFirstField
+dbGetRecdesName => dbGetRecordTypeName
+dbFirstRecdes => dbFirstRecordType
+dbNextFielddes => dbNextField
+dbGetChoices => dbGetMenuChoices
+dbRead(pdbbase,fp) => dbReadDatabaseFP(&pdbbase,fp,0,0)
<li><b>Target architecture specifications changed</b></li>
<p>Since target architecture specifications have been changed (solaris to
solaris-sparc, win32 to win32-x86, ...) Makefile.Host references to and
- tests on T_A have to be changed. In most cases T_A can be replaced by
- OS_CLASS. Since HOST_ARCH will eventually be phased out, it would be a
+ tests on T_A have to be changed. In most cases T_A can be replaced by
+ OS_CLASS. Since HOST_ARCH will eventually be phased out, it would be a
good idea to change any Makefile.Host references to HOST_ARCH to OS_CLASS
if possible. <br>
For example change</p>
<blockquote>
- <tt>ifeq ($(T_A),solaris)</tt> <br>
- <tt>RPCFLAGS = -K -1</tt> <br>
+ <pre>ifeq ($(T_A),solaris)
+RPCFLAGS = -K -1
+endif
to
<blockquote>
- <tt>ifeq ($(OS_CLASS),solaris)</tt> <br>
+ <pre>ifeq ($(OS_CLASS),solaris)
+RPCFLAGS = -K -1
+endif
<li><b>New ca_set_puser</b></li>
<p>Statements of the form: <tt>ca_puser(chid) = xyz</tt>; should to be
- changed to: <tt>ca_set_puser(chid,xyz)</tt>; <br>
- </p>
+ changed to: <tt>ca_set_puser(chid,xyz)</tt>; <br>
+ </p>
<li><b>Extern C around includes</b></li>
@@ -162,9 +160,10 @@
<blockquote>
- <tt>extern "C" {</tt> <br>
- <tt>#include "cadefs.h"</tt> <br>
- <tt>} /* end extern C */</tt></blockquote>
+ <pre>extern "C" {
+#include "cadefs.h"
+} /* end extern C */
to
<blockquote>
@@ -174,8 +173,8 @@
<p>Some infrequently used R3.13 timestamp functions and macro definitions
have been removed from EPICS base and now exist in a library, ts, created
- and installed in the ar extension. The only ANL distributed extension that
- uses these unbundled functions and macros is cau. The two R3.13 functions
+ and installed in the ar extension. The only ANL distributed extension that
+ uses these unbundled functions and macros is cau. The two R3.13 functions
tsStampToText and tsLocalTime along with the definitions TS_TEXT_MONDDYYYY
and TS_TEXT_MMDDYY have been retained in R3.14 for extension compatibility
purposes. <br>
@@ -185,27 +184,28 @@
PROD_LIBS or USR_LIBS in your Makefile.Host as follows:</p>
<blockquote>
- <tt>#include "tsSubr.h"</tt>
+ <pre>#include "tsSubr.h"
- <p><tt>ifdef BASE_3_14</tt> <br>
- <tt>PROD_LIBS += ts</tt> <br>
- <tt>ts_DIR = $(EPICS_EXTENSIONS_LIB)</tt> <br>
- <tt>endif</tt></p>
- </blockquote>
+ifdef BASE_3_14
+PROD_LIBS += ts
+ts_DIR = $(EPICS_EXTENSIONS_LIB)
+endif
<li><b>No Field name length restriction</b></li>
<p> The length restriction to database record names no longer exists in R3.14
- so the the <tt>FLDNAME_SZ macro definition was removed.from dbDefs.h.
+ so the the <tt>FLDNAME_SZ macro definition was removed.from dbDefs.h.
Extensions which still have a field name restriction should add the field
name size definition to their code until they are updated.</tt></p>
<blockquote>
- <tt>#ifndef FLDNAME_SZ</tt> <br>
- <tt>#define FLDNAME_SZ 4 /*Field Name Size*/</tt> <br>
- <tt>#endif</tt></blockquote>
+ <pre>#ifndef FLDNAME_SZ
+#define FLDNAME_SZ 4 /*Field Name Size*/
+#endif
- <li><b>Some EPICS base version macros removed</b></li>
+ <li><b>Some EPICS base version macros removed</b></li>
<p>
The EPICS base version macros that start with "BASE_" have been removed
@@ -214,24 +214,14 @@
</blockquote>
<blockquote>
<blockquote>
- <tt></tt><font face="Arial,Helvetica">BASE_VERSION
- => EPICS_VERSION</font> <br>
- <font face="Arial,Helvetica">BASE_REVISION =>
- EPICS_REVISION</font> <br>
- <font face="Arial,Helvetica">BASE_MODIFICATION => </font><font
- face="Arial,Helvetica"> EPICS_MODIFICATION</font> <br>
- <font face="Arial,Helvetica">BASE_UPDATE_NAME =>
- EPICS_UPDATE_NAME</font> <br>
- <font face="Arial,Helvetica">BASE_UPDATE_LEVEL =>
- EPICS_UPDATE_LEVEL</font> <br>
- <font face="Arial,Helvetica">BASE_VERSION_STRING =>
- EPICS_VERSION_STRING</font></blockquote>
+ BASE_VERSION => EPICS_VERSION
+ BASE_REVISION => EPICS_REVISION
+ BASE_MODIFICATION => EPICS_MODIFICATION
+ BASE_UPDATE_NAME => EPICS_UPDATE_NAME
+ BASE_UPDATE_LEVEL => EPICS_UPDATE_LEVEL
+ BASE_VERSION_STRING => EPICS_VERSION_STRING
+ </blockquote>
</blockquote>
-<p></p>
-<p></p>
</body>
</html>
=== modified file 'documentation/ConvertingR3.14.5AppsToR3.14.6.html'
--- documentation/ConvertingR3.14.5AppsToR3.14.6.html 2005-11-21 22:19:51 +0000
+++ documentation/ConvertingR3.14.5AppsToR3.14.6.html 2010-10-06 18:12:40 +0000
@@ -86,27 +86,27 @@
<h3>Record support changes</h3>
-<p>The steppermotor, scan, and pid records are no longer in base. If these
+<p>The steppermotor, scan, and pid records are no longer in base. If these
records are not used in your application, comment out references to them in
-base.dbd. If these record types are used at your site, they should be
+base.dbd. If these record types are used at your site, they should be
downloaded and built with base R3.14 by your EPICS administrator. To update
-the R3.14 location of these record types in your application you must add
+the R3.14 location of these record types in your application you must add
appropriate module definitions to your application's config/RELEASE file and
add <tt>LIBOBJS</tt> definitions to the src Makefile.</p>
<p>For example add</p>
-<p> <tt>PID=<full path to modules directory>/pid</tt></p>
+<pre> PID=<full path to modules directory>/pid
+</pre>
<p>to config/RELEASE and add <br>
-<p></p>
-<p><tt>LIBOBJS += $(PID_BIN)/pidRecord.o</tt></p>
+<pre> LIBOBJS += $(PID_BIN)/pidRecord.o
+</pre>
-new EPICS motor record module supported by Beamline Controls and Data
+new EPICS motor record module supported by Beamline Controls and Data
Acquisition at APS.</p>
@@ -115,7 +115,7 @@
separate EPICS modules.You must now add the appropriate module full path
definitions to your application config/RELEASE file, and change
<tt>LIBOBJS</tt> location definition <tt>$(EPICS_BASE_BIN)</tt> to the module
-definition bin directory in your application src directory files. See
+definition bin directory in your application src directory files. See
"Hardware support changes" below for instructions.</p>
<h3>Hardware support changes</h3>
@@ -129,21 +129,24 @@
support for your site should be downloaded and built with base R3.14 by your
EPICS administrator. You must now add the appropriate module full path
-<tt>LIBOBJS</tt> location from <tt>$(EPICS_BASE_BIN) </tt>to the module bin
+<tt>LIBOBJS</tt> location from <tt>$(EPICS_BASE_BIN) </tt>to the module bin
<p>For example, remove</p>
-<p> <tt>LIBOBJS+=$(EPICS_BASE_BIN)/symb</tt></p>
+<pre> LIBOBJS+=$(EPICS_BASE_BIN)/symb
+</pre>
<p>from baseLIBOBJS and add</p>
-<p> <tt>LIBOBJS+=$(SYMB_BIN)/symb</tt></p>
+<pre> LIBOBJS+=$(SYMB_BIN)/symb
+</pre>
<p>to your application src/Makefile, <br>
and add the line</p>
-<p><tt>SYMB=<full path definition for the built module SYMB></tt></p>
+<pre> SYMB=<full path definition for the built module SYMB>
+</pre>
<p>into your application config/RELEASE file .</p>
@@ -151,13 +154,12 @@
<p>The host tool dbLoadTemplate has been replace by a new EPICS extension,
msi, which should be downloaded and built with base R3.14 by your EPICS
-administrator. dbLoadTemplate is still supported on iocs. If, in your
+administrator. dbLoadTemplate is still supported on iocs. If, in your
application, db files are created from template and substitution files you
-should add the definition</p>
+should add the definition</p>
<p><tt>MSI=<full path name to msi executable></tt></p>
<p>to your application config/RELEASE file.</p>
-<br>
- </body>
+</body>
</html>
=== modified file 'documentation/ReleaseChecklist.html'
--- documentation/ReleaseChecklist.html 2009-09-22 14:55:27 +0000
+++ documentation/ReleaseChecklist.html 2010-10-06 18:12:40 +0000
@@ -33,7 +33,9 @@
<h1>EPICS Base Release Procedures & Checklist</h1>
<blockquote>
- <p>$Id$</p>
+ <p>$Date$<br />
+ $Authors$<br />
+ $Revision-Id$</p>
</blockquote>
<p>This document describes the procedures and provides a checklist of tasks
@@ -42,7 +44,7 @@
<h3>The Release Process</h3>
<p>The version released on the Feature Freeze date is designated the first
-pre-release, <tt>-pre1</tt>. The first Release Candidate <tt>-RC1</tt> is the
+pre-release, <tt>-pre1</tt>. The first Release Candidate <tt>-rc1</tt> is the
first version that has undergone widespread testing and which has no known
problems in it that are slated to be fixed in this release. New versions should
be made at about weekly intervals during the testing and debugging period, and
@@ -61,7 +63,7 @@
<dt><strong>Release Manager</strong> (Andrew Johnson)</dt>
<dd>Responsible for the release</dd>
<dt><strong>Configuration Manager</strong> (Janet Anderson)</dt>
- <dd>Responsible for committing version number updates to CVS and for
+ <dd>Responsible for committing version number updates and for
creating tarfiles</dd>
<dt><strong>Platform Developers</strong></dt>
<dd>Responsible for individual operating system platforms</dd>
@@ -77,33 +79,33 @@
<th>Check</th>
<th>Who</th>
<th>Description</th>
- </tr>
+ </tr>
<tr>
<th colspan="3">Preparing for a release</th>
- </tr>
+ </tr>
<tr>
- <td> </td>
+ <td> </td>
<td>Release Manager</td>
<td>Email all developers about the upcoming release and ask for a list
of remaining jobs that must be finished.</td>
- </tr>
+ </tr>
<tr>
- <td> </td>
+ <td> </td>
<td>All developers</td>
- <td>Check the Mantis bug tracker for any outstanding items and handle
+ <td>Check the bug tracker for any outstanding items and handle
appropriately. All bugs that have been fixed should have been marked
- as resolved.</td>
- </tr>
+ as Fix Committed.</td>
+ </tr>
<tr>
- <td> </td>
+ <td> </td>
- <td>Set the Feature Freeze date, by which time all CVS commits for
+ <td>Set the Feature Freeze date, by which time all Bazaar commits for
enhancements and new functionality should have been completed. After
this date, commits should only be made to fix problems that show up
during testing.</td>
- </tr>
+ </tr>
<tr>
- <td> </td>
+ <td> </td>
<td>Release Manager<br />
& all developers</td>
<td>Ensure that documentation will be updated before the release date:
@@ -114,218 +116,267 @@
<li>Other documents</li>
</ul>
</td>
- </tr>
- <tr>
- <th colspan="3">Creating pre-release and Release Candidate versions</th>
- </tr>
- <tr>
- <td> </td>
+ </tr>
+ <tr>
+ <td> </td>
+ <td>Release Manager</td>
+ <td>Review and update this document for the upcoming release.</td>
+ </tr>
+ <tr>
+ <td> </td>
+ <td>Website Manager</td>
+ <td>Create a release milestone on Launchpad if necessary and set the
+ expected release date. Note that pre-release and release-candidate
+ versions do not appear on Launchpad, only the final release.</td>
+ </tr>
+ <tr>
+ <th colspan="3">Creating pre-release and release-candidate versions</th>
+ </tr>
+ <tr>
+ <td> </td>
<td>Configuration Manager</td>
<td>Edit and commit changes to the EPICS version number file
configure/CONFIG_BASE_VERSION.</td>
- </tr>
- <tr>
- <td> </td>
- <td>Configuration Manager</td>
- <td>Tag the module in CVS. Pre-release version tags take the form
- <tt>R<i>x</i>-<i>y</i>-<i>z</i>-pre<i>n</i></tt> while Release
- Candidate tags take the form
- <tt>R<i>x</i>-<i>y</i>-<i>z</i>-RC<i>m</i></tt>.
- </td>
- </tr>
- <tr>
- <td> </td>
- <td>Export the tagged version and create a tarfile of the result:
- <blockquote><tt>
- cvs export -kv -d base-x.y.z-pre1 -r Rx-y-z-pre1 epics/base<br />
- tar cfz baseRx.y.z-pre1.tar.gz base-x.y.z-pre1
- </tt></blockquote></td>
- </tr>
- <tr>
- <td> </td>
+ </tr>
+ <tr>
+ <td> </td>
+ <td>Configuration Manager</td>
+ <td>Tag the module in Bazaar, using these tag conventions:
+ <ul>
+ <li>
+ <tt>R3.14.12-pre<i>n</i></tt>
+ — pre-release tag
+ </li>
+ <li>
+ <tt>R3.14.12-rc<i>n</i></tt>
+ — release candidate tag, note the <tt>rc</tt> is now
+ lower-case</li>
+ </ul>
+ <blockquote><tt>
+ cd ~/base/mirror-3.14<br />
+ bzr tag R3.14.12-rc<i>n</i>
+ </tt></blockquote>
+ </td>
+ </tr>
+ <tr>
+ <td> </td>
+ <td>Export the tagged version into a tarfile. Note that this command
+ generates a gzipped tarfile directly from the repository:
+ <blockquote><tt>
+ cd ~/base<br />
+ bzr export --keywords=publish
+ --root=base-3.14.12-rc<i>n</i>
+ -r tag:R3.14.12-rc<i>n</i>
+ baseR3.14.12-rc<i>n</i>.tar.gz
+ mirror-3.14
+ This requires that the Bazaar keywords plugin is installed and
+ configured properly.
+ </td>
+ </tr>
+ <tr>
+ <td> </td>
<td>Test the tarfile by extracting its contents and building it on at
- least one supported platform</td>
- </tr>
+ least one supported platform.</td>
+ </tr>
<tr>
- <td> </td>
+ <td> </td>
- <td>Copy the tar file to the Base download area of the website</td>
- </tr>
+ <td>Copy the tar file to the Base download area of the website.</td>
+ </tr>
<tr>
- <td> </td>
+ <td> </td>
<td>Create or update a website subdirectory to hold the release
- documentation, and copy in the files from the base/documentation
- directory of the tarfile.</td>
- </tr>
+ documentation, and copy in selected files from the base/documentation
+ and base/html directories of the tarfile.</td>
+ </tr>
<tr>
- <td> </td>
+ <td> </td>
<td>Create or modify the webpage for the new release with links to the
- release documents and tar file. Pre-release and RC versions should use
- the page and URL for the final release version number.</td>
- </tr>
+ release documents and tar file. Pre-release and release-candidate
+ versions should use the page and URL for the final release version
+ number.</td>
+ </tr>
<tr>
- <td> </td>
+ <td> </td>
- <td>Add the new pre-release tar file to the website Base download index
- page.</td>
- </tr>
+ <td>Add the new tar file to the website Base download index page.</td>
+ </tr>
<tr>
<th colspan="3">Testing</th>
- </tr>
+ </tr>
<tr>
- <td> </td>
+ <td> </td>
<td>Platform Developers</td>
<td>Run the built-in test programs on all available host platforms using
<blockquote><tt>
make -s runtests
- </tr>
+ </tr>
<tr>
- <td> </td>
+ <td> </td>
<td>Run the CA client side regression tests on all available host
platforms.</td>
- </tr>
+ </tr>
<tr>
- <td> </td>
+ <td> </td>
<td>Build and run the
- <a href="https://svn.aps.anl.gov/trac/epics/soft-test">IOC Soft-Test</a>
+ <a href="https://launchpad.net/epics-base-tests">epics-base-tests</a>
suite on all available platforms.</td>
- </tr>
+ </tr>
<tr>
- <td> </td>
+ <td> </td>
<td>Check that all makeBaseApp templates build and run properly, all
- xxxApp and xxxBoot types and any internal options, e.g. setting
- <tt>STATIC_BUILD=YES</tt> or using a different <tt>INSTALL_LOCATION</tt>
- in configure/CONFIG_SITE.</td>
- </tr>
+ <i>xxxApp</i> and <i>xxxBoot</i> types and any internal options, e.g.
+ setting <tt>STATIC_BUILD=YES</tt> or using a different
+ <tt>INSTALL_LOCATION</tt> in configure/CONFIG_SITE.</td>
+ </tr>
<tr>
- <td> </td>
+ <td> </td>
<td>Build the SNL Sequencer against this version of Base, and check that
the makeBaseApp example builds and runs correctly with it.</td>
- </tr>
+ </tr>
<tr>
- <td> </td>
+ <td> </td>
<td>Application Developers</td>
<td>Build external applications against this version of Base on all
available platforms and test as appropriate. Application code changes
may be necessary where the EPICS Base APIs have been modified.</td>
- </tr>
+ </tr>
<tr>
- <td> </td>
+ <td> </td>
<td>Check that documentation has been updated:
<ul>
- <li>Application Developers Guide</li>
+ <li><a href="https://launchpad.net/epics-appdev">Application
+ Developers Guide</a></li>
<li>Release Notes</li>
<li>Known Problems (hopefully empty)</li>
<li>Other documents (converting...)</li>
- </ul>
- </td>
- </tr>
+ </ul>
+ </td>
+ </tr>
<tr>
<th colspan="3">Release Approval</th>
</tr>
<tr>
- <td> </td>
+ <td> </td>
<td>Obtain a positive <q>Ok to release</q> from all platform developers
- when a Release Candidate version has gone a whole week without any
+ once a Release Candidate version has gone a whole week without any
issues being reported.</td>
- </tr>
+ </tr>
<tr>
<th colspan="3">Creating the final release version</th>
- </tr>
+ </tr>
<tr>
- <td> </td>
+ <td> </td>
- </tr>
- <tr>
- <td> </td>
- <td>Tag the module in CVS. Official base release version tags take the
- form <tt>R<i>x</i>-<i>y</i>-<i>z</i>[-<i>n</i>]</tt></td>
- </tr>
- <tr>
- <td> </td>
- <blockquote><tt>
- cvs export -kv -d base-x.y.z -r Rx-y-z epics/base<br />
- tar cfz baseRx.y.z.tar.gz base-x.y.z
- </tr>
- <tr>
- <td> </td>
+ </tr>
+ <tr>
+ <td> </td>
+ <td>Tag the module in Bazaar:
+ <blockquote><tt>
+ bzr tag R3.14.12</i>
+ </td>
+ </tr>
+ <tr>
+ <td> </td>
+ <blockquote><tt>
+ cd ~/base<br />
+ -r tag:R3.14.12
+ baseR3.14.12.tar.gz
+ mirror-3.14
+ </td>
+ </tr>
+ <tr>
+ <td> </td>
<td>Test the tar file by extracting its contents and building it on at
- </tr>
- <tr>
- <td> </td>
+ </tr>
+ <tr>
+ <th colspan="3">Publish and Announce it</th>
+ </tr>
+ <tr>
+ <td> </td>
- </tr>
+ </tr>
<tr>
- <td> </td>
+ <td> </td>
<td>Update the website subdirectory that holds the release
- </tr>
+ </tr>
<tr>
- <td> </td>
+ <td> </td>
<td>Update the webpage for the new release with links to the release
documents and tar file.</td>
- </tr>
- <tr>
- <th colspan="3">Announce it</th>
- </tr>
- <tr>
- <td> </td>
+ </tr>
+ <tr>
+ <td> </td>
<td>Add the new release tar file to the website Base download index
page.</td>
- </tr>
+ </tr>
<tr>
- <td> </td>
+ <td> </td>
<td>Link to the release webpage from other relevent areas of the
website - update front page and sidebars.</td>
- </tr>
- <tr>
- <td> </td>
- <td>Website Manager</td>
- <td>Add the new Version number to the Mantis bug tracker.</td>
- </tr>
- <tr>
- <td> </td>
- <td>Close all Mantis bug reports that were marked as resolved and which
- have been fixed in this release.</td>
- </tr>
- <tr>
- <td> </td>
+ </tr>
+ <tr>
+ <td> </td>
+ <td>Upload the release tar file to the Launchpad download area.</td>
+ </tr>
+ <tr>
+ <td> </td>
+ <td>Add the new Version number to the Launchpad bug tracker.</td>
+ </tr>
+ <tr>
+ <td> </td>
+ <td>Find all Launchpad bug reports with the status Fix Committed which
+ have been fixed in this release and mark them Fix Released.</td>
+ </tr>
+ <tr>
+ <td> </td>
<td>Email tech-talk</td>
- </tr>
+ </tr>
<tr>
- <td> </td>
+ <td> </td>
<td>Add an entry to the website News page, linking to the new version
webpage.</td>
- </tr>
- </tbody>
-</table>
+ </tr>
+ </tbody>
+ </table>
</body>
</html>
=== modified file 'src/Makefile'
--- src/Makefile 2010-07-06 22:23:24 +0000
+++ src/Makefile 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
# in the file LICENSE that is included with this distribution.
-# $Id$
+# $Revision-Id$
TOP = ..
=== modified file 'src/RTEMS/Makefile'
--- src/RTEMS/Makefile 2002-07-12 21:35:43 +0000
+++ src/RTEMS/Makefile 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
# in file LICENSE that is included with this distribution.
-# $Id$
+# $Revision-Id$
TOP = ../..
=== modified file 'src/RTEMS/base/epicsRtemsInitHookPost.c'
--- src/RTEMS/base/epicsRtemsInitHookPost.c 2006-06-29 15:22:53 +0000
+++ src/RTEMS/base/epicsRtemsInitHookPost.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
* Dummy version -- use if application does not provide its own version
- * $Id$
+ * $Revision-Id$
#include "epicsRtemsInitHooks.h"
=== modified file 'src/RTEMS/base/epicsRtemsInitHookPre.c'
--- src/RTEMS/base/epicsRtemsInitHookPre.c 2006-06-29 15:22:53 +0000
+++ src/RTEMS/base/epicsRtemsInitHookPre.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
=== modified file 'src/RTEMS/base/epicsRtemsInitHooks.h'
--- src/RTEMS/base/epicsRtemsInitHooks.h 2006-06-29 20:07:10 +0000
+++ src/RTEMS/base/epicsRtemsInitHooks.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
* Hooks into RTEMS startup code
- * $Id$
+ * $Revision-Id$
#include <bsp.h>
#include <rtems/rtems_bsdnet.h>
=== modified file 'src/RTEMS/base/rtems_config.c'
--- src/RTEMS/base/rtems_config.c 2010-07-23 16:21:02 +0000
+++ src/RTEMS/base/rtems_config.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
* RTEMS configuration for EPICS
- * $Id$
+ * $Revision-Id$
* Author: W. Eric Norum
* [email protected]
* (630) 252-4793
=== modified file 'src/RTEMS/base/rtems_init.c'
--- src/RTEMS/base/rtems_init.c 2010-07-23 16:21:02 +0000
+++ src/RTEMS/base/rtems_init.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
* RTEMS startup task for EPICS
- * $Id$
+ * $Revision-Id$
* [email protected]
* (306) 966-5394
=== modified file 'src/RTEMS/base/rtems_netconfig.c'
--- src/RTEMS/base/rtems_netconfig.c 2004-11-30 19:40:48 +0000
+++ src/RTEMS/base/rtems_netconfig.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
* RTEMS network configuration for EPICS
- * $Id$
+ * $Revision-Id$
* [email protected]
* (306) 966-5394
=== modified file 'src/RTEMS/base/rtems_util.c'
--- src/RTEMS/base/rtems_util.c 2009-04-24 17:06:54 +0000
+++ src/RTEMS/base/rtems_util.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
* RTEMS utilitiy routines for EPICS
- * $Id$
+ * $Revision-Id$
* [email protected]
* (306) 966-6055
=== modified file 'src/as/asDbLib.h'
--- src/as/asDbLib.h 2004-07-08 15:25:56 +0000
+++ src/as/asDbLib.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
* in file LICENSE that is included with this distribution.
/* share/epicsH/dbAsLib.h */
-/* $Id$ */
+/* $Revision-Id$ */
/* Author: Marty Kraimer Date: 02-23-94*/
#ifndef INCdbAsLibh
=== modified file 'src/as/ascheck.c'
--- src/as/ascheck.c 2006-12-01 23:52:59 +0000
+++ src/as/ascheck.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-/* $Id$ */
/* Author: Marty Kraimer Date: 03-24-94 */
#include <stdlib.h>
=== modified file 'src/bpt/cvtTable.h'
--- src/bpt/cvtTable.h 2002-07-12 21:35:43 +0000
+++ src/bpt/cvtTable.h 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
* and higher are distributed subject to a Software License Agreement found
-/* $Id$
+/* $Revision-Id$
* Breakpoint Tables
=== modified file 'src/bpt/makeBpt.c'
--- src/bpt/makeBpt.c 2010-06-22 16:43:42 +0000
+++ src/bpt/makeBpt.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$
+/* $Revision-Id$
* Date: 9/28/95
* Replacement for old bldCvtTable
=== modified file 'src/cas/README'
--- src/cas/README 1996-11-22 19:41:05 +0000
+++ src/cas/README 2010-10-06 18:12:40 +0000
@@ -1,14 +1,10 @@
-$Id$
+$Revision-Id$
README file for the EPICS Channel Access Server
Author Jeff Hill [email protected]
-$Log$
-Revision 1.1.1.1 1996/06/20 00:28:06 jhill
-ca server installation
Directory Structure
=== modified file 'src/cas/example/directoryService/vxEntry.cc'
--- src/cas/example/directoryService/vxEntry.cc 2002-07-12 21:35:43 +0000
+++ src/cas/example/directoryService/vxEntry.cc 2010-10-06 18:12:40 +0000
@@ -8,26 +8,9 @@
-// $Id$
+// $Revision-Id$
// Author: Jeff HIll (LANL)
-// $Log$
-// Revision 1.2 2001/01/31 13:33:29 mrk
-// osiTime=>epicsTime
-// Revision 1.1 1997/06/13 09:20:26 jhill
-// installed
-// Revision 1.2 1997/04/10 19:39:26 jhill
-// API changes
-// Revision 1.1 1996/12/06 22:20:22 jhill
-// moved down one level
-// Revision 1.2 1996/09/16 18:22:09 jhill
-// added cvs log entries
#include <vxWorks.h>
#include <taskLib.h>
=== modified file 'src/cas/generic/beaconAnomalyGovernor.cc'
--- src/cas/generic/beaconAnomalyGovernor.cc 2003-02-12 19:06:15 +0000
+++ src/cas/generic/beaconAnomalyGovernor.cc 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* Author Jeffrey O. Hill
* [email protected]
=== modified file 'src/cas/generic/beaconAnomalyGovernor.h'
--- src/cas/generic/beaconAnomalyGovernor.h 2003-02-12 19:06:15 +0000
+++ src/cas/generic/beaconAnomalyGovernor.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/beaconTimer.cc'
--- src/cas/generic/beaconTimer.cc 2009-07-09 15:27:43 +0000
+++ src/cas/generic/beaconTimer.cc 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/beaconTimer.h'
--- src/cas/generic/beaconTimer.h 2003-02-12 19:06:15 +0000
+++ src/cas/generic/beaconTimer.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/caHdrLargeArray.h'
--- src/cas/generic/caHdrLargeArray.h 2010-04-06 21:59:35 +0000
+++ src/cas/generic/caHdrLargeArray.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/caNetAddr.cc'
--- src/cas/generic/caNetAddr.cc 2003-08-01 19:13:39 +0000
+++ src/cas/generic/caNetAddr.cc 2010-10-06 18:12:40 +0000
@@ -10,7 +10,7 @@
-// $Id$
+// $Revision-Id$
// Author: Jeffrey O. Hill
// [email protected]
=== modified file 'src/cas/generic/caServer.cc'
--- src/cas/generic/caServer.cc 2003-05-02 17:45:06 +0000
+++ src/cas/generic/caServer.cc 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/caServerI.cc'
--- src/cas/generic/caServerI.cc 2009-08-06 02:24:00 +0000
+++ src/cas/generic/caServerI.cc 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casAsyncIOI.cc'
--- src/cas/generic/casAsyncIOI.cc 2009-08-13 23:32:18 +0000
+++ src/cas/generic/casAsyncIOI.cc 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casAsyncIOI.h'
--- src/cas/generic/casAsyncIOI.h 2003-03-10 22:26:33 +0000
+++ src/cas/generic/casAsyncIOI.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casAsyncPVAttachIO.cc'
--- src/cas/generic/casAsyncPVAttachIO.cc 2003-08-01 19:13:39 +0000
+++ src/cas/generic/casAsyncPVAttachIO.cc 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casAsyncPVAttachIOI.cpp'
--- src/cas/generic/casAsyncPVAttachIOI.cpp 2009-08-06 02:24:00 +0000
+++ src/cas/generic/casAsyncPVAttachIOI.cpp 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casAsyncPVAttachIOI.h'
--- src/cas/generic/casAsyncPVAttachIOI.h 2003-03-10 22:26:33 +0000
+++ src/cas/generic/casAsyncPVAttachIOI.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casAsyncPVExistIO.cc'
--- src/cas/generic/casAsyncPVExistIO.cc 2003-08-01 19:13:39 +0000
+++ src/cas/generic/casAsyncPVExistIO.cc 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casAsyncPVExistIOI.cpp'
--- src/cas/generic/casAsyncPVExistIOI.cpp 2009-08-06 02:24:00 +0000
+++ src/cas/generic/casAsyncPVExistIOI.cpp 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casAsyncPVExistIOI.h'
--- src/cas/generic/casAsyncPVExistIOI.h 2003-03-10 22:26:33 +0000
+++ src/cas/generic/casAsyncPVExistIOI.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casAsyncReadIO.cc'
--- src/cas/generic/casAsyncReadIO.cc 2003-08-01 19:13:39 +0000
+++ src/cas/generic/casAsyncReadIO.cc 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casAsyncReadIOI.cc'
--- src/cas/generic/casAsyncReadIOI.cc 2009-07-09 15:27:43 +0000
+++ src/cas/generic/casAsyncReadIOI.cc 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casAsyncReadIOI.h'
--- src/cas/generic/casAsyncReadIOI.h 2003-09-29 22:58:43 +0000
+++ src/cas/generic/casAsyncReadIOI.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casAsyncWriteIO.cc'
--- src/cas/generic/casAsyncWriteIO.cc 2003-08-01 19:13:39 +0000
+++ src/cas/generic/casAsyncWriteIO.cc 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casAsyncWriteIOI.cpp'
--- src/cas/generic/casAsyncWriteIOI.cpp 2009-07-09 15:27:43 +0000
+++ src/cas/generic/casAsyncWriteIOI.cpp 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casAsyncWriteIOI.h'
--- src/cas/generic/casAsyncWriteIOI.h 2003-03-10 22:26:33 +0000
+++ src/cas/generic/casAsyncWriteIOI.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casBufferFactory.cpp'
--- src/cas/generic/casBufferFactory.cpp 2003-02-12 19:06:15 +0000
+++ src/cas/generic/casBufferFactory.cpp 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casChannel.cc'
--- src/cas/generic/casChannel.cc 2009-08-03 22:09:52 +0000
+++ src/cas/generic/casChannel.cc 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casChannelI.cc'
--- src/cas/generic/casChannelI.cc 2009-08-03 22:09:52 +0000
+++ src/cas/generic/casChannelI.cc 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casChannelI.h'
--- src/cas/generic/casChannelI.h 2009-08-03 22:09:52 +0000
+++ src/cas/generic/casChannelI.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casCoreClient.cc'
--- src/cas/generic/casCoreClient.cc 2009-07-09 15:27:43 +0000
+++ src/cas/generic/casCoreClient.cc 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casCoreClient.h'
--- src/cas/generic/casCoreClient.h 2009-08-13 23:37:30 +0000
+++ src/cas/generic/casCoreClient.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casCtx.h'
--- src/cas/generic/casCtx.h 2003-02-12 19:11:43 +0000
+++ src/cas/generic/casCtx.h 2010-10-06 18:12:40 +0000
@@ -10,7 +10,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casDGClient.cc'
--- src/cas/generic/casDGClient.cc 2009-07-30 23:29:43 +0000
+++ src/cas/generic/casDGClient.cc 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casEvent.h'
--- src/cas/generic/casEvent.h 2003-03-10 22:26:33 +0000
+++ src/cas/generic/casEvent.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casEventMask.cc'
--- src/cas/generic/casEventMask.cc 2009-08-24 17:07:03 +0000
+++ src/cas/generic/casEventMask.cc 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casEventMask.h'
--- src/cas/generic/casEventMask.h 2003-02-12 19:06:15 +0000
+++ src/cas/generic/casEventMask.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casEventRegistry.h'
--- src/cas/generic/casEventRegistry.h 2003-02-12 19:11:43 +0000
+++ src/cas/generic/casEventRegistry.h 2010-10-06 18:12:40 +0000
@@ -11,7 +11,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casEventSys.cc'
--- src/cas/generic/casEventSys.cc 2009-08-18 00:40:00 +0000
+++ src/cas/generic/casEventSys.cc 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casEventSys.h'
--- src/cas/generic/casEventSys.h 2009-08-13 23:42:37 +0000
+++ src/cas/generic/casEventSys.h 2010-10-06 18:12:40 +0000
@@ -10,7 +10,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casMonEvent.cc'
--- src/cas/generic/casMonEvent.cc 2009-07-09 15:27:43 +0000
+++ src/cas/generic/casMonEvent.cc 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casMonEvent.h'
--- src/cas/generic/casMonEvent.h 2003-03-10 22:26:33 +0000
+++ src/cas/generic/casMonEvent.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casMonitor.cc'
--- src/cas/generic/casMonitor.cc 2009-07-09 15:27:43 +0000
+++ src/cas/generic/casMonitor.cc 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casMonitor.h'
--- src/cas/generic/casMonitor.h 2008-07-28 16:19:50 +0000
+++ src/cas/generic/casMonitor.h 2010-10-06 18:12:40 +0000
@@ -10,7 +10,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casPV.cc'
--- src/cas/generic/casPV.cc 2009-08-03 22:09:52 +0000
+++ src/cas/generic/casPV.cc 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casPVI.cc'
--- src/cas/generic/casPVI.cc 2009-08-03 22:09:52 +0000
+++ src/cas/generic/casPVI.cc 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/casPVI.h'
--- src/cas/generic/casPVI.h 2009-08-05 23:56:26 +0000
+++ src/cas/generic/casPVI.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/chanIntfForPV.cc'
--- src/cas/generic/chanIntfForPV.cc 2009-07-09 15:27:43 +0000
+++ src/cas/generic/chanIntfForPV.cc 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/chanIntfForPV.h'
--- src/cas/generic/chanIntfForPV.h 2008-07-28 16:19:50 +0000
+++ src/cas/generic/chanIntfForPV.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/channelDestroyEvent.cpp'
--- src/cas/generic/channelDestroyEvent.cpp 2003-03-19 18:00:33 +0000
+++ src/cas/generic/channelDestroyEvent.cpp 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/channelDestroyEvent.h'
--- src/cas/generic/channelDestroyEvent.h 2003-03-13 00:16:39 +0000
+++ src/cas/generic/channelDestroyEvent.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/clientBufMemoryManager.cpp'
--- src/cas/generic/clientBufMemoryManager.cpp 2003-02-12 19:06:15 +0000
+++ src/cas/generic/clientBufMemoryManager.cpp 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/inBuf.cc'
--- src/cas/generic/inBuf.cc 2009-07-30 23:45:14 +0000
+++ src/cas/generic/inBuf.cc 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/ioBlocked.h'
--- src/cas/generic/ioBlocked.h 2009-07-14 22:51:06 +0000
+++ src/cas/generic/ioBlocked.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/mt/ioBlocked.cc'
--- src/cas/generic/mt/ioBlocked.cc 2003-02-12 19:06:15 +0000
+++ src/cas/generic/mt/ioBlocked.cc 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-// $Id$
+// $Revision-Id$
// Author: Jeff Hill
// This file implements a IO blocked list NOOP for multi-threaded systems
=== modified file 'src/cas/generic/outBuf.cc'
--- src/cas/generic/outBuf.cc 2009-07-25 01:24:50 +0000
+++ src/cas/generic/outBuf.cc 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/cas/generic/pvAttachReturn.cc'
--- src/cas/generic/pvAttachReturn.cc 2002-08-21 16:33:50 +0000
+++ src/cas/generic/pvAttachReturn.cc 2010-10-06 18:12:40 +0000
@@ -10,7 +10,7 @@
-// $Id$
+// $Revision-Id$
=== modified file 'src/cas/generic/pvExistReturn.cc'
--- src/cas/generic/pvExistReturn.cc 2004-08-04 20:08:56 +0000
+++ src/cas/generic/pvExistReturn.cc 2010-10-06 18:12:40 +0000
@@ -10,7 +10,7 @@
-// $Id$
+// $Revision-Id$
=== modified file 'src/cas/generic/st/casDGEvWakeup.h'
--- src/cas/generic/st/casDGEvWakeup.h 2003-02-12 19:11:43 +0000
+++ src/cas/generic/st/casDGEvWakeup.h 2010-10-06 18:12:40 +0000
@@ -10,7 +10,7 @@
-// $Id$
+// $Revision-Id$
#ifndef casDGEvWakeuph
=== modified file 'src/cas/generic/st/casDGIOWakeup.h'
--- src/cas/generic/st/casDGIOWakeup.h 2003-02-12 19:11:43 +0000
+++ src/cas/generic/st/casDGIOWakeup.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
-// $Id$
+// $Revision-Id$
#ifndef casDGIOWakeuph
=== modified file 'src/cas/generic/st/casDGIntfOS.cc'
--- src/cas/generic/st/casDGIntfOS.cc 2009-08-13 23:51:40 +0000
+++ src/cas/generic/st/casDGIntfOS.cc 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
// casDGIntfOS.cc
-// $Id$
+// $Revision-Id$
#include "fdManager.h"
=== modified file 'src/cas/generic/st/casDGIntfOS.h'
--- src/cas/generic/st/casDGIntfOS.h 2009-07-30 23:54:18 +0000
+++ src/cas/generic/st/casDGIntfOS.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
-// $Id$
+// $Revision-Id$
#ifndef casDGIntfOSh
=== modified file 'src/cas/generic/st/casIntfOS.cc'
--- src/cas/generic/st/casIntfOS.cc 2003-03-10 22:26:33 +0000
+++ src/cas/generic/st/casIntfOS.cc 2010-10-06 18:12:40 +0000
@@ -11,7 +11,7 @@
* casIntfOS.cc
- * $Id$
+ * $Revision-Id$
=== modified file 'src/cas/generic/st/casIntfOS.h'
--- src/cas/generic/st/casIntfOS.h 2005-08-31 21:09:27 +0000
+++ src/cas/generic/st/casIntfOS.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
-// $Id$
+// $Revision-Id$
// casOSD.h - Channel Access Server OS dependent wrapper
=== modified file 'src/cas/generic/st/casOSD.h'
--- src/cas/generic/st/casOSD.h 2003-02-12 19:06:15 +0000
+++ src/cas/generic/st/casOSD.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-// $Id$
+// $Revision-Id$
=== modified file 'src/cas/generic/st/casStreamOS.cc'
--- src/cas/generic/st/casStreamOS.cc 2009-08-13 23:55:03 +0000
+++ src/cas/generic/st/casStreamOS.cc 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
// casStreamOS.cc
-// $Id$
+// $Revision-Id$
// TO DO:
// o armRecv() and armSend() should return bad status when
=== modified file 'src/cas/generic/st/casStreamOS.h'
--- src/cas/generic/st/casStreamOS.h 2009-07-31 00:00:42 +0000
+++ src/cas/generic/st/casStreamOS.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
-// $Id$
+// $Revision-Id$
#ifndef casStreamOSh
=== modified file 'src/cas/generic/st/ioBlocked.cc'
--- src/cas/generic/st/ioBlocked.cc 2009-07-14 22:51:06 +0000
+++ src/cas/generic/st/ioBlocked.cc 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
-// $Id$
+// $Revision-Id$
// Author Jeff Hill
// IO Blocked list class
=== modified file 'src/cas/io/bsdSocket/caServerIO.cc'
--- src/cas/io/bsdSocket/caServerIO.cc 2009-07-09 15:27:43 +0000
+++ src/cas/io/bsdSocket/caServerIO.cc 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-// $Id$
+// $Revision-Id$
// verify connection state prior to doing anything in this file
=== modified file 'src/cas/io/bsdSocket/caServerIO.h'
--- src/cas/io/bsdSocket/caServerIO.h 2003-02-12 19:11:43 +0000
+++ src/cas/io/bsdSocket/caServerIO.h 2010-10-06 18:12:40 +0000
@@ -10,7 +10,7 @@
-// $Id$
+// $Revision-Id$
#ifndef caServerIOh
=== modified file 'src/cas/io/bsdSocket/casDGIntfIO.h'
--- src/cas/io/bsdSocket/casDGIntfIO.h 2009-07-30 23:50:45 +0000
+++ src/cas/io/bsdSocket/casDGIntfIO.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
-// $Id$
+// $Revision-Id$
#ifndef casDGIntfIOh
=== modified file 'src/cas/io/bsdSocket/casIOD.h'
--- src/cas/io/bsdSocket/casIOD.h 2003-09-17 19:25:31 +0000
+++ src/cas/io/bsdSocket/casIOD.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-// $Id$
+// $Revision-Id$
#ifndef includeCASIODH
=== modified file 'src/cas/io/bsdSocket/casIntfIO.h'
--- src/cas/io/bsdSocket/casIntfIO.h 2009-07-25 01:04:14 +0000
+++ src/cas/io/bsdSocket/casIntfIO.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
-// $Id$
+// $Revision-Id$
#ifndef casIntfIOh
=== modified file 'src/cas/io/bsdSocket/casStreamIO.h'
--- src/cas/io/bsdSocket/casStreamIO.h 2010-08-10 21:05:46 +0000
+++ src/cas/io/bsdSocket/casStreamIO.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-// $Id$
+// $Revision-Id$
#ifndef casStreamIOh
=== modified file 'src/cas/io/bsdSocket/ipIgnoreEntry.h'
--- src/cas/io/bsdSocket/ipIgnoreEntry.h 2003-02-12 19:11:43 +0000
+++ src/cas/io/bsdSocket/ipIgnoreEntry.h 2010-10-06 18:12:40 +0000
@@ -10,7 +10,7 @@
-// $Id$
+// $Revision-Id$
#ifndef ipIgnoreEntryh
=== modified file 'src/db/callback.h'
--- src/db/callback.h 2008-05-15 17:41:02 +0000
+++ src/db/callback.h 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
* EPICS BASE is distributed subject to a Software License Agreement found
-/* $Id$ */
/* includes for general purpose callback tasks */
=== modified file 'src/db/cvtBpt.c'
--- src/db/cvtBpt.c 2006-10-26 16:05:23 +0000
+++ src/db/cvtBpt.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
/* cvtBpt.c - Convert using breakpoint table
=== modified file 'src/db/dbAccess.c'
--- src/db/dbAccess.c 2009-11-18 16:55:04 +0000
+++ src/db/dbAccess.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* dbAccess.c */
-/* $Id$ */
* Original Author: Bob Dalesio
* Current Author: Marty Kraimer
=== modified file 'src/db/dbAccessDefs.h'
--- src/db/dbAccessDefs.h 2010-07-19 14:49:01 +0000
+++ src/db/dbAccessDefs.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* dbAccessDefs.h */
-/* $Id$ */
#ifndef INCdbAccessDefsh
#define INCdbAccessDefsh
=== modified file 'src/db/dbBkpt.c'
--- src/db/dbBkpt.c 2009-08-28 18:34:38 +0000
+++ src/db/dbBkpt.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* dbBkpt.c */
-/* base/src/db $Id$ */
+/* base/src/db $Revision-Id$ */
* Author: Matthew Needes
* Date: 8-30-93
=== modified file 'src/db/dbBkpt.h'
--- src/db/dbBkpt.h 2006-12-19 16:20:47 +0000
+++ src/db/dbBkpt.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* dbBkpt.h */
-/* base/include $Id$ */
+/* base/include $Revision-Id$ */
* Date: 8-30-93
=== modified file 'src/db/dbCAC.h'
--- src/db/dbCAC.h 2008-07-28 22:23:35 +0000
+++ src/db/dbCAC.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* L O S A L A M O S
=== modified file 'src/db/dbCa.c'
--- src/db/dbCa.c 2009-12-22 23:43:52 +0000
+++ src/db/dbCa.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$
+/* $Revision-Id$
* Original Authors: Bob Dalesio and Marty Kraimer
* Date: 26MAR96
=== modified file 'src/db/dbChannelIO.cpp'
--- src/db/dbChannelIO.cpp 2009-07-09 15:27:43 +0000
+++ src/db/dbChannelIO.cpp 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* L O S A L A M O S
=== modified file 'src/db/dbChannelIO.h'
--- src/db/dbChannelIO.h 2007-01-11 22:07:47 +0000
+++ src/db/dbChannelIO.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* L O S A L A M O S
=== modified file 'src/db/dbContext.cpp'
--- src/db/dbContext.cpp 2009-07-09 15:27:43 +0000
+++ src/db/dbContext.cpp 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
- * $Id$
+ * $Revision-Id$
* L O S A L A M O S
=== modified file 'src/db/dbContextReadNotifyCache.cpp'
--- src/db/dbContextReadNotifyCache.cpp 2009-07-07 23:54:41 +0000
+++ src/db/dbContextReadNotifyCache.cpp 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* Auther Jeff Hill
=== modified file 'src/db/dbEvent.c'
--- src/db/dbEvent.c 2009-07-09 16:37:24 +0000
+++ src/db/dbEvent.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* dbEvent.c */
-/* $Id$ */
/* routines for scheduling events to lower priority tasks via the RT kernel */
* Author: Jeffrey O. Hill
=== modified file 'src/db/dbEvent.h'
--- src/db/dbEvent.h 2006-11-28 18:54:03 +0000
+++ src/db/dbEvent.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* Author: Jeff Hill
* Date: 030393
=== modified file 'src/db/dbFastLinkConv.c'
--- src/db/dbFastLinkConv.c 2009-04-23 18:49:40 +0000
+++ src/db/dbFastLinkConv.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* dbFastLinkConv.c */
* Date: 12-9-93
=== modified file 'src/db/dbNotify.c'
--- src/db/dbNotify.c 2010-03-17 01:09:51 +0000
+++ src/db/dbNotify.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* dbNotify.c */
* Date: 03-30-95
=== modified file 'src/db/dbPutNotifyBlocker.cpp'
--- src/db/dbPutNotifyBlocker.cpp 2009-07-09 15:27:43 +0000
+++ src/db/dbPutNotifyBlocker.cpp 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* L O S A L A M O S
=== modified file 'src/db/dbPutNotifyBlocker.h'
--- src/db/dbPutNotifyBlocker.h 2004-01-09 00:42:15 +0000
+++ src/db/dbPutNotifyBlocker.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* L O S A L A M O S
=== modified file 'src/db/dbScan.h'
--- src/db/dbScan.h 2009-04-02 14:11:27 +0000
+++ src/db/dbScan.h 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$
+/* $Revision-Id$
* Date: 07-17-91
=== modified file 'src/db/dbSubscriptionIO.cpp'
--- src/db/dbSubscriptionIO.cpp 2009-07-09 15:27:43 +0000
+++ src/db/dbSubscriptionIO.cpp 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* L O S A L A M O S
=== modified file 'src/db/dbTest.c'
--- src/db/dbTest.c 2010-05-25 14:57:49 +0000
+++ src/db/dbTest.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
/* database access test subroutines */
#include <stddef.h>
=== modified file 'src/db/db_access.c'
--- src/db/db_access.c 2010-08-11 21:38:49 +0000
+++ src/db/db_access.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
/* Interface between old database access and new
=== modified file 'src/db/db_field_log.h'
--- src/db/db_field_log.h 2002-07-12 21:35:43 +0000
+++ src/db/db_field_log.h 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$
+/* $Revision-Id$
* Date: 4-1-89
=== modified file 'src/db/initHooks.c'
--- src/db/initHooks.c 2009-07-09 18:37:26 +0000
+++ src/db/initHooks.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$ */
* Authors: Benjamin Franksen (BESY) and Marty Kraimer
* Date: 06-01-91
=== modified file 'src/db/initHooks.h'
--- src/db/initHooks.h 2009-04-16 18:38:20 +0000
+++ src/db/initHooks.h 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$ */
* Date: 06-01-91
=== modified file 'src/db/recGbl.c'
--- src/db/recGbl.c 2009-02-24 22:30:26 +0000
+++ src/db/recGbl.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
/* recGbl.c */
-/* $Id$ */
=== modified file 'src/db/templateInstances.cpp'
--- src/db/templateInstances.cpp 2004-01-09 01:30:28 +0000
+++ src/db/templateInstances.cpp 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* L O S A L A M O S
=== modified file 'src/db/test/callbackTest.c'
--- src/db/test/callbackTest.c 2008-10-09 15:01:53 +0000
+++ src/db/test/callbackTest.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$ */
/* Author: Marty Kraimer Date: 26JAN2000 */
=== modified file 'src/dbStatic/alarm.h'
--- src/dbStatic/alarm.h 2009-03-03 17:15:10 +0000
+++ src/dbStatic/alarm.h 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
/* Alarm definitions, must match menuAlarmSevr.dbd and menuAlarmStat.dbd */
-/* $Id$ */
* Authors: Bob Dalesio and Marty Kraimer
=== modified file 'src/dbStatic/alarmString.h'
--- src/dbStatic/alarmString.h 2009-03-03 17:15:10 +0000
+++ src/dbStatic/alarmString.h 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$ */
/* String names for alarms */
=== modified file 'src/dbStatic/dbBase.h'
--- src/dbStatic/dbBase.h 2009-07-09 15:27:43 +0000
+++ src/dbStatic/dbBase.h 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$
+/* $Revision-Id$
* Date: 03-19-92
=== modified file 'src/dbStatic/dbFldTypes.h'
--- src/dbStatic/dbFldTypes.h 2005-12-12 21:25:17 +0000
+++ src/dbStatic/dbFldTypes.h 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$
+/* $Revision-Id$
* Date: 6-1-90
=== modified file 'src/dbStatic/dbLexRoutines.c'
--- src/dbStatic/dbLexRoutines.c 2010-05-04 20:43:20 +0000
+++ src/dbStatic/dbLexRoutines.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$ */
/* Author: Marty Kraimer Date: 13JUL95*/
=== modified file 'src/dbStatic/dbStaticLib.c'
--- src/dbStatic/dbStaticLib.c 2010-06-22 22:35:48 +0000
+++ src/dbStatic/dbStaticLib.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$ */
#include <stdio.h>
#include <errno.h>
=== modified file 'src/dbStatic/dbStaticLib.h'
--- src/dbStatic/dbStaticLib.h 2009-04-23 21:56:22 +0000
+++ src/dbStatic/dbStaticLib.h 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$
+/* $Revision-Id$
* Date: 06-08-93
=== modified file 'src/dbStatic/devSup.h'
--- src/dbStatic/devSup.h 2009-07-09 15:27:43 +0000
+++ src/dbStatic/devSup.h 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
/* devSup.h Device Support */
-/* $Id$ */
* Date: 6-1-90
=== modified file 'src/dbStatic/drvSup.h'
--- src/dbStatic/drvSup.h 2009-07-09 15:27:43 +0000
+++ src/dbStatic/drvSup.h 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
/* drvSup.h Driver Support */
-/* share/epicsH $Id$ */
+/* share/epicsH $Revision-Id$ */
=== modified file 'src/dbStatic/guigroup.h'
--- src/dbStatic/guigroup.h 2002-07-12 21:35:43 +0000
+++ src/dbStatic/guigroup.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-/* $Id$
+/* $Revision-Id$
these are used in the pmt (prompt) field of the record support
ascii files. They represent field groupings for dct tools
=== modified file 'src/dbStatic/link.h'
--- src/dbStatic/link.h 2010-06-22 22:35:48 +0000
+++ src/dbStatic/link.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* link.h */
=== modified file 'src/dbStatic/special.h'
--- src/dbStatic/special.h 2002-07-12 21:35:43 +0000
+++ src/dbStatic/special.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* special.h */
=== modified file 'src/dev/softDev/devAaiSoft.c'
--- src/dev/softDev/devAaiSoft.c 2010-05-27 13:23:07 +0000
+++ src/dev/softDev/devAaiSoft.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$
+/* $Revision-Id$
* devAaiSoft.c - Device Support Routines for soft Waveform Records
=== modified file 'src/dev/softDev/devAaoSoft.c'
--- src/dev/softDev/devAaoSoft.c 2010-05-27 14:44:03 +0000
+++ src/dev/softDev/devAaoSoft.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$
+/* $Revision-Id$
* devAaoSoft.c - Device Support Routines for soft Waveform Records
=== modified file 'src/dev/softDev/devAiSoft.c'
--- src/dev/softDev/devAiSoft.c 2009-04-09 15:03:09 +0000
+++ src/dev/softDev/devAiSoft.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$
+/* $Revision-Id$
* Date: 3/6/91
=== modified file 'src/dev/softDev/devAiSoftRaw.c'
--- src/dev/softDev/devAiSoftRaw.c 2008-08-06 22:11:51 +0000
+++ src/dev/softDev/devAiSoftRaw.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$
+/* $Revision-Id$
* Date: 6-1-90
=== modified file 'src/dev/softDev/devAoSoft.c'
--- src/dev/softDev/devAoSoft.c 2009-04-03 17:46:26 +0000
+++ src/dev/softDev/devAoSoft.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* devAoSoft.c */
-/* base/src/dev $Id$ */
+/* base/src/dev $Revision-Id$ */
/* Device Support Routines for soft Analog Output Records*/
=== modified file 'src/dev/softDev/devAoSoftRaw.c'
--- src/dev/softDev/devAoSoftRaw.c 2009-04-03 15:45:03 +0000
+++ src/dev/softDev/devAoSoftRaw.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* devAoSoftRaw.c */
/* Device Support Routines for soft raw Analog Output Records*/
=== modified file 'src/dev/softDev/devBiSoft.c'
--- src/dev/softDev/devBiSoft.c 2008-08-06 22:11:51 +0000
+++ src/dev/softDev/devBiSoft.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$
+/* $Revision-Id$
* Date: 6-1-90
=== modified file 'src/dev/softDev/devBiSoftRaw.c'
--- src/dev/softDev/devBiSoftRaw.c 2008-08-06 22:11:51 +0000
+++ src/dev/softDev/devBiSoftRaw.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$
+/* $Revision-Id$
* Date: 6-1-90
=== modified file 'src/dev/softDev/devBoSoft.c'
--- src/dev/softDev/devBoSoft.c 2009-04-03 17:46:26 +0000
+++ src/dev/softDev/devBoSoft.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* devBoSoft.c */
/* devBoSoft.c - Device Support Routines for Soft Binary Output*/
=== modified file 'src/dev/softDev/devBoSoftRaw.c'
--- src/dev/softDev/devBoSoftRaw.c 2009-04-03 17:46:26 +0000
+++ src/dev/softDev/devBoSoftRaw.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* devBoSoftRaw.c */
/* devBoSoftRaw.c - Device Support Routines for SoftRaw Binary Output*/
=== modified file 'src/dev/softDev/devEventSoft.c'
--- src/dev/softDev/devEventSoft.c 2008-08-06 22:11:51 +0000
+++ src/dev/softDev/devEventSoft.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$
+/* $Revision-Id$
* Author: Janet Anderson
* Date: 04-21-91
=== modified file 'src/dev/softDev/devGeneralTime.c'
--- src/dev/softDev/devGeneralTime.c 2009-01-28 20:01:41 +0000
+++ src/dev/softDev/devGeneralTime.c 2010-10-06 18:12:40 +0000
@@ -3,7 +3,7 @@
-/* $Id$ */
* Original Author: Sheng Peng, ORNL / SNS Project
* Date: 07/2004
=== modified file 'src/dev/softDev/devHistogramSoft.c'
--- src/dev/softDev/devHistogramSoft.c 2009-04-03 17:46:26 +0000
+++ src/dev/softDev/devHistogramSoft.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* devHistogramSoft.c */
* Date: 07/02/91
=== modified file 'src/dev/softDev/devLiSoft.c'
--- src/dev/softDev/devLiSoft.c 2008-08-06 22:11:51 +0000
+++ src/dev/softDev/devLiSoft.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$
+/* $Revision-Id$
* Date: 09-23-91
=== modified file 'src/dev/softDev/devLoSoft.c'
--- src/dev/softDev/devLoSoft.c 2009-04-03 17:46:26 +0000
+++ src/dev/softDev/devLoSoft.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* devLoSoft.c */
* Date: 09-23-91
=== modified file 'src/dev/softDev/devMbbiDirectSoft.c'
--- src/dev/softDev/devMbbiDirectSoft.c 2008-08-06 22:11:51 +0000
+++ src/dev/softDev/devMbbiDirectSoft.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$
+/* $Revision-Id$
* Original Authors: Bob Dalesio and Matthew Needes
* Date: 10-08-93
=== modified file 'src/dev/softDev/devMbbiDirectSoftRaw.c'
--- src/dev/softDev/devMbbiDirectSoftRaw.c 2008-08-06 22:11:51 +0000
+++ src/dev/softDev/devMbbiDirectSoftRaw.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$
+/* $Revision-Id$
* Date: 10-08-93
=== modified file 'src/dev/softDev/devMbbiSoft.c'
--- src/dev/softDev/devMbbiSoft.c 2008-08-06 22:11:51 +0000
+++ src/dev/softDev/devMbbiSoft.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$
+/* $Revision-Id$
* Date: 6-1-90
=== modified file 'src/dev/softDev/devMbbiSoftRaw.c'
--- src/dev/softDev/devMbbiSoftRaw.c 2008-08-06 22:11:51 +0000
+++ src/dev/softDev/devMbbiSoftRaw.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$
+/* $Revision-Id$
* Date: 6-1-90
=== modified file 'src/dev/softDev/devMbboDirectSoft.c'
--- src/dev/softDev/devMbboDirectSoft.c 2009-04-03 17:46:26 +0000
+++ src/dev/softDev/devMbboDirectSoft.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* devMbboDirectSoft.c */
* Current Author: Matthew Needes
=== modified file 'src/dev/softDev/devMbboDirectSoftRaw.c'
--- src/dev/softDev/devMbboDirectSoftRaw.c 2009-04-03 17:46:26 +0000
+++ src/dev/softDev/devMbboDirectSoftRaw.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* devMbboDirectSoftRaw.c */
=== modified file 'src/dev/softDev/devMbboSoft.c'
--- src/dev/softDev/devMbboSoft.c 2009-04-03 17:46:26 +0000
+++ src/dev/softDev/devMbboSoft.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* devMbboSoft.c */
=== modified file 'src/dev/softDev/devMbboSoftRaw.c'
--- src/dev/softDev/devMbboSoftRaw.c 2009-04-03 17:46:26 +0000
+++ src/dev/softDev/devMbboSoftRaw.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* devMbboSoftRaw.c */
* Date: 3-28-92
=== modified file 'src/dev/softDev/devSASoft.c'
--- src/dev/softDev/devSASoft.c 2008-08-06 22:11:51 +0000
+++ src/dev/softDev/devSASoft.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$
+/* $Revision-Id$
* Author: Carl Lionberger
* Date: 9-2-93
=== modified file 'src/dev/softDev/devSiSoft.c'
--- src/dev/softDev/devSiSoft.c 2009-04-03 17:46:26 +0000
+++ src/dev/softDev/devSiSoft.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$
+/* $Revision-Id$
* Date: 04-21-91
=== modified file 'src/dev/softDev/devSoSoft.c'
--- src/dev/softDev/devSoSoft.c 2009-04-03 17:46:26 +0000
+++ src/dev/softDev/devSoSoft.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
* Date: 21APR1991
=== modified file 'src/dev/softDev/devSoSoftCallback.c'
--- src/dev/softDev/devSoSoftCallback.c 2009-04-29 18:24:25 +0000
+++ src/dev/softDev/devSoSoftCallback.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
* Date: 04NOV2003
=== modified file 'src/dev/softDev/devSoStdio.c'
--- src/dev/softDev/devSoStdio.c 2008-09-29 17:54:35 +0000
+++ src/dev/softDev/devSoStdio.c 2010-10-06 18:12:40 +0000
@@ -5,7 +5,7 @@
-/* $Id$ */
#include <stdio.h>
#include <string.h>
=== modified file 'src/dev/softDev/devTimestamp.c'
--- src/dev/softDev/devTimestamp.c 2008-06-06 14:29:37 +0000
+++ src/dev/softDev/devTimestamp.c 2010-10-06 18:12:40 +0000
@@ -5,7 +5,7 @@
* in the file LICENSE that is included with this distribution.
-/* $Id$ */
* Device support for EPICS time stamps
=== modified file 'src/dev/softDev/devWfSoft.c'
--- src/dev/softDev/devWfSoft.c 2008-08-06 22:11:51 +0000
+++ src/dev/softDev/devWfSoft.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$
+/* $Revision-Id$
* Date: 6-1-90
=== modified file 'src/dev/testDev/devHistogramTestAsyn.c'
--- src/dev/testDev/devHistogramTestAsyn.c 2009-04-27 18:31:50 +0000
+++ src/dev/testDev/devHistogramTestAsyn.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* devHistogramTestAsyn.c */
* Date: 07/02/91
=== modified file 'src/dev/testDev/devTestAsyn.c'
--- src/dev/testDev/devTestAsyn.c 2009-04-23 22:19:46 +0000
+++ src/dev/testDev/devTestAsyn.c 2010-10-06 18:12:40 +0000
@@ -4,7 +4,7 @@
-/* $Id$ */
/* Device Support for testing asynchronous processing
=== modified file 'src/dev/testDev/devTestAsyn.dbd'
--- src/dev/testDev/devTestAsyn.dbd 2010-07-09 16:51:11 +0000
+++ src/dev/testDev/devTestAsyn.dbd 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
device(ai,CONSTANT,devTestAsyn,"Test Asyn")
device(aai,CONSTANT,devTestAsyn,"Test Asyn")
=== modified file 'src/gdd/README'
--- src/gdd/README 2002-07-15 20:34:24 +0000
+++ src/gdd/README 2010-10-06 18:12:40 +0000
@@ -2,7 +2,7 @@
# Author: Jim Kowalkowski
# Date: 2/96
-# $Id$
+# $Revision-Id$
Some Notes:
=== modified file 'src/gdd/aitConvert.cc'
--- src/gdd/aitConvert.cc 2010-03-17 01:09:53 +0000
+++ src/gdd/aitConvert.cc 2010-10-06 18:12:40 +0000
@@ -11,7 +11,7 @@
// Author: Jim Kowalkowski
// Date: 2/96
-// $Id$
+// $Revision-Id$
#define AIT_CONVERT_SOURCE 1
=== modified file 'src/gdd/aitConvert.h'
--- src/gdd/aitConvert.h 2004-08-12 16:50:26 +0000
+++ src/gdd/aitConvert.h 2010-10-06 18:12:40 +0000
@@ -14,7 +14,7 @@
* Author: Jim Kowalkowski
* Date: 2/96
- * $Id$
+ * $Revision-Id$
=== modified file 'src/gdd/aitGen.c'
--- src/gdd/aitGen.c 2009-04-03 17:46:26 +0000
+++ src/gdd/aitGen.c 2010-10-06 18:12:40 +0000
@@ -11,7 +11,7 @@
* Date: 2/96
- * $Id$
+ * $Revision-Id$
=== modified file 'src/gdd/aitHelpers.cc'
--- src/gdd/aitHelpers.cc 2006-06-29 15:28:36 +0000
+++ src/gdd/aitHelpers.cc 2010-10-06 18:12:40 +0000
@@ -11,7 +11,7 @@
// Date: 6/20/96
-// $Id$
+// $Revision-Id$
#include <stdio.h>
=== modified file 'src/gdd/aitHelpers.h'
--- src/gdd/aitHelpers.h 2006-06-29 15:28:36 +0000
+++ src/gdd/aitHelpers.h 2010-10-06 18:12:40 +0000
@@ -14,7 +14,7 @@
* Authors: Jeff Hill and Jim Kowalkowski
* Date: 6/20/96
- * $Id$
+ * $Revision-Id$
=== modified file 'src/gdd/aitTypes.c'
--- src/gdd/aitTypes.c 2002-07-15 20:34:24 +0000
+++ src/gdd/aitTypes.c 2010-10-06 18:12:40 +0000
@@ -11,7 +11,7 @@
* Date: 2/96
- * $Id$
+ * $Revision-Id$
=== modified file 'src/gdd/aitTypes.h'
--- src/gdd/aitTypes.h 2008-12-10 21:51:19 +0000
+++ src/gdd/aitTypes.h 2010-10-06 18:12:40 +0000
@@ -14,7 +14,7 @@
* Date: 2/96
- * $Id$
+ * $Revision-Id$
=== modified file 'src/gdd/dbMapper.cc'
--- src/gdd/dbMapper.cc 2009-07-09 17:06:45 +0000
+++ src/gdd/dbMapper.cc 2010-10-06 18:12:40 +0000
@@ -10,7 +10,7 @@
// Date: 2/96
-// $Id$
+// $Revision-Id$
#define DB_MAPPER_SOURCE 1
=== modified file 'src/gdd/dbMapper.h'
--- src/gdd/dbMapper.h 2002-07-15 20:34:24 +0000
+++ src/gdd/dbMapper.h 2010-10-06 18:12:40 +0000
@@ -14,7 +14,7 @@
* Date: 2/96
- * $Id$
+ * $Revision-Id$
=== modified file 'src/gdd/gdd.cc'
--- src/gdd/gdd.cc 2009-03-20 06:19:47 +0000
+++ src/gdd/gdd.cc 2010-10-06 18:12:40 +0000
@@ -10,7 +10,7 @@
// Date: 2/96
-// $Id$
+// $Revision-Id$
#include <stdio.h>
=== modified file 'src/gdd/gdd.h'
--- src/gdd/gdd.h 2004-02-07 01:34:59 +0000
+++ src/gdd/gdd.h 2010-10-06 18:12:40 +0000
@@ -14,7 +14,7 @@
* Date: 2/96
- * $Id$
+ * $Revision-Id$
=== modified file 'src/gdd/gddAppDefs.cc'
--- src/gdd/gddAppDefs.cc 2002-07-15 20:34:24 +0000
+++ src/gdd/gddAppDefs.cc 2010-10-06 18:12:40 +0000
@@ -10,7 +10,7 @@
// Date: 2/96
-// $Id$
+// $Revision-Id$
#define epicsExportSharedSymbols
=== modified file 'src/gdd/gddAppFuncTable.h'
--- src/gdd/gddAppFuncTable.h 2009-07-09 15:27:43 +0000
+++ src/gdd/gddAppFuncTable.h 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/gdd/gddAppTable.cc'
--- src/gdd/gddAppTable.cc 2003-02-12 18:54:48 +0000
+++ src/gdd/gddAppTable.cc 2010-10-06 18:12:40 +0000
@@ -10,7 +10,7 @@
// Date: 2/96
-// $Id$
+// $Revision-Id$
=== modified file 'src/gdd/gddAppTable.h'
--- src/gdd/gddAppTable.h 2003-02-12 18:54:48 +0000
+++ src/gdd/gddAppTable.h 2010-10-06 18:12:40 +0000
@@ -14,7 +14,7 @@
* Date: 2/96
- * $Id$
+ * $Revision-Id$
=== modified file 'src/gdd/gddArray.cc'
--- src/gdd/gddArray.cc 2002-07-15 20:42:22 +0000
+++ src/gdd/gddArray.cc 2010-10-06 18:12:40 +0000
@@ -14,7 +14,7 @@
// Date: 3/97
-// $Id$
+// $Revision-Id$
#include "gdd.h"
=== modified file 'src/gdd/gddArray.h'
--- src/gdd/gddArray.h 2002-07-15 20:34:24 +0000
+++ src/gdd/gddArray.h 2010-10-06 18:12:40 +0000
@@ -14,7 +14,7 @@
* Date: 3/97
- * $Id$
+ * $Revision-Id$
* Adds ability to put array data into a DD, get it out, and adjust it
=== modified file 'src/gdd/gddContainer.cc'
--- src/gdd/gddContainer.cc 2002-07-15 20:34:24 +0000
+++ src/gdd/gddContainer.cc 2010-10-06 18:12:40 +0000
@@ -15,7 +15,7 @@
// Date: 3/97
-// $Id$
+// $Revision-Id$
#include "gdd.h"
=== modified file 'src/gdd/gddContainer.h'
--- src/gdd/gddContainer.h 2002-07-15 20:34:24 +0000
+++ src/gdd/gddContainer.h 2010-10-06 18:12:40 +0000
@@ -14,7 +14,7 @@
* Date: 3/97
- * $Id$
+ * $Revision-Id$
#include "shareLib.h"
=== modified file 'src/gdd/gddContainerI.h'
--- src/gdd/gddContainerI.h 2002-07-15 20:34:24 +0000
+++ src/gdd/gddContainerI.h 2010-10-06 18:12:40 +0000
@@ -14,7 +14,7 @@
* Date: 3/97
- * $Id$
+ * $Revision-Id$
=== modified file 'src/gdd/gddErrorCodes.cc'
--- src/gdd/gddErrorCodes.cc 2002-07-15 20:34:24 +0000
+++ src/gdd/gddErrorCodes.cc 2010-10-06 18:12:40 +0000
@@ -11,7 +11,7 @@
// Date: 3/97
-// $Id$
+// $Revision-Id$
// -------------------------- Error messages -------------------------
=== modified file 'src/gdd/gddErrorCodes.h'
--- src/gdd/gddErrorCodes.h 2002-07-15 20:34:24 +0000
+++ src/gdd/gddErrorCodes.h 2010-10-06 18:12:40 +0000
@@ -14,7 +14,7 @@
* Date: 2/96
- * $Id$
+ * $Revision-Id$
=== modified file 'src/gdd/gddI.h'
--- src/gdd/gddI.h 2008-12-10 21:51:19 +0000
+++ src/gdd/gddI.h 2010-10-06 18:12:40 +0000
@@ -14,7 +14,7 @@
* Date: 3/97
- * $Id$
+ * $Revision-Id$
=== modified file 'src/gdd/gddNewDel.cc'
--- src/gdd/gddNewDel.cc 2004-01-28 00:04:03 +0000
+++ src/gdd/gddNewDel.cc 2010-10-06 18:12:40 +0000
@@ -10,7 +10,7 @@
// Date: 2/96
-// $Id$
+// $Revision-Id$
=== modified file 'src/gdd/gddNewDel.h'
--- src/gdd/gddNewDel.h 2009-07-01 22:28:41 +0000
+++ src/gdd/gddNewDel.h 2010-10-06 18:12:40 +0000
@@ -14,7 +14,7 @@
* Date: 2/96
- * $Id$
+ * $Revision-Id$
=== modified file 'src/gdd/gddTest.cc'
--- src/gdd/gddTest.cc 2002-07-15 20:34:24 +0000
+++ src/gdd/gddTest.cc 2010-10-06 18:12:40 +0000
@@ -10,7 +10,7 @@
// Date: 2/96
-// $Id$
+// $Revision-Id$
#include <stdio.h>
=== modified file 'src/gdd/gddUtils.cc'
--- src/gdd/gddUtils.cc 2002-07-15 20:34:24 +0000
+++ src/gdd/gddUtils.cc 2010-10-06 18:12:40 +0000
@@ -11,7 +11,7 @@
// Date: 3/97
-// $Id$
+// $Revision-Id$
#include <stdio.h>
=== modified file 'src/gdd/gddUtils.h'
--- src/gdd/gddUtils.h 2008-12-10 21:51:19 +0000
+++ src/gdd/gddUtils.h 2010-10-06 18:12:40 +0000
@@ -14,7 +14,7 @@
* Date: 2/96
- * $Id$
+ * $Revision-Id$
=== modified file 'src/gdd/gddUtilsI.h'
--- src/gdd/gddUtilsI.h 2002-07-15 20:34:24 +0000
+++ src/gdd/gddUtilsI.h 2010-10-06 18:12:40 +0000
@@ -14,7 +14,7 @@
* Date: 3/97
- * $Id$
+ * $Revision-Id$
=== modified file 'src/gdd/genApps.cc'
--- src/gdd/genApps.cc 2002-07-15 20:34:24 +0000
+++ src/gdd/genApps.cc 2010-10-06 18:12:40 +0000
@@ -10,9 +10,8 @@
// Date: 2/96
-// $Id$
+// $Revision-Id$
-// $Log$
#include "gddAppTable.h"
=== modified file 'src/libCom/bucketLib/bucketLib.h'
--- src/libCom/bucketLib/bucketLib.h 2009-07-09 17:06:45 +0000
+++ src/libCom/bucketLib/bucketLib.h 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/libCom/calc/calcPerform.c'
--- src/libCom/calc/calcPerform.c 2009-08-25 18:19:49 +0000
+++ src/libCom/calc/calcPerform.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$ */
* Author: Julie Sander and Bob Dalesio
* Date: 07-27-87
=== modified file 'src/libCom/calc/postfix.c'
--- src/libCom/calc/postfix.c 2009-04-23 18:49:40 +0000
+++ src/libCom/calc/postfix.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$
+/* $Revision-Id$
* Subroutines used to convert an infix expression to a postfix expression
=== modified file 'src/libCom/cppStd/epicsExcept.h'
--- src/libCom/cppStd/epicsExcept.h 2002-07-12 21:35:43 +0000
+++ src/libCom/cppStd/epicsExcept.h 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-// $Id$
+// $Revision-Id$
// Author: Andrew Johnson & Jeff Hill
// Date: December 2000
=== modified file 'src/libCom/cvtFast/cvtFast.c'
--- src/libCom/cvtFast/cvtFast.c 2008-08-11 21:55:02 +0000
+++ src/libCom/cvtFast/cvtFast.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$*/
+/* $Revision-Id$*/
/* Very efficient routines to convert numbers to strings
* Author: Bob Dalesio wrote cvtFloatToString (called FF_TO_STR)
* Code is same for cvtDoubleToString
=== modified file 'src/libCom/cvtFast/cvtFast.h'
--- src/libCom/cvtFast/cvtFast.h 2002-12-06 14:13:36 +0000
+++ src/libCom/cvtFast/cvtFast.h 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$
+/* $Revision-Id$
=== modified file 'src/libCom/cxxTemplates/epicsGuard.h'
--- src/libCom/cxxTemplates/epicsGuard.h 2007-01-11 22:04:44 +0000
+++ src/libCom/cxxTemplates/epicsGuard.h 2010-10-06 18:12:40 +0000
@@ -16,7 +16,7 @@
#endif
- * $Id$
+ * $Revision-Id$
=== modified file 'src/libCom/cxxTemplates/epicsOnce.cpp'
--- src/libCom/cxxTemplates/epicsOnce.cpp 2008-11-19 17:11:49 +0000
+++ src/libCom/cxxTemplates/epicsOnce.cpp 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* L O S A L A M O S
=== modified file 'src/libCom/cxxTemplates/epicsOnce.h'
--- src/libCom/cxxTemplates/epicsOnce.h 2002-07-12 21:35:43 +0000
+++ src/libCom/cxxTemplates/epicsOnce.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* L O S A L A M O S
=== modified file 'src/libCom/cxxTemplates/epicsSingleton.h'
--- src/libCom/cxxTemplates/epicsSingleton.h 2009-02-23 21:40:52 +0000
+++ src/libCom/cxxTemplates/epicsSingleton.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
=== modified file 'src/libCom/cxxTemplates/epicsSingletonBase.cpp'
--- src/libCom/cxxTemplates/epicsSingletonBase.cpp 2004-08-27 16:04:26 +0000
+++ src/libCom/cxxTemplates/epicsSingletonBase.cpp 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
=== modified file 'src/libCom/cxxTemplates/epicsSingletonMutex.cpp'
--- src/libCom/cxxTemplates/epicsSingletonMutex.cpp 2008-11-19 17:20:15 +0000
+++ src/libCom/cxxTemplates/epicsSingletonMutex.cpp 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* Author: Jeff O. Hill
=== modified file 'src/libCom/cxxTemplates/resourceLib.cpp'
--- src/libCom/cxxTemplates/resourceLib.cpp 2009-03-24 17:04:02 +0000
+++ src/libCom/cxxTemplates/resourceLib.cpp 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* L O S A L A M O S
* Los Alamos National Laboratory
=== modified file 'src/libCom/cxxTemplates/resourceLib.h'
--- src/libCom/cxxTemplates/resourceLib.h 2009-03-24 17:04:02 +0000
+++ src/libCom/cxxTemplates/resourceLib.h 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
- * $Id$
+ * $Revision-Id$
* General hash table templates for fast indexing of resources
* of any base resource type and any resource identifier type. Fast
=== modified file 'src/libCom/cxxTemplates/tsDLList.h'
--- src/libCom/cxxTemplates/tsDLList.h 2004-01-09 09:38:05 +0000
+++ src/libCom/cxxTemplates/tsDLList.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* type safe doubly linked list templates
=== modified file 'src/libCom/cxxTemplates/tsFreeList.h'
--- src/libCom/cxxTemplates/tsFreeList.h 2009-02-10 22:58:43 +0000
+++ src/libCom/cxxTemplates/tsFreeList.h 2010-10-06 18:12:40 +0000
@@ -11,7 +11,7 @@
#ifndef tsFreeList_h
#define tsFreeList_h
-/* $Id$
+/* $Revision-Id$
* L O S A L A M O S
=== modified file 'src/libCom/cxxTemplates/tsSLList.h'
--- src/libCom/cxxTemplates/tsSLList.h 2004-10-08 15:03:04 +0000
+++ src/libCom/cxxTemplates/tsSLList.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* type safe singly linked list templates
=== modified file 'src/libCom/ellLib/ellLib.c'
--- src/libCom/ellLib/ellLib.c 2009-08-28 18:34:38 +0000
+++ src/libCom/ellLib/ellLib.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$
+/* $Revision-Id$
* Author: John Winans (ANL)
* Date: 07-02-92
=== modified file 'src/libCom/ellLib/ellLib.h'
--- src/libCom/ellLib/ellLib.h 2009-08-28 18:34:38 +0000
+++ src/libCom/ellLib/ellLib.h 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$
+/* $Revision-Id$
* Date: 07-02-92
=== modified file 'src/libCom/env/envDefs.h'
--- src/libCom/env/envDefs.h 2010-04-06 21:59:35 +0000
+++ src/libCom/env/envDefs.h 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$
+/* $Revision-Id$
* Author: Roger A. Cole
* Date: 07-20-91
=== modified file 'src/libCom/env/envSubr.c'
--- src/libCom/env/envSubr.c 2009-07-09 15:27:43 +0000
+++ src/libCom/env/envSubr.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$
+/* $Revision-Id$
* Date: 07-20-91
=== modified file 'src/libCom/error/errMdef.h'
--- src/libCom/error/errMdef.h 2009-07-09 20:11:02 +0000
+++ src/libCom/error/errMdef.h 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
/* Error Handling definitions */
-/* $Id$ */
* Date: 6-1-90
=== modified file 'src/libCom/error/errSymLib.c'
--- src/libCom/error/errSymLib.c 2009-07-09 20:11:02 +0000
+++ src/libCom/error/errSymLib.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$
+/* $Revision-Id$
* errSymLib.c
* Date: 6-1-90
=== modified file 'src/libCom/error/error.h'
--- src/libCom/error/error.h 2002-07-12 21:35:43 +0000
+++ src/libCom/error/error.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* error.h - errMessage symbol table header */
=== modified file 'src/libCom/fdmgr/fdManager.cpp'
--- src/libCom/fdmgr/fdManager.cpp 2010-08-16 21:15:26 +0000
+++ src/libCom/fdmgr/fdManager.cpp 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-// $Id$
+// $Revision-Id$
// File descriptor management C++ class library
// (for multiplexing IO in a single threaded environment)
=== modified file 'src/libCom/fdmgr/fdManager.h'
--- src/libCom/fdmgr/fdManager.h 2008-07-28 16:19:50 +0000
+++ src/libCom/fdmgr/fdManager.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* File descriptor management C++ class library
* (for multiplexing IO in a single threaded environment)
=== modified file 'src/libCom/fdmgr/fdmgr.h'
--- src/libCom/fdmgr/fdmgr.h 2009-04-27 18:31:50 +0000
+++ src/libCom/fdmgr/fdmgr.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
/* fdmgr.h
- * share/epicsH/$Id$
+ * share/epicsH/$Revision-Id$
* Header file associated with a file descriptor manager
* for use with the UNIX system call select
=== modified file 'src/libCom/freeList/freeList.h'
--- src/libCom/freeList/freeList.h 2002-07-12 21:35:43 +0000
+++ src/libCom/freeList/freeList.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* share/epicsH/freeList.h */
/* Author: Marty Kraimer Date: 04-19-94 */
#ifndef INCfreeListh
=== modified file 'src/libCom/freeList/freeListLib.c'
--- src/libCom/freeList/freeListLib.c 2002-07-12 21:35:43 +0000
+++ src/libCom/freeList/freeListLib.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
=== modified file 'src/libCom/gpHash/gpHash.h'
--- src/libCom/gpHash/gpHash.h 2009-03-19 23:00:44 +0000
+++ src/libCom/gpHash/gpHash.h 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
/* Author: Marty Kraimer Date: 04-07-94 */
/* gph provides a general purpose directory accessed via a hash table*/
=== modified file 'src/libCom/gpHash/gpHashLib.c'
--- src/libCom/gpHash/gpHashLib.c 2009-03-19 23:00:44 +0000
+++ src/libCom/gpHash/gpHashLib.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$ */
=== modified file 'src/libCom/macLib/macCore.c'
--- src/libCom/macLib/macCore.c 2010-05-04 20:43:20 +0000
+++ src/libCom/macLib/macCore.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$
+/* $Revision-Id$
* Implementation of core macro substitution library (macLib)
=== modified file 'src/libCom/macLib/macEnv.c'
--- src/libCom/macLib/macEnv.c 2009-04-23 18:49:40 +0000
+++ src/libCom/macLib/macEnv.c 2010-10-06 18:12:40 +0000
@@ -4,7 +4,7 @@
-/* $Id$
+/* $Revision-Id$
* Macro expansion of environment variables
=== modified file 'src/libCom/macLib/macLib.h'
--- src/libCom/macLib/macLib.h 2010-05-04 20:43:20 +0000
+++ src/libCom/macLib/macLib.h 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$
+/* $Revision-Id$
* Definitions for macro substitution library (macLib)
=== modified file 'src/libCom/macLib/macLibNOTES'
--- src/libCom/macLib/macLibNOTES 1996-07-10 14:49:55 +0000
+++ src/libCom/macLib/macLibNOTES 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
# Test input file for macTest filter, doubling as notes on usage of the
# macro library. Some special strings at start of line are supported:
=== modified file 'src/libCom/macLib/macUtil.c'
--- src/libCom/macLib/macUtil.c 2010-05-27 10:47:07 +0000
+++ src/libCom/macLib/macUtil.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$
+/* $Revision-Id$
* Implementation of utility macro substitution library (macLib)
=== modified file 'src/libCom/misc/cantProceed.c'
--- src/libCom/misc/cantProceed.c 2008-07-29 20:47:11 +0000
+++ src/libCom/misc/cantProceed.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
/* Author: Marty Kraimer Date: 04JAN99 */
=== removed file 'src/libCom/misc/createSoftLinks.sh'
--- src/libCom/misc/createSoftLinks.sh 1996-01-25 21:39:01 +0000
+++ src/libCom/misc/createSoftLinks.sh 1970-01-01 00:00:00 +0000
@@ -1,12 +0,0 @@
-#! /bin/sh
-# createSoftLinks.sh
-# $Id$
-# Tailored script to create local softlinks releative to this directory
-# the name createSoftLinks.sh is a key and must not be changed. If the
-# release tool sccsGet finds a file by the name of (createSoftLinks.sh),
-# after it has retrieved any out-of-date SCCS files, it invokes the
-# script to create the defined softlinks
-/bin/rm -f epicsVersion.h
-ln -s ../version/epicsVersion.h epicsVersion.h
=== modified file 'src/libCom/misc/dbDefs.h'
--- src/libCom/misc/dbDefs.h 2009-08-04 16:31:06 +0000
+++ src/libCom/misc/dbDefs.h 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$
+/* $Revision-Id$
* Date: 6-1-90
=== modified file 'src/libCom/misc/epicsString.c'
--- src/libCom/misc/epicsString.c 2009-04-10 19:58:34 +0000
+++ src/libCom/misc/epicsString.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
/* Authors: Jun-ichi Odagiri, Marty Kraimer, Eric Norum,
* Mark Rivers, Andrew Johnson, Ralph Lange
=== modified file 'src/libCom/misc/epicsString.h'
--- src/libCom/misc/epicsString.h 2009-04-10 19:58:34 +0000
+++ src/libCom/misc/epicsString.h 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
=== modified file 'src/libCom/misc/epicsTypes.h'
--- src/libCom/misc/epicsTypes.h 2009-06-05 19:56:33 +0000
+++ src/libCom/misc/epicsTypes.h 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
* Author: Jeff Hill
=== modified file 'src/libCom/misc/epicsUnitTest.c'
--- src/libCom/misc/epicsUnitTest.c 2009-04-23 22:19:46 +0000
+++ src/libCom/misc/epicsUnitTest.c 2010-10-06 18:12:40 +0000
@@ -5,7 +5,7 @@
-/* $Id$
+/* $Revision-Id$
* Author: Andrew Johnson
* Unit test module which generates output in the Test Anything Protocol
=== modified file 'src/libCom/misc/epicsUnitTest.h'
--- src/libCom/misc/epicsUnitTest.h 2009-04-03 17:46:26 +0000
+++ src/libCom/misc/epicsUnitTest.h 2010-10-06 18:12:40 +0000
@@ -5,7 +5,7 @@
-/* $Id$
+/* $Revision-Id$
=== modified file 'src/libCom/misc/ipAddrToAsciiAsynchronous.h'
--- src/libCom/misc/ipAddrToAsciiAsynchronous.h 2003-09-01 20:05:12 +0000
+++ src/libCom/misc/ipAddrToAsciiAsynchronous.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* L O S A L A M O S
=== modified file 'src/libCom/misc/locationException.h'
--- src/libCom/misc/locationException.h 2002-07-12 21:35:43 +0000
+++ src/libCom/misc/locationException.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
-// $Id$
+// $Revision-Id$
=== modified file 'src/libCom/misc/makeEpicsVersion.pl'
--- src/libCom/misc/makeEpicsVersion.pl 2005-12-20 14:56:46 +0000
+++ src/libCom/misc/makeEpicsVersion.pl 2010-10-06 18:12:40 +0000
@@ -1,60 +1,73 @@
#!/usr/bin/perl
-# Copyright (c) 2002 The University of Chicago, as Operator of Argonne
+# Copyright (c) 2010 UChicago Argonne LLC, as Operator of Argonne
# National Laboratory.
# Copyright (c) 2002 The Regents of the University of California, as
# Operator of Los Alamos National Laboratory.
-# EPICS BASE Versions 3.13.7
-# and higher are distributed subject to a Software License Agreement found
+# EPICS BASE is distributed subject to a Software License Agreement found
-($infile, $outdir, $site_ver) = @ARGV;
+use strict;
+my ($ver, $rev, $mod, $patch, $snapshot, $commit_date);
+my ($infile, $outdir, $site_ver) = @ARGV;
die "Usage: perl makeEpicsVersion.pl CONFIG_BASE_VERSION outdir siteversion"
unless ($infile && $outdir);
print "Building epicsVersion.h from $infile\n";
-open VARS, $infile or die "Can't open $infile: $!\n";
+open my $VARS, '<', $infile
+ or die "Can't open $infile: $!\n";
-while (<VARS>)
- chomp;
- next if m/^#/; # Skip comments
- if (m/^EPICS_VERSION\s*=\s*(\d+)/) { $ver = $1; }
- if (m/^EPICS_REVISION\s*=\s*(\d+)/) { $rev = $1; }
- if (m/^EPICS_MODIFICATION\s*=\s*([0-9a-z]+)/) { $mod = $1; }
- if (m/^EPICS_PATCH_LEVEL\s*=\s*(\d+)/) { $patch = $1; }
- if (m/^EPICS_CVS_SNAPSHOT\s*=\s*([CVS-]+)/) { $snapshot = $1; }
- if (m/^CVS_DATE\s*=\s*"\\(.*)"/) { $cvs_date = $1; }
- if (m/^CVS_TAG\s*=\s*"\\(.*)"/) { $cvs_tag = $1; }
+while (<$VARS>) {
+ chomp;
+ next if m/^\s*#/; # Skip comments
+ if (m/^EPICS_VERSION\s*=\s*(\d+)/) { $ver = $1; }
+ if (m/^EPICS_REVISION\s*=\s*(\d+)/) { $rev = $1; }
+ if (m/^EPICS_MODIFICATION\s*=\s*([0-9a-z]+)/) { $mod = $1; }
+ if (m/^EPICS_PATCH_LEVEL\s*=\s*(\d+)/) { $patch = $1; }
+ if (m/^EPICS_DEV_SNAPSHOT\s*=\s*([DEV-]+)/) { $snapshot = $1; }
+ if (m/^COMMIT_DATE\s*=\s*"\\(.*)"/) { $commit_date = $1; }
-$ver_str = "$ver.$rev.$mod";
+close $VARS;
+map {
+ die "Variable missing from $infile" unless defined $_;
+} $ver, $rev, $mod, $patch, $snapshot, $commit_date;
+my $ver_str = "$ver.$rev.$mod";
$ver_str .= ".$patch" if $patch > 0;
$ver_str .= $snapshot if $snapshot ne '';
$ver_str .= "-$site_ver" if $site_ver;
print "Found EPICS Version $ver_str\n";
-$epicsVersion="$outdir/epicsVersion.h";
+my $epicsVersion="$outdir/epicsVersion.h";
mkdir ($outdir, 0777) unless -d $outdir;
-open OUT, "> $epicsVersion" or die "Cannot create $epicsVersion: $!\n";
-print OUT "#define EPICS_VERSION $ver\n";
-print OUT "#define EPICS_REVISION $rev\n";
-print OUT "#define EPICS_MODIFICATION $mod\n";
-print OUT "#define EPICS_PATCH_LEVEL $patch\n";
-print OUT "#define EPICS_CVS_SNAPSHOT \"$snapshot\"\n";
-print OUT "#define EPICS_SITE_VERSION \"$site_ver\"\n";
-print OUT "#define EPICS_VERSION_STRING \"EPICS $ver_str\"\n";
-print OUT "#define epicsReleaseVersion \"EPICS R$ver_str $cvs_tag $cvs_date\"\n";
-print OUT "\n";
-print OUT "/* EPICS_UPDATE_LEVEL is deprecated, use EPICS_PATCH_LEVEL instead */\n";
-print OUT "#define EPICS_UPDATE_LEVEL $patch\n";
-close OUT;
+open my $OUT, '>', $epicsVersion
+ or die "Cannot create $epicsVersion: $!\n";
+print $OUT <<"END_OUTPUT";
+/* Generated epicsVersion.h */
+#define EPICS_VERSION $ver
+#define EPICS_REVISION $rev
+#define EPICS_MODIFICATION $mod
+#define EPICS_PATCH_LEVEL $patch
+#define EPICS_DEV_SNAPSHOT "$snapshot"
+#define EPICS_SITE_VERSION "$site_ver"
+#define EPICS_VERSION_STRING "EPICS $ver_str"
+#define epicsReleaseVersion "EPICS R$ver_str $commit_date"
+/* The following names are deprecated, use the equivalent name above */
+#define EPICS_UPDATE_LEVEL EPICS_PATCH_LEVEL
+#define EPICS_CVS_SNAPSHOT EPICS_DEV_SNAPSHOT
+END_OUTPUT
+close $OUT;
=== modified file 'src/libCom/misc/testMain.h'
--- src/libCom/misc/testMain.h 2006-11-10 22:43:04 +0000
+++ src/libCom/misc/testMain.h 2010-10-06 18:12:40 +0000
@@ -4,7 +4,7 @@
-/* $Id$ */
#ifndef INC_testMain_H
#define INC_testMain_H
=== modified file 'src/libCom/osi/devLib.h'
--- src/libCom/osi/devLib.h 2010-05-26 16:17:26 +0000
+++ src/libCom/osi/devLib.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
/* devLib.h */
-/* $Id$ */
* Original Author: Marty Kraimer
=== modified file 'src/libCom/osi/devLibVME.c'
--- src/libCom/osi/devLibVME.c 2010-05-26 16:17:26 +0000
+++ src/libCom/osi/devLibVME.c 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
* in file LICENSE that is included with this distribution.
/* devLib.c - support for allocation of common device resources */
-/* $Id$ */
+/* $Revision-Id$ */
@@ -20,7 +20,7 @@
* .01 06-14-93 joh needs devAllocInterruptVector() routine
-static const char sccsID[] = "@(#) $Id$";
+static const char sccsID[] = "@(#) $Revision-Id$";
#include <string.h>
#include <stdio.h>
=== modified file 'src/libCom/osi/epicsAssert.h'
--- src/libCom/osi/epicsAssert.h 2009-08-04 19:07:07 +0000
+++ src/libCom/osi/epicsAssert.h 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$ */
* EPICS assert
=== modified file 'src/libCom/osi/epicsMessageQueue.cpp'
--- src/libCom/osi/epicsMessageQueue.cpp 2004-08-27 16:04:26 +0000
+++ src/libCom/osi/epicsMessageQueue.cpp 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* Author W. Eric Norum
* [email protected]
=== modified file 'src/libCom/osi/epicsMessageQueue.h'
--- src/libCom/osi/epicsMessageQueue.h 2008-07-29 20:12:09 +0000
+++ src/libCom/osi/epicsMessageQueue.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/libCom/osi/epicsThread.cpp'
--- src/libCom/osi/epicsThread.cpp 2009-08-24 17:08:41 +0000
+++ src/libCom/osi/epicsThread.cpp 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-// $Id$
+// $Revision-Id$
=== modified file 'src/libCom/osi/os/Darwin/osdEnv.c'
--- src/libCom/osi/os/Darwin/osdEnv.c 2009-02-23 18:11:40 +0000
+++ src/libCom/osi/os/Darwin/osdEnv.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
/* osdEnv.c */
- * $Id$
+ * $Revision-Id$
* Author: Eric Norum
* Date: May 7, 2001
=== modified file 'src/libCom/osi/os/Darwin/osdSock.h'
--- src/libCom/osi/os/Darwin/osdSock.h 2005-06-28 20:34:12 +0000
+++ src/libCom/osi/os/Darwin/osdSock.h 2010-10-06 18:12:40 +0000
@@ -5,7 +5,7 @@
- * $Id$
+ * $Revision-Id$
=== modified file 'src/libCom/osi/os/Darwin/osdSockAddrReuse.cpp'
--- src/libCom/osi/os/Darwin/osdSockAddrReuse.cpp 2003-08-21 18:27:00 +0000
+++ src/libCom/osi/os/Darwin/osdSockAddrReuse.cpp 2010-10-06 18:12:40 +0000
@@ -10,7 +10,7 @@
- * $Id$
+ * $Revision-Id$
* Author: Jeff Hill
=== modified file 'src/libCom/osi/os/Darwin/osdTime.h'
--- src/libCom/osi/os/Darwin/osdTime.h 2009-04-23 18:49:40 +0000
+++ src/libCom/osi/os/Darwin/osdTime.h 2010-10-06 18:12:40 +0000
@@ -4,7 +4,7 @@
- * $Id$
+ * $Revision-Id$
=== modified file 'src/libCom/osi/os/Darwin/osiFileName.h'
--- src/libCom/osi/os/Darwin/osiFileName.h 2002-07-12 21:35:43 +0000
+++ src/libCom/osi/os/Darwin/osiFileName.h 2010-10-06 18:12:40 +0000
@@ -5,7 +5,7 @@
- * $Id$
+ * $Revision-Id$
=== modified file 'src/libCom/osi/os/Linux/osdTime.h'
--- src/libCom/osi/os/Linux/osdTime.h 2004-08-12 13:38:17 +0000
+++ src/libCom/osi/os/Linux/osdTime.h 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
- * $Id$
+ * $Revision-Id$
=== modified file 'src/libCom/osi/os/Linux/osiUnistd.h'
--- src/libCom/osi/os/Linux/osiUnistd.h 2003-03-03 21:53:19 +0000
+++ src/libCom/osi/os/Linux/osiUnistd.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* L O S A L A M O S
=== modified file 'src/libCom/osi/os/RTEMS/devLibVMEOSD.c'
--- src/libCom/osi/os/RTEMS/devLibVMEOSD.c 2010-05-27 08:35:29 +0000
+++ src/libCom/osi/os/RTEMS/devLibVMEOSD.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$ */
/* RTEMS port by Till Straumann, <[email protected]>
* 3/2002
=== modified file 'src/libCom/osi/os/RTEMS/osdEvent.c'
--- src/libCom/osi/os/RTEMS/osdEvent.c 2008-10-16 13:38:14 +0000
+++ src/libCom/osi/os/RTEMS/osdEvent.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
* RTEMS osdEvent.c
- * $Id$
+ * $Revision-Id$
* Author: W. Eric Norum
* [email protected]
* (306) 966-6055
=== modified file 'src/libCom/osi/os/RTEMS/osdEvent.h'
--- src/libCom/osi/os/RTEMS/osdEvent.h 2002-07-12 21:35:43 +0000
+++ src/libCom/osi/os/RTEMS/osdEvent.h 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
* RTEMS osdEvent.h
- * $Id$
+ * $Revision-Id$
* [email protected]
* (306) 966-6055
=== modified file 'src/libCom/osi/os/RTEMS/osdInterrupt.c'
--- src/libCom/osi/os/RTEMS/osdInterrupt.c 2009-04-24 17:01:39 +0000
+++ src/libCom/osi/os/RTEMS/osdInterrupt.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
* RTEMS osdInterrupt.c
- * $Id$
+ * $Revision-Id$
* [email protected]
* (306) 966-6055
=== modified file 'src/libCom/osi/os/RTEMS/osdMessageQueue.c'
--- src/libCom/osi/os/RTEMS/osdMessageQueue.c 2009-04-24 17:01:39 +0000
+++ src/libCom/osi/os/RTEMS/osdMessageQueue.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/libCom/osi/os/RTEMS/osdMessageQueue.h'
--- src/libCom/osi/os/RTEMS/osdMessageQueue.h 2003-05-29 03:10:16 +0000
+++ src/libCom/osi/os/RTEMS/osdMessageQueue.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/libCom/osi/os/RTEMS/osdMutex.c'
--- src/libCom/osi/os/RTEMS/osdMutex.c 2004-09-16 19:29:09 +0000
+++ src/libCom/osi/os/RTEMS/osdMutex.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
* RTEMS osdMutex.c
- * $Id$
+ * $Revision-Id$
* [email protected]
* (306) 966-6055
=== modified file 'src/libCom/osi/os/RTEMS/osdMutex.h'
--- src/libCom/osi/os/RTEMS/osdMutex.h 2002-07-12 21:35:43 +0000
+++ src/libCom/osi/os/RTEMS/osdMutex.h 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
* RTEMS osdMutex.h
- * $Id$
+ * $Revision-Id$
* [email protected]
* (306) 966-6055
=== modified file 'src/libCom/osi/os/RTEMS/osdProcess.c'
--- src/libCom/osi/os/RTEMS/osdProcess.c 2002-07-12 21:35:43 +0000
+++ src/libCom/osi/os/RTEMS/osdProcess.c 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* Operating System Dependent Implementation of osiProcess.h
=== modified file 'src/libCom/osi/os/RTEMS/osdSock.h'
--- src/libCom/osi/os/RTEMS/osdSock.h 2009-12-22 17:43:25 +0000
+++ src/libCom/osi/os/RTEMS/osdSock.h 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
* RTEMS osdSock.h
- * $Id$
+ * $Revision-Id$
* [email protected]
* (306) 966-6055
=== modified file 'src/libCom/osi/os/RTEMS/osdThread.c'
--- src/libCom/osi/os/RTEMS/osdThread.c 2010-05-14 22:26:54 +0000
+++ src/libCom/osi/os/RTEMS/osdThread.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
* RTEMS osdThread.c
- * $Id$
+ * $Revision-Id$
* [email protected]
* (306) 966-6055
=== modified file 'src/libCom/osi/os/RTEMS/osdTime.cpp'
--- src/libCom/osi/os/RTEMS/osdTime.cpp 2010-07-19 19:01:41 +0000
+++ src/libCom/osi/os/RTEMS/osdTime.cpp 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
- * $Id$
+ * $Revision-Id$
=== modified file 'src/libCom/osi/os/RTEMS/osdTime.h'
--- src/libCom/osi/os/RTEMS/osdTime.h 2008-09-12 22:55:55 +0000
+++ src/libCom/osi/os/RTEMS/osdTime.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
=== modified file 'src/libCom/osi/os/RTEMS/osdVME.h'
--- src/libCom/osi/os/RTEMS/osdVME.h 2006-09-19 16:18:26 +0000
+++ src/libCom/osi/os/RTEMS/osdVME.h 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
* and higher are distributed subject to a Software License Agreement found
-/* $Id$ */
* OS-dependent VME support
=== modified file 'src/libCom/osi/os/RTEMS/osiFileName.h'
--- src/libCom/osi/os/RTEMS/osiFileName.h 2002-07-12 21:35:43 +0000
+++ src/libCom/osi/os/RTEMS/osiFileName.h 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
* RTEMS osiFileName.h
- * $Id$
+ * $Revision-Id$
* [email protected]
* (306) 966-6055
=== modified file 'src/libCom/osi/os/RTEMS/osiUnistd.h'
--- src/libCom/osi/os/RTEMS/osiUnistd.h 2004-09-14 23:09:33 +0000
+++ src/libCom/osi/os/RTEMS/osiUnistd.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* L O S A L A M O S
=== modified file 'src/libCom/osi/os/WIN32/epicsSocketConvertErrnoToString.cpp'
--- src/libCom/osi/os/WIN32/epicsSocketConvertErrnoToString.cpp 2003-04-24 22:37:35 +0000
+++ src/libCom/osi/os/WIN32/epicsSocketConvertErrnoToString.cpp 2010-10-06 18:12:40 +0000
@@ -10,7 +10,7 @@
- * $Id$
+ * $Revision-Id$
#include <stdio.h>
=== modified file 'src/libCom/osi/os/WIN32/epicsTempFile.cpp'
--- src/libCom/osi/os/WIN32/epicsTempFile.cpp 2009-06-05 19:10:46 +0000
+++ src/libCom/osi/os/WIN32/epicsTempFile.cpp 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* Author: Jeff Hill
=== modified file 'src/libCom/osi/os/WIN32/osdEvent.c'
--- src/libCom/osi/os/WIN32/osdEvent.c 2002-11-26 23:24:16 +0000
+++ src/libCom/osi/os/WIN32/osdEvent.c 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
/* osdEvent.c */
- * $Id$
+ * $Revision-Id$
* WIN32 version
* Author Jeffrey O. Hill
=== modified file 'src/libCom/osi/os/WIN32/osdEvent.h'
--- src/libCom/osi/os/WIN32/osdEvent.h 2002-07-12 21:35:43 +0000
+++ src/libCom/osi/os/WIN32/osdEvent.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
/* osdEvent.c */
- * $Id$
+ * $Revision-Id$
* WIN32 version
=== modified file 'src/libCom/osi/os/WIN32/osdMutex.c'
--- src/libCom/osi/os/WIN32/osdMutex.c 2006-12-05 22:54:52 +0000
+++ src/libCom/osi/os/WIN32/osdMutex.c 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
/* osdMutex.c */
- * $Id$
+ * $Revision-Id$
* WIN32 version
=== modified file 'src/libCom/osi/os/WIN32/osdMutex.h'
--- src/libCom/osi/os/WIN32/osdMutex.h 2002-07-12 21:35:43 +0000
+++ src/libCom/osi/os/WIN32/osdMutex.h 2010-10-06 18:12:40 +0000
@@ -10,7 +10,7 @@
/* osdMutex.h */
- * $Id$
+ * $Revision-Id$
* WIN32 version
=== modified file 'src/libCom/osi/os/WIN32/osdNetIntf.c'
--- src/libCom/osi/os/WIN32/osdNetIntf.c 2006-11-18 00:13:53 +0000
+++ src/libCom/osi/os/WIN32/osdNetIntf.c 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* WIN32 specific initialisation for bsd sockets,
* based on Chris Timossi's base/src/ca/windows_depend.c,
=== modified file 'src/libCom/osi/os/WIN32/osdProcess.c'
--- src/libCom/osi/os/WIN32/osdProcess.c 2010-06-16 19:46:09 +0000
+++ src/libCom/osi/os/WIN32/osdProcess.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
=== modified file 'src/libCom/osi/os/WIN32/osdSock.c'
--- src/libCom/osi/os/WIN32/osdSock.c 2003-07-16 22:05:54 +0000
+++ src/libCom/osi/os/WIN32/osdSock.c 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
=== modified file 'src/libCom/osi/os/WIN32/osdSockAddrReuse.cpp'
--- src/libCom/osi/os/WIN32/osdSockAddrReuse.cpp 2003-08-21 18:27:00 +0000
+++ src/libCom/osi/os/WIN32/osdSockAddrReuse.cpp 2010-10-06 18:12:40 +0000
@@ -10,7 +10,7 @@
- * $Id$
+ * $Revision-Id$
* Author: Jeff Hill
=== modified file 'src/libCom/osi/os/WIN32/osdThread.c'
--- src/libCom/osi/os/WIN32/osdThread.c 2010-08-14 00:15:49 +0000
+++ src/libCom/osi/os/WIN32/osdThread.c 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* Author: Jeff Hill
=== modified file 'src/libCom/osi/os/WIN32/osdTime.cpp'
--- src/libCom/osi/os/WIN32/osdTime.cpp 2008-12-09 21:46:40 +0000
+++ src/libCom/osi/os/WIN32/osdTime.cpp 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-// $Id$
+// $Revision-Id$
=== modified file 'src/libCom/osi/os/WIN32/osdTime.h'
--- src/libCom/osi/os/WIN32/osdTime.h 2004-03-29 19:55:34 +0000
+++ src/libCom/osi/os/WIN32/osdTime.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* Author: Jeff Hill
=== modified file 'src/libCom/osi/os/WIN32/osiUnistd.h'
--- src/libCom/osi/os/WIN32/osiUnistd.h 2002-07-12 21:35:43 +0000
+++ src/libCom/osi/os/WIN32/osiUnistd.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* L O S A L A M O S
=== modified file 'src/libCom/osi/os/WIN32/systemCallIntMech.cpp'
--- src/libCom/osi/os/WIN32/systemCallIntMech.cpp 2003-04-24 16:32:59 +0000
+++ src/libCom/osi/os/WIN32/systemCallIntMech.cpp 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-/* $Id$ */
* Author: Jeff Hill
=== modified file 'src/libCom/osi/os/cygwin32/devLibVMEOSD.c'
--- src/libCom/osi/os/cygwin32/devLibVMEOSD.c 2010-05-26 16:17:26 +0000
+++ src/libCom/osi/os/cygwin32/devLibVMEOSD.c 2010-10-06 18:12:40 +0000
@@ -5,7 +5,7 @@
-/* $Id$ */
#include <stdlib.h>
=== modified file 'src/libCom/osi/os/cygwin32/osdSockAddrReuse.cpp'
--- src/libCom/osi/os/cygwin32/osdSockAddrReuse.cpp 2008-09-25 16:35:15 +0000
+++ src/libCom/osi/os/cygwin32/osdSockAddrReuse.cpp 2010-10-06 18:12:40 +0000
@@ -10,7 +10,7 @@
- * $Id$
+ * $Revision-Id$
* Author: Jeff Hill
=== modified file 'src/libCom/osi/os/default/devLibVMEOSD.c'
--- src/libCom/osi/os/default/devLibVMEOSD.c 2010-05-26 16:17:26 +0000
+++ src/libCom/osi/os/default/devLibVMEOSD.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$ */
#include <stdlib.h>
=== modified file 'src/libCom/osi/os/default/epicsReadline.c'
--- src/libCom/osi/os/default/epicsReadline.c 2009-09-29 18:58:04 +0000
+++ src/libCom/osi/os/default/epicsReadline.c 2010-10-06 18:12:40 +0000
@@ -5,7 +5,7 @@
-/* $Id$ */
/* Author: Eric Norum Date: 12DEC2001 */
#include <stdio.h>
=== modified file 'src/libCom/osi/os/default/epicsSocketConvertErrnoToString.cpp'
--- src/libCom/osi/os/default/epicsSocketConvertErrnoToString.cpp 2003-04-24 17:09:58 +0000
+++ src/libCom/osi/os/default/epicsSocketConvertErrnoToString.cpp 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
/* osdSock.c */
-/* $Id$ */
* Author: Jeff Hill
* Date: 04-05-94
=== modified file 'src/libCom/osi/os/default/osdAssert.c'
--- src/libCom/osi/os/default/osdAssert.c 2009-07-02 19:49:11 +0000
+++ src/libCom/osi/os/default/osdAssert.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$ */
* Author: Jeffrey Hill
* Date: 02-27-95
=== modified file 'src/libCom/osi/os/default/osdEnv.c'
--- src/libCom/osi/os/default/osdEnv.c 2004-08-27 16:04:26 +0000
+++ src/libCom/osi/os/default/osdEnv.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
/* osdEnv.c */
- * $Id$
+ * $Revision-Id$
* Date: May 7, 2001
=== modified file 'src/libCom/osi/os/default/osdMessageQueue.cpp'
--- src/libCom/osi/os/default/osdMessageQueue.cpp 2010-01-11 23:56:17 +0000
+++ src/libCom/osi/os/default/osdMessageQueue.cpp 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/libCom/osi/os/default/osdNetIntf.c'
--- src/libCom/osi/os/default/osdNetIntf.c 2006-11-18 00:13:53 +0000
+++ src/libCom/osi/os/default/osdNetIntf.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-/* $Id$ */
* Author: Jeff Hill
* Date: 04-05-94
=== modified file 'src/libCom/osi/os/default/osdVME.h'
--- src/libCom/osi/os/default/osdVME.h 2004-11-13 17:16:22 +0000
+++ src/libCom/osi/os/default/osdVME.h 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
=== modified file 'src/libCom/osi/os/freebsd/osdTime.h'
--- src/libCom/osi/os/freebsd/osdTime.h 2006-11-14 19:40:47 +0000
+++ src/libCom/osi/os/freebsd/osdTime.h 2010-10-06 18:12:40 +0000
@@ -5,7 +5,7 @@
- * $Id$
+ * $Revision-Id$
=== modified file 'src/libCom/osi/os/freebsd/osiUnistd.h'
--- src/libCom/osi/os/freebsd/osiUnistd.h 2006-11-14 19:40:47 +0000
+++ src/libCom/osi/os/freebsd/osiUnistd.h 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
- * $Id$
+ * $Revision-Id$
* L O S A L A M O S
=== modified file 'src/libCom/osi/os/iOS/osdEnv.c'
--- src/libCom/osi/os/iOS/osdEnv.c 2010-09-22 21:26:15 +0000
+++ src/libCom/osi/os/iOS/osdEnv.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
/* osdEnv.c */
- * $Id$
+ * $Revision-Id$
* Date: May 7, 2001
=== modified file 'src/libCom/osi/os/iOS/osdSock.h'
--- src/libCom/osi/os/iOS/osdSock.h 2010-09-22 21:26:15 +0000
+++ src/libCom/osi/os/iOS/osdSock.h 2010-10-06 18:12:40 +0000
@@ -5,7 +5,7 @@
- * $Id$
+ * $Revision-Id$
=== modified file 'src/libCom/osi/os/iOS/osdSockAddrReuse.cpp'
--- src/libCom/osi/os/iOS/osdSockAddrReuse.cpp 2010-09-22 21:26:15 +0000
+++ src/libCom/osi/os/iOS/osdSockAddrReuse.cpp 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* Author: Jeff Hill
=== modified file 'src/libCom/osi/os/iOS/osdTime.h'
--- src/libCom/osi/os/iOS/osdTime.h 2010-09-22 21:26:15 +0000
+++ src/libCom/osi/os/iOS/osdTime.h 2010-10-06 18:12:40 +0000
@@ -5,7 +5,7 @@
- * $Id$
+ * $Revision-Id$
=== modified file 'src/libCom/osi/os/iOS/osiFileName.h'
--- src/libCom/osi/os/iOS/osiFileName.h 2010-09-22 21:26:15 +0000
+++ src/libCom/osi/os/iOS/osiFileName.h 2010-10-06 18:12:40 +0000
@@ -5,7 +5,7 @@
- * $Id$
+ * $Revision-Id$
=== modified file 'src/libCom/osi/os/posix/osdProcess.c'
--- src/libCom/osi/os/posix/osdProcess.c 2010-05-03 17:29:13 +0000
+++ src/libCom/osi/os/posix/osdProcess.c 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
=== modified file 'src/libCom/osi/os/posix/osdSock.c'
--- src/libCom/osi/os/posix/osdSock.c 2003-07-16 22:09:58 +0000
+++ src/libCom/osi/os/posix/osdSock.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* osdSock.c */
-/* $Id$ */
* Author: Jeff Hill
* Date: 04-05-94
=== modified file 'src/libCom/osi/os/posix/osdSockAddrReuse.cpp'
--- src/libCom/osi/os/posix/osdSockAddrReuse.cpp 2003-08-21 18:27:00 +0000
+++ src/libCom/osi/os/posix/osdSockAddrReuse.cpp 2010-10-06 18:12:40 +0000
@@ -10,7 +10,7 @@
- * $Id$
+ * $Revision-Id$
* Author: Jeff Hill
=== modified file 'src/libCom/osi/os/posix/osdTime.h'
--- src/libCom/osi/os/posix/osdTime.h 2004-01-30 01:25:16 +0000
+++ src/libCom/osi/os/posix/osdTime.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* Author: Jeff Hill
=== modified file 'src/libCom/osi/os/posix/osiUnistd.h'
--- src/libCom/osi/os/posix/osiUnistd.h 2002-07-12 21:35:43 +0000
+++ src/libCom/osi/os/posix/osiUnistd.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* L O S A L A M O S
=== modified file 'src/libCom/osi/os/posix/systemCallIntMech.cpp'
--- src/libCom/osi/os/posix/systemCallIntMech.cpp 2008-08-19 21:52:11 +0000
+++ src/libCom/osi/os/posix/systemCallIntMech.cpp 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-/* $Id$ */
* Author: Jeff Hill
=== modified file 'src/libCom/osi/os/vxWorks/camacLib.h'
--- src/libCom/osi/os/vxWorks/camacLib.h 2003-08-05 18:38:18 +0000
+++ src/libCom/osi/os/vxWorks/camacLib.h 2010-10-06 18:12:40 +0000
@@ -14,7 +14,7 @@
-static char ht2992_h_RCSID[] = "$Header$";
+static char ht2992_h_RCSID[] = "$Revision-Id$";
/* GLOBAL DATA */
=== modified file 'src/libCom/osi/os/vxWorks/devLibVMEOSD.c'
--- src/libCom/osi/os/vxWorks/devLibVMEOSD.c 2010-05-26 16:17:26 +0000
+++ src/libCom/osi/os/vxWorks/devLibVMEOSD.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
- * $Id$
+ * $Revision-Id$
* Archictecture dependent support for common device driver resources
=== modified file 'src/libCom/osi/os/vxWorks/logMsgToErrlog.cpp'
--- src/libCom/osi/os/vxWorks/logMsgToErrlog.cpp 2003-08-06 18:17:30 +0000
+++ src/libCom/osi/os/vxWorks/logMsgToErrlog.cpp 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* route vxWorks logMsg messages into the EPICS logging system
=== modified file 'src/libCom/osi/os/vxWorks/module_types.h'
--- src/libCom/osi/os/vxWorks/module_types.h 2003-08-05 18:38:18 +0000
+++ src/libCom/osi/os/vxWorks/module_types.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* module_types.h */
* Date: 12-07-88
=== modified file 'src/libCom/osi/os/vxWorks/osdEnv.c'
--- src/libCom/osi/os/vxWorks/osdEnv.c 2010-08-11 15:45:17 +0000
+++ src/libCom/osi/os/vxWorks/osdEnv.c 2010-10-06 18:12:40 +0000
@@ -5,7 +5,7 @@
/* osdEnv.c */
- * $Id$
+ * $Revision-Id$
* Date: May 7, 2001
=== modified file 'src/libCom/osi/os/vxWorks/osdMessageQueue.cpp'
--- src/libCom/osi/os/vxWorks/osdMessageQueue.cpp 2003-05-29 03:10:16 +0000
+++ src/libCom/osi/os/vxWorks/osdMessageQueue.cpp 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/libCom/osi/os/vxWorks/osdMessageQueue.h'
--- src/libCom/osi/os/vxWorks/osdMessageQueue.h 2003-05-29 21:03:39 +0000
+++ src/libCom/osi/os/vxWorks/osdMessageQueue.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/libCom/osi/os/vxWorks/osdProcess.c'
--- src/libCom/osi/os/vxWorks/osdProcess.c 2010-08-11 15:45:17 +0000
+++ src/libCom/osi/os/vxWorks/osdProcess.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
=== modified file 'src/libCom/osi/os/vxWorks/osdVME.h'
--- src/libCom/osi/os/vxWorks/osdVME.h 2004-11-13 17:16:22 +0000
+++ src/libCom/osi/os/vxWorks/osdVME.h 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
=== modified file 'src/libCom/osi/os/vxWorks/task_params.h'
--- src/libCom/osi/os/vxWorks/task_params.h 2003-08-05 18:38:18 +0000
+++ src/libCom/osi/os/vxWorks/task_params.h 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
/* Parameters for tasks on IOC */
=== modified file 'src/libCom/osi/os/vxWorks/veclist.c'
--- src/libCom/osi/os/vxWorks/veclist.c 2009-07-09 16:37:24 +0000
+++ src/libCom/osi/os/vxWorks/veclist.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* @(#)veclist.c 1.10
* list fuctions attached to the interrupt vector table
@@ -42,7 +42,7 @@
#include "sysSymTbl.h"
- "@(#) $Id$";
+ "@(#) $Revision-Id$";
=== modified file 'src/libCom/osi/osiPoolStatus.h'
--- src/libCom/osi/osiPoolStatus.h 2002-07-12 21:35:43 +0000
+++ src/libCom/osi/osiPoolStatus.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* Author: Jeff Hill
=== modified file 'src/libCom/osi/osiProcess.h'
--- src/libCom/osi/osiProcess.h 2002-07-12 21:35:43 +0000
+++ src/libCom/osi/osiProcess.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* Operating System Independent Interface to Process Environment
=== modified file 'src/libCom/osi/osiSock.c'
--- src/libCom/osi/osiSock.c 2004-10-19 18:21:02 +0000
+++ src/libCom/osi/osiSock.c 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* socket support library generic code
=== modified file 'src/libCom/osi/osiSock.h'
--- src/libCom/osi/osiSock.h 2009-06-04 21:31:39 +0000
+++ src/libCom/osi/osiSock.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* socket support library API def
=== modified file 'src/libCom/taskwd/taskwd.h'
--- src/libCom/taskwd/taskwd.h 2008-05-22 17:54:19 +0000
+++ src/libCom/taskwd/taskwd.h 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
/* General purpose task watchdog */
=== modified file 'src/libCom/test/epicsCalcTest.cpp'
--- src/libCom/test/epicsCalcTest.cpp 2009-08-21 14:49:01 +0000
+++ src/libCom/test/epicsCalcTest.cpp 2010-10-06 18:12:40 +0000
@@ -4,7 +4,7 @@
* EPICS BASE is distributed subject to a Software License Agreement found
-// $Id$
+// $Revision-Id$
#include "epicsUnitTest.h"
=== modified file 'src/libCom/test/epicsMessageQueueTest.cpp'
--- src/libCom/test/epicsMessageQueueTest.cpp 2010-05-18 21:12:36 +0000
+++ src/libCom/test/epicsMessageQueueTest.cpp 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/libCom/test/epicsStringTest.c'
--- src/libCom/test/epicsStringTest.c 2010-09-29 22:44:10 +0000
+++ src/libCom/test/epicsStringTest.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$
+/* $Revision-Id$
* Author Marty Kraimer
=== modified file 'src/libCom/test/epicsThreadOnceTest.c'
--- src/libCom/test/epicsThreadOnceTest.c 2010-04-26 20:48:42 +0000
+++ src/libCom/test/epicsThreadOnceTest.c 2010-10-06 18:12:40 +0000
@@ -4,7 +4,7 @@
-/* $Id$ */
#include <stdio.h>
#include <string.h>
=== modified file 'src/libCom/test/epicsThreadPrivateTest.cpp'
--- src/libCom/test/epicsThreadPrivateTest.cpp 2008-08-28 15:32:46 +0000
+++ src/libCom/test/epicsThreadPrivateTest.cpp 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$ */
/* Author: Jeff Hill Date: March 28 2001 */
=== modified file 'src/libCom/test/epicsTimerTest.cpp'
--- src/libCom/test/epicsTimerTest.cpp 2009-08-24 17:07:03 +0000
+++ src/libCom/test/epicsTimerTest.cpp 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/libCom/test/epicsUnitTestTest.c'
--- src/libCom/test/epicsUnitTestTest.c 2009-04-03 17:46:26 +0000
+++ src/libCom/test/epicsUnitTestTest.c 2010-10-06 18:12:40 +0000
@@ -5,7 +5,7 @@
-/* $Id$
+/* $Revision-Id$
* Test for the unit test module...
=== modified file 'src/libCom/test/macEnvExpandTest.c'
--- src/libCom/test/macEnvExpandTest.c 2008-03-31 19:30:17 +0000
+++ src/libCom/test/macEnvExpandTest.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
- * $Id$
+ * $Revision-Id$
#include <stddef.h>
=== modified file 'src/libCom/test/macLibTest.c'
--- src/libCom/test/macLibTest.c 2010-05-04 20:43:20 +0000
+++ src/libCom/test/macLibTest.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
- * $Id$
+ * $Revision-Id$
#include <stddef.h>
=== modified file 'src/libCom/test/taskwdTest.c'
--- src/libCom/test/taskwdTest.c 2008-05-22 20:19:34 +0000
+++ src/libCom/test/taskwdTest.c 2010-10-06 18:12:40 +0000
@@ -4,7 +4,7 @@
-/* $Id$ */
/* Author: Andrew Johnson
* Date: May 21, 2008
=== modified file 'src/libCom/timer/epicsTimer.cpp'
--- src/libCom/timer/epicsTimer.cpp 2010-03-24 17:17:41 +0000
+++ src/libCom/timer/epicsTimer.cpp 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/libCom/timer/timerPrivate.h'
--- src/libCom/timer/timerPrivate.h 2009-05-11 22:50:06 +0000
+++ src/libCom/timer/timerPrivate.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/libCom/timer/timerQueueActiveMgr.cpp'
--- src/libCom/timer/timerQueueActiveMgr.cpp 2009-02-10 22:24:20 +0000
+++ src/libCom/timer/timerQueueActiveMgr.cpp 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/libCom/tsDefs/tsDefs.c'
--- src/libCom/tsDefs/tsDefs.c 2002-07-12 21:35:43 +0000
+++ src/libCom/tsDefs/tsDefs.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
=== modified file 'src/libCom/tsDefs/tsDefs.h'
--- src/libCom/tsDefs/tsDefs.h 2002-07-12 21:35:43 +0000
+++ src/libCom/tsDefs/tsDefs.h 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* This file contains the old R3.13
* time stamp definitions and routines
* needed by epics extensions. They exist
=== modified file 'src/makeBaseApp/makeBaseApp.pl'
--- src/makeBaseApp/makeBaseApp.pl 2009-04-24 12:25:21 +0000
+++ src/makeBaseApp/makeBaseApp.pl 2010-10-06 18:12:40 +0000
@@ -2,7 +2,7 @@
if $running_under_some_shell; # makeBaseApp
# Authors: Ralph Lange, Marty Kraimer, Andrew Johnson and Janet Anderson
-# $Id$
+# $Revision-Id$
use Cwd;
use Getopt::Std;
=== modified file 'src/makeBaseApp/top/caServerApp/vxEntry.cc'
--- src/makeBaseApp/top/caServerApp/vxEntry.cc 2003-02-05 23:46:23 +0000
+++ src/makeBaseApp/top/caServerApp/vxEntry.cc 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-// $Id$
+// $Revision-Id$
// Author: Jeff HIll (LANL)
=== modified file 'src/makeBaseExt/makeBaseExt.pl'
--- src/makeBaseExt/makeBaseExt.pl 2009-04-24 12:35:36 +0000
+++ src/makeBaseExt/makeBaseExt.pl 2010-10-06 18:12:40 +0000
@@ -2,7 +2,7 @@
if $running_under_some_shell; # makeBaseExt
-# $Id$
+# $Revision-Id$
use Cwd;
use Getopt::Std;
=== modified file 'src/makeBaseExt/top/Makefile'
--- src/makeBaseExt/top/Makefile 2000-09-27 16:06:58 +0000
+++ src/makeBaseExt/top/Makefile 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
TOP = .
include $(TOP)/configure/CONFIG
=== modified file 'src/makeBaseExt/top/configure/CONFIG'
--- src/makeBaseExt/top/configure/CONFIG 2006-03-30 17:25:13 +0000
+++ src/makeBaseExt/top/configure/CONFIG 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
INSTALL_IDLFILE = $(INSTALL)
=== modified file 'src/makeBaseExt/top/configure/Makefile'
--- src/makeBaseExt/top/configure/Makefile 2001-09-13 21:46:22 +0000
+++ src/makeBaseExt/top/configure/Makefile 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
TOP=..
=== modified file 'src/makeBaseExt/top/configure/RULES'
--- src/makeBaseExt/top/configure/RULES 2009-03-31 19:48:17 +0000
+++ src/makeBaseExt/top/configure/RULES 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
include $(CONFIG)/RULES
include $(TOP)/configure/RULES_PYTHON
=== modified file 'src/makeBaseExt/top/configure/RULES_DIRS'
--- src/makeBaseExt/top/configure/RULES_DIRS 2009-03-31 19:48:17 +0000
+++ src/makeBaseExt/top/configure/RULES_DIRS 2010-10-06 18:12:40 +0000
@@ -1,3 +1,3 @@
-# $Id$
+# $Revision-Id$
include $(CONFIG)/RULES_DIRS
=== modified file 'src/makeBaseExt/top/configure/RULES_IDL'
--- src/makeBaseExt/top/configure/RULES_IDL 2009-05-06 15:13:45 +0000
+++ src/makeBaseExt/top/configure/RULES_IDL 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
ifdef T_A
ifeq ($(findstring Host,$(VALID_BUILDS)),Host)
=== modified file 'src/makeBaseExt/top/configure/RULES_PYTHON'
--- src/makeBaseExt/top/configure/RULES_PYTHON 2006-03-29 21:59:14 +0000
+++ src/makeBaseExt/top/configure/RULES_PYTHON 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
ifdef T_A
=== modified file 'src/makeBaseExt/top/configure/RULES_TOP'
--- src/makeBaseExt/top/configure/RULES_TOP 2009-03-31 19:48:17 +0000
+++ src/makeBaseExt/top/configure/RULES_TOP 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
include $(CONFIG)/RULES_TOP
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG.win32-x86-borland.win32-x86-borland'
--- src/makeBaseExt/top/configure/os/CONFIG.win32-x86-borland.win32-x86-borland 2004-10-15 18:19:40 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG.win32-x86-borland.win32-x86-borland 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
# Site Specific Configuration Information
# Only the local epics system manager should modify this file
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.Common.Common'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.Common.Common 2006-12-04 22:44:31 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.Common.Common 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc-gnu.aix-ppc-gnu'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc-gnu.aix-ppc-gnu 2004-10-15 18:19:40 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc-gnu.aix-ppc-gnu 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc.aix-ppc'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc.aix-ppc 2004-10-15 18:19:40 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc.aix-ppc 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.cygwin-x86.cygwin-x86'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.cygwin-x86.cygwin-x86 2009-07-21 17:11:02 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.cygwin-x86.cygwin-x86 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppc.darwin-ppc'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppc.darwin-ppc 2006-12-04 22:43:25 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppc.darwin-ppc 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppcx86.darwin-ppcx86'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppcx86.darwin-ppcx86 2006-12-04 22:34:31 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppcx86.darwin-ppcx86 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-x86.darwin-x86'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-x86.darwin-x86 2006-12-04 22:34:31 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-x86.darwin-x86 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.freebsd-x86_64.freebsd-x86_64'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.freebsd-x86_64.freebsd-x86_64 2006-12-04 22:34:31 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.freebsd-x86_64.freebsd-x86_64 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.hpux-parisc-gnu.hpux-parisc-gnu'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.hpux-parisc-gnu.hpux-parisc-gnu 2004-10-15 18:19:40 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.hpux-parisc-gnu.hpux-parisc-gnu 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.hpux-parisc.hpux-parisc'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.hpux-parisc.hpux-parisc 2006-12-04 22:41:51 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.hpux-parisc.hpux-parisc 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.interix-x86.interix-x86'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.interix-x86.interix-x86 2006-12-04 22:34:31 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.interix-x86.interix-x86 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.linux-ppc.linux-ppc'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.linux-ppc.linux-ppc 2006-12-04 22:34:31 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.linux-ppc.linux-ppc 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-borland.linux-x86-borland'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-borland.linux-x86-borland 2004-04-07 16:09:16 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-borland.linux-x86-borland 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-debug.linux-x86-debug'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-debug.linux-x86-debug 2006-12-04 22:34:31 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-debug.linux-x86-debug 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-athlon'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-athlon 2006-12-04 22:40:46 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-athlon 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-x86'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-x86 2009-03-31 19:04:02 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-x86 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug 2006-12-04 22:34:31 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64 2009-07-21 17:10:26 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.osf-alpha.osf-alpha'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.osf-alpha.osf-alpha 2006-12-04 22:38:38 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.osf-alpha.osf-alpha 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-debug.solaris-sparc-debug'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-debug.solaris-sparc-debug 2006-12-04 22:34:31 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-debug.solaris-sparc-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-gnu.solaris-sparc-gnu'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-gnu.solaris-sparc-gnu 2004-10-15 18:19:40 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-gnu.solaris-sparc-gnu 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc.solaris-sparc'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc.solaris-sparc 2006-12-04 22:37:45 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc.solaris-sparc 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64-gnu.solaris-sparc64-gnu'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64-gnu.solaris-sparc64-gnu 2006-12-04 22:34:31 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64-gnu.solaris-sparc64-gnu 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64.solaris-sparc64'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64.solaris-sparc64 2006-12-04 22:34:31 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64.solaris-sparc64 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-gnu.solaris-x86-gnu'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-gnu.solaris-x86-gnu 2004-10-15 18:19:40 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-gnu.solaris-x86-gnu 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86.solaris-x86'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86.solaris-x86 2009-07-21 17:26:34 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86.solaris-x86 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86_64.solaris-x86_64'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86_64.solaris-x86_64 2009-07-22 14:12:24 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86_64.solaris-x86_64 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-borland.win32-x86-borland'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-borland.win32-x86-borland 2003-09-19 16:12:33 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-borland.win32-x86-borland 2010-10-06 18:12:40 +0000
@@ -1,5 +1,5 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-cygwin.win32-x86-cygwin'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-cygwin.win32-x86-cygwin 2006-12-04 22:34:31 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-cygwin.win32-x86-cygwin 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-debug.win32-x86-debug'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-debug.win32-x86-debug 2006-12-04 22:34:31 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-debug.win32-x86-debug 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-mingw.win32-x86-mingw'
--- src/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-mingw.win32-x86-mingw 2006-12-04 22:34:31 +0000
+++ src/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-mingw.win32-x86-mingw 2010-10-06 18:12:40 +0000
@@ -1,6 +1,6 @@
-# $Id$
+# $Revision-Id$
=== modified file 'src/makeBaseExt/top/src/Makefile'
--- src/makeBaseExt/top/src/Makefile 2000-09-27 16:06:58 +0000
+++ src/makeBaseExt/top/src/Makefile 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
TOP = ..
=== modified file 'src/misc/base.dbd'
--- src/misc/base.dbd 2010-05-27 13:23:07 +0000
+++ src/misc/base.dbd 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
# This file defines the standard record types and device support
# provided by Base and (usually) loaded into all IOCs.
=== modified file 'src/misc/epicsRelease.c'
--- src/misc/epicsRelease.c 2006-11-16 19:32:13 +0000
+++ src/misc/epicsRelease.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$
+/* $Revision-Id$
#include <stdlib.h>
=== modified file 'src/misc/iocInit.c'
--- src/misc/iocInit.c 2009-07-02 20:05:32 +0000
+++ src/misc/iocInit.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$ */
* Date: 06-01-91
=== modified file 'src/rec/aSubRecord.c'
--- src/rec/aSubRecord.c 2010-04-20 22:13:54 +0000
+++ src/rec/aSubRecord.c 2010-10-06 18:12:40 +0000
@@ -4,7 +4,7 @@
-/* $Id$
+/* $Revision-Id$
* Record Support Routines for the Array Subroutine Record type,
* derived from Andy Foster's genSub record, with some features
=== modified file 'src/rec/aiRecord.c'
--- src/rec/aiRecord.c 2010-04-05 18:49:18 +0000
+++ src/rec/aiRecord.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$ */
/* aiRecord.c - Record Support Routines for Analog Input records */
=== modified file 'src/rec/aoRecord.c'
--- src/rec/aoRecord.c 2010-04-05 18:49:18 +0000
+++ src/rec/aoRecord.c 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
-/* $Id$ */
/* aoRecord.c - Record Support Routines for Analog Output records */
=== modified file 'src/rec/biRecord.c'
--- src/rec/biRecord.c 2010-04-05 18:49:18 +0000
+++ src/rec/biRecord.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
/* recBi.c - Record Support Routines for Binary Input records */
=== modified file 'src/rec/boRecord.c'
--- src/rec/boRecord.c 2010-04-05 18:49:18 +0000
+++ src/rec/boRecord.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
/* recBo.c - Record Support Routines for Binary Output records */
=== modified file 'src/rec/calcRecord.c'
--- src/rec/calcRecord.c 2009-04-03 14:40:13 +0000
+++ src/rec/calcRecord.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
/* Record Support Routines for Calculation records */
=== modified file 'src/rec/compressRecord.c'
--- src/rec/compressRecord.c 2010-04-02 21:26:17 +0000
+++ src/rec/compressRecord.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
* Original Author: Bob Dalesio
* Date: 7-14-89
=== modified file 'src/rec/dfanoutRecord.c'
--- src/rec/dfanoutRecord.c 2009-04-03 14:40:13 +0000
+++ src/rec/dfanoutRecord.c 2010-10-06 18:12:40 +0000
@@ -5,7 +5,7 @@
-/* $Id$ */
/* recDfanout.c - Record Support Routines for Dfanout records */
=== modified file 'src/rec/eventRecord.c'
--- src/rec/eventRecord.c 2009-07-08 18:14:11 +0000
+++ src/rec/eventRecord.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
/* recEvent.c - Record Support Routines for Event records */
=== modified file 'src/rec/fanoutRecord.c'
--- src/rec/fanoutRecord.c 2009-04-02 21:41:45 +0000
+++ src/rec/fanoutRecord.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
* Date: 12-20-88
=== modified file 'src/rec/histogramRecord.c'
--- src/rec/histogramRecord.c 2009-07-08 18:14:11 +0000
+++ src/rec/histogramRecord.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
/* recHistogram.c - Record Support Routines for Histogram records */
=== modified file 'src/rec/longinRecord.c'
--- src/rec/longinRecord.c 2010-04-05 18:49:18 +0000
+++ src/rec/longinRecord.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
/* recLongin.c - Record Support Routines for Longin records */
=== modified file 'src/rec/longoutRecord.c'
--- src/rec/longoutRecord.c 2010-04-05 18:49:18 +0000
+++ src/rec/longoutRecord.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
* Author: Janet Anderson
* Date: 9/23/91
=== modified file 'src/rec/mbbiDirectRecord.c'
--- src/rec/mbbiDirectRecord.c 2010-04-05 18:49:18 +0000
+++ src/rec/mbbiDirectRecord.c 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
-/* $Id$ */
/* recMbbiDirect.c - Record Support routines for mbboDirect records */
=== modified file 'src/rec/mbbiRecord.c'
--- src/rec/mbbiRecord.c 2010-04-05 18:49:18 +0000
+++ src/rec/mbbiRecord.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-/* $Id$ */
* Date: 5-9-88
=== modified file 'src/rec/mbboDirectRecord.c'
--- src/rec/mbboDirectRecord.c 2010-04-05 18:49:18 +0000
+++ src/rec/mbboDirectRecord.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
/* recMbboDirect.c - Record Support for mbboDirect records */
=== modified file 'src/rec/mbboRecord.c'
--- src/rec/mbboRecord.c 2010-04-05 18:49:18 +0000
+++ src/rec/mbboRecord.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-/* $Id$ */
/* recMbbo.c - Record Support Routines for multi bit binary Output records */
=== modified file 'src/rec/permissiveRecord.c'
--- src/rec/permissiveRecord.c 2009-04-02 21:41:45 +0000
+++ src/rec/permissiveRecord.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
/* recPermissive.c - Record Support Routines for Permissive records */
=== modified file 'src/rec/selRecord.c'
--- src/rec/selRecord.c 2009-08-25 18:19:49 +0000
+++ src/rec/selRecord.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
/* selRecord.c - Record Support Routines for Select records */
=== modified file 'src/rec/seqRecord.c'
--- src/rec/seqRecord.c 2009-04-02 21:41:45 +0000
+++ src/rec/seqRecord.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* Date: 09-21-92
=== modified file 'src/rec/stateRecord.c'
--- src/rec/stateRecord.c 2009-04-02 21:41:45 +0000
+++ src/rec/stateRecord.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
/* recState.c - Record Support Routines for State records */
=== modified file 'src/rec/stringinRecord.c'
--- src/rec/stringinRecord.c 2010-04-20 22:13:54 +0000
+++ src/rec/stringinRecord.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
/* recStringin.c - Record Support Routines for Stringin records */
=== modified file 'src/rec/stringoutRecord.c'
--- src/rec/stringoutRecord.c 2010-04-20 22:13:54 +0000
+++ src/rec/stringoutRecord.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
/* recStringout.c - Record Support Routines for Stringout records */
=== modified file 'src/rec/subArrayRecord.c'
--- src/rec/subArrayRecord.c 2009-04-23 22:19:46 +0000
+++ src/rec/subArrayRecord.c 2010-10-06 18:12:40 +0000
@@ -5,7 +5,7 @@
-/* $Id$ */
/* recSubArray.c - Record Support Routines for SubArray records
=== modified file 'src/rec/subRecord.c'
--- src/rec/subRecord.c 2010-04-05 18:49:18 +0000
+++ src/rec/subRecord.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
/* Record Support Routines for Subroutine records */
=== modified file 'src/rec/waveformRecord.c'
--- src/rec/waveformRecord.c 2009-07-08 18:14:11 +0000
+++ src/rec/waveformRecord.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* $Id$ */
/* recWaveform.c - Record Support Routines for Waveform records */
=== modified file 'src/rsrv/caservertask.c'
--- src/rsrv/caservertask.c 2010-08-10 21:05:46 +0000
+++ src/rsrv/caservertask.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* Author: Jeffrey O. Hill
=== modified file 'src/rsrv/online_notify.c'
--- src/rsrv/online_notify.c 2008-09-19 23:27:52 +0000
+++ src/rsrv/online_notify.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
- * $Id$
+ * $Revision-Id$
* tell CA clients this a server has joined the network
=== modified file 'src/rsrv/rsrv.h'
--- src/rsrv/rsrv.h 2008-07-09 21:31:56 +0000
+++ src/rsrv/rsrv.h 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
- * $Id$
+ * $Revision-Id$
* [email protected]
=== modified file 'src/softIoc/softIocExit.db'
--- src/softIoc/softIocExit.db 2006-11-13 21:45:40 +0000
+++ src/softIoc/softIocExit.db 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-# $Id$
+# $Revision-Id$
record(sub,"$(IOC):exit") {
field(DESC,"Exit subroutine")
=== modified file 'src/softIoc/softMain.cpp'
--- src/softIoc/softMain.cpp 2009-07-28 21:08:37 +0000
+++ src/softIoc/softMain.cpp 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
* found in the file LICENSE that is included with this distribution.
-/* $Id$ */
/* Author: Andrew Johnson Date: 2003-04-08 */
=== modified file 'src/tools/EPICS/Copy.pm'
--- src/tools/EPICS/Copy.pm 2008-04-03 21:57:16 +0000
+++ src/tools/EPICS/Copy.pm 2010-10-06 18:12:40 +0000
@@ -5,7 +5,7 @@
# in file LICENSE that is included with this distribution.
-# $Id$
+# $Revision-Id$
# Copy directories and files from a template
=== modified file 'src/tools/EPICS/Path.pm'
--- src/tools/EPICS/Path.pm 2008-10-20 18:32:47 +0000
+++ src/tools/EPICS/Path.pm 2010-10-06 18:12:40 +0000
@@ -5,7 +5,7 @@
-# $Id$
+# $Revision-Id$
use Carp;
use Cwd qw(getcwd abs_path);
=== modified file 'src/tools/EPICS/Release.pm'
--- src/tools/EPICS/Release.pm 2009-12-22 23:55:02 +0000
+++ src/tools/EPICS/Release.pm 2010-10-06 18:12:40 +0000
@@ -5,7 +5,7 @@
-# $Id$
+# $Revision-Id$
# Parse all relevent configure/RELEASE* files and includes
=== modified file 'src/tools/convertRelease.pl'
--- src/tools/convertRelease.pl 2010-10-05 21:02:09 +0000
+++ src/tools/convertRelease.pl 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
-# $Id$
+# $Revision-Id$
# Convert configure/RELEASE file(s) into something else.
=== modified file 'src/tools/cvsclean.pl'
--- src/tools/cvsclean.pl 2010-07-29 19:58:14 +0000
+++ src/tools/cvsclean.pl 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
# in the file LICENSE that is included with this distribution.
-# $Id$
+# $Revision-Id$
# Find and delete cvs .#* and editor backup *~
# files from all dirs of the directory tree.
=== modified file 'src/tools/dos2unix.pl'
--- src/tools/dos2unix.pl 2008-03-24 22:17:06 +0000
+++ src/tools/dos2unix.pl 2010-10-06 18:12:40 +0000
@@ -11,7 +11,7 @@
# Converts text file in DOS CR/LF format to unix ISO format
-# $Id$
+# $Revision-Id$
@files=@ARGV;
=== modified file 'src/tools/expandVars.pl'
--- src/tools/expandVars.pl 2008-09-23 22:13:52 +0000
+++ src/tools/expandVars.pl 2010-10-06 18:12:40 +0000
@@ -6,7 +6,7 @@
# Author: Andrew Johnson <[email protected]>
# Date: 10 February 2005
-# $Id$
+# $Revision-Id$
use strict;
=== modified file 'src/tools/filterWarnings.pl'
--- src/tools/filterWarnings.pl 2010-07-29 19:58:14 +0000
+++ src/tools/filterWarnings.pl 2010-10-06 18:12:40 +0000
@@ -12,7 +12,7 @@
-# $Id$
+# $Revision-Id$
# Author: Ralph Lange
=== modified file 'src/tools/fullPathName.pl'
--- src/tools/fullPathName.pl 2010-07-29 19:58:14 +0000
+++ src/tools/fullPathName.pl 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# Determines an absolute pathname for its argument,
# which may be either a relative or absolute path and
=== modified file 'src/tools/makeIncludeDbd.pl'
--- src/tools/makeIncludeDbd.pl 2008-03-24 22:17:06 +0000
+++ src/tools/makeIncludeDbd.pl 2010-10-06 18:12:40 +0000
@@ -9,7 +9,7 @@
-# $Id$
+# $Revision-Id$
use File::Basename;
=== modified file 'src/tools/munch.pl'
--- src/tools/munch.pl 2010-07-29 19:58:14 +0000
+++ src/tools/munch.pl 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-# $Id$
+# $Revision-Id$
# Creates a ctdt.c file of C++ static constructors and destructors,
# as required for all vxWorks binaries containing C++ code.
=== modified file 'src/toolsComm/flex/README'
--- src/toolsComm/flex/README 1993-11-18 11:19:13 +0000
+++ src/toolsComm/flex/README 2010-10-06 18:12:40 +0000
@@ -1,4 +1,4 @@
-// $Header$
+// $Revision-Id$
This is release 2.3 of flex - a full release.
=== modified file 'src/toolsComm/flex/ccl.c'
--- src/toolsComm/flex/ccl.c 2009-04-30 20:45:31 +0000
+++ src/toolsComm/flex/ccl.c 2010-10-06 18:12:40 +0000
@@ -36,7 +36,7 @@
#ifndef lint
static char rcsid[] =
- "@(#) $Header$ (LBL)";
+ "@(#) $Revision-Id$ (LBL)";
#endif
#include "flexdef.h"
=== modified file 'src/toolsComm/flex/dfa.c'
--- src/toolsComm/flex/dfa.c 2009-04-30 20:45:31 +0000
+++ src/toolsComm/flex/dfa.c 2010-10-06 18:12:40 +0000
@@ -36,7 +36,7 @@
#ifndef lint
#endif
=== modified file 'src/toolsComm/flex/ecs.c'
--- src/toolsComm/flex/ecs.c 2009-04-30 20:45:31 +0000
+++ src/toolsComm/flex/ecs.c 2010-10-06 18:12:40 +0000
@@ -36,7 +36,7 @@
#ifndef lint
#endif
=== modified file 'src/toolsComm/flex/flex.skel'
--- src/toolsComm/flex/flex.skel 2009-06-05 19:07:24 +0000
+++ src/toolsComm/flex/flex.skel 2010-10-06 18:12:40 +0000
@@ -1,7 +1,7 @@
/* A lexical scanner generated by flex */
/* scanner skeleton version:
- * $Header$
+ * $Revision-Id$
#define FLEX_SCANNER
=== modified file 'src/toolsComm/flex/flex.skel.static'
--- src/toolsComm/flex/flex.skel.static 2009-06-05 19:07:24 +0000
+++ src/toolsComm/flex/flex.skel.static 2010-10-06 18:12:40 +0000
@@ -1,7 +1,7 @@
- * $Header$
+ * $Revision-Id$
/* modified by Jim Kowalkowski to have everything declared static */
=== modified file 'src/toolsComm/flex/flexdef.h'
--- src/toolsComm/flex/flexdef.h 2009-06-05 19:16:31 +0000
+++ src/toolsComm/flex/flexdef.h 2010-10-06 18:12:40 +0000
@@ -34,7 +34,7 @@
* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
-/* @(#) $Header$ (LBL) */
+/* @(#) $Revision-Id$ (LBL) */
#ifndef INC_flexdef_H
#define INC_flexdef_H
=== modified file 'src/toolsComm/flex/gen.c'
--- src/toolsComm/flex/gen.c 2009-04-30 20:45:31 +0000
+++ src/toolsComm/flex/gen.c 2010-10-06 18:12:40 +0000
@@ -36,7 +36,7 @@
#ifndef lint
#endif
=== modified file 'src/toolsComm/flex/libmain.c'
--- src/toolsComm/flex/libmain.c 2009-04-30 20:45:31 +0000
+++ src/toolsComm/flex/libmain.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* libmain - flex run-time support library "main" function */
-/* $Header$ */
extern int yylex();
=== modified file 'src/toolsComm/flex/main.c'
--- src/toolsComm/flex/main.c 2010-08-27 14:12:20 +0000
+++ src/toolsComm/flex/main.c 2010-10-06 18:12:40 +0000
@@ -45,7 +45,7 @@
#ifndef lint
#endif
=== modified file 'src/toolsComm/flex/misc.c'
--- src/toolsComm/flex/misc.c 2010-08-27 14:12:20 +0000
+++ src/toolsComm/flex/misc.c 2010-10-06 18:12:40 +0000
@@ -36,7 +36,7 @@
#ifndef lint
#endif
#include <ctype.h>
=== modified file 'src/toolsComm/flex/nfa.c'
--- src/toolsComm/flex/nfa.c 2009-04-30 20:45:31 +0000
+++ src/toolsComm/flex/nfa.c 2010-10-06 18:12:40 +0000
@@ -36,7 +36,7 @@
#ifndef lint
#endif
=== modified file 'src/toolsComm/flex/parse.y'
--- src/toolsComm/flex/parse.y 2009-04-30 20:45:31 +0000
+++ src/toolsComm/flex/parse.y 2010-10-06 18:12:40 +0000
@@ -32,7 +32,7 @@
#ifndef lint
#endif
=== modified file 'src/toolsComm/flex/scan.c'
--- src/toolsComm/flex/scan.c 2009-06-05 19:07:24 +0000
+++ src/toolsComm/flex/scan.c 2010-10-06 18:12:40 +0000
@@ -1,7 +1,7 @@
- * $Header$
+ * $Revision-Id$
=== modified file 'src/toolsComm/flex/sym.c'
--- src/toolsComm/flex/sym.c 2009-04-30 20:45:31 +0000
+++ src/toolsComm/flex/sym.c 2010-10-06 18:12:40 +0000
@@ -36,7 +36,7 @@
#ifndef lint
#endif
=== modified file 'src/toolsComm/flex/tblcmp.c'
--- src/toolsComm/flex/tblcmp.c 2009-06-03 15:00:08 +0000
+++ src/toolsComm/flex/tblcmp.c 2010-10-06 18:12:40 +0000
@@ -36,7 +36,7 @@
#ifndef lint
#endif
=== modified file 'src/toolsComm/flex/yylex.c'
--- src/toolsComm/flex/yylex.c 2009-04-30 20:45:31 +0000
+++ src/toolsComm/flex/yylex.c 2010-10-06 18:12:40 +0000
@@ -35,7 +35,7 @@
- * $Id$
+ * $Revision-Id$
#include <ctype.h>
=== modified file 'src/util/ca_test.c'
--- src/util/ca_test.c 2009-07-09 16:37:24 +0000
+++ src/util/ca_test.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* @(#)ca_test.c $Id$
+/* @(#)ca_test.c $Revision-Id$
* Author: Jeff Hill
* Date: 07-01-91
=== modified file 'src/util/ca_test.h'
--- src/util/ca_test.h 2002-07-12 21:35:43 +0000
+++ src/util/ca_test.h 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* @(#)ca_test.k $Id$
+/* @(#)ca_test.k $Revision-Id$
* Author: Jeff Hill
* Date: 21JAN2000
=== modified file 'src/util/ca_test_main.c'
--- src/util/ca_test_main.c 2002-07-12 21:35:43 +0000
+++ src/util/ca_test_main.c 2010-10-06 18:12:40 +0000
@@ -7,7 +7,7 @@
-/* @(#)ca_test_main.c $Id$
+/* @(#)ca_test_main.c $Revision-Id$
* Author: Jeff Hill
* Date: 21JAN2000
=== modified file 'src/util/iocLogServer.c'
--- src/util/iocLogServer.c 2009-07-09 17:06:45 +0000
+++ src/util/iocLogServer.c 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
/* iocLogServer.c */
-/* base/src/util $Id$ */
+/* base/src/util $Revision-Id$ */
* archive logMsg() from several IOC's to a common rotating file
=== modified file 'startup/EpicsHostArch.pl'
--- startup/EpicsHostArch.pl 2006-12-19 17:03:02 +0000
+++ startup/EpicsHostArch.pl 2010-10-06 18:12:40 +0000
@@ -10,7 +10,7 @@
-# $Id$
+# $Revision-Id$
# Returns the Epics host architecture suitable
# for assigning to the EPICS_HOST_ARCH variable
=== modified file 'startup/cygwin.bat'
--- startup/cygwin.bat 2009-04-13 21:27:32 +0000
+++ startup/cygwin.bat 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
REM and higher are distributed subject to a Software License Agreement found
REM in file LICENSE that is included with this distribution.
REM *************************************************************************
-REM $Id$
+REM $Revision-Id$
REM
REM Site-specific EPICS environment settings
REM
=== modified file 'startup/win32.bat'
--- startup/win32.bat 2009-05-06 18:50:46 +0000
+++ startup/win32.bat 2010-10-06 18:12:40 +0000
@@ -8,7 +8,7 @@
-REM $Id$
+REM $Revision-Id$
REM
REM
- Re: [Merge] lp:~anj/epics-base/keywords into lp:epics-base Ralph Lange
- Re: [Merge] lp:~anj/epics-base/keywords into lp:epics-base Andrew Johnson
Launchpad Bugs Re-enabling Auto Expiring Bugs deryck . hodge
<2010>
2025
2026
<2010>
2025
2026
