2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~anj/epics-base/keywords into lp:epics-base
Date: Wed, 06 Oct 2010 20:44:00 -0000
Do we really need the Id/Revision-Id keywords?
At some point we threw out all those keywords from our sources, as they were creating a constant pain by causing a conflict with every single merge from a branch.
That was still under CVS. Does Bazaar handle this more sanely?
https://code.launchpad.net/~anj/epics-base/keywords/+merge/37769
Your team EPICS Core Developers is requested to review the proposed merge of lp:~anj/epics-base/keywords into lp:epics-base.
[Merge] lp:~anj/epics-base/keywords into lp:epics-base Andrew Johnson
Prev: [Merge] lp:~anj/epics-base/keywords into lp:epics-base Andrew Johnson
Next: Re: [Merge] lp:~anj/epics-base/keywords into lp:epics-base Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
