2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~anj/epics-base/keywords into lp:epics-base
Date: Wed, 06 Oct 2010 22:11:00 -0000
Bazaar only converts keywords from their internal $Raw$ form into the $External: cooked $ form at the end of the extraction process iff you have the keywords plug-in installed, and the inverse conversion happens when importing a commit.  All merging is done using the raw form, so there should be no issues like we had with CVS.  If you don't have the keywords plug-in installed and configured it won't do any expansion anyway, so I don't think this will be a problem.
We could take out the $Revision-Id$ keywords, but they are occasionally useful.
There is a bug in the latest official release of the keywords plug-in: It recognizes anything that matches the cooked regular expression as a keyword and converts it into the associated raw form on commit, even if it's not a known keyword.  For Perl scripts that's a major issue, so I developed and pushed a fix for it before enabling the plug-in.
If you do install the keywords plug-in, ask me for my rules file.
https://code.launchpad.net/~anj/epics-base/keywords/+merge/37769
Your team EPICS Core Developers is requested to review the proposed merge of lp:~anj/epics-base/keywords into lp:epics-base.
[Merge] lp:~anj/epics-base/keywords into lp:epics-base Andrew Johnson
Prev: Re: [Merge] lp:~anj/epics-base/keywords into lp:epics-base Ralph Lange
Next: Re: [Merge] lp:~anj/epics-base/expand-calc-size into lp:epics-base Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: 3.14.12 Feature Freeze Andrew Johnson
