Hi Jeff,
On Tuesday 04 January 2011 18:32:05 you wrote:
> I am actually not certain if I asked this question before, but in any case,
> I see quite a few warning popups in the ms ide about end of line
> terminations being inconsistent which can have some impact on productivity.
> So I am wondering if we have chosen the "native" option as described on
> this web page.
> http://doc.bazaar.canonical.com/development/en/user-reference/eol-help.html
Unlike with CVS this configuration has to be set by each developer that needs
windows line-endings; the %BZR_HOME%/bazaar/2.0/rules file that the above page
talks about is not stored inside the repository or your working directory, I
believe it's somewhere under your Windows home directory. As the page says,
if a value is not given then 'exact' is used, so you get the line endings
exactly as stored in the repository.
> Sorry to ask this question twice if that turns out to be the case, but
> thought this issue should be addressed soon if its solvable.
I don't remember you asking about it before, but I think you'll have to fix it
yourself if you want Windows line endings in your working files. After you
add the necessary rule(s) you will have to check out your working tree again
to get the line-endings in your working files changed, or you can use these
commands from the <base> directory to remove and re-create them all (unless
you're using a light checkout, where this won't work):
make distclean
bzr clean-tree (deletes all unknown files)
bzr shelve --all (saves any uncommitted changes)
bzr remove-tree (removes working files)
bzr checkout . (recreate working files)
bzr unshelve (restore uncommitted changes)
By the way my rules file currently contains the following settings to
configure keyword expansion, but you'd need my version of the Bazaar keywords
plugin to use them; the "official" keywords plugin is broken.
[name *.html *.php *.xml]
keywords = xml_escape
[name *]
keywords = on
You can get my version of the keywords plugin if you want it by doing this:
cd %BZR_HOME%/bazaar/2.0/plugins
bzr co lp:~anj/bzr-keywords/fix-505038 keywords
then run 'bzr plugins' to check that it's seeing the plugin.
HTH,
- Andrew
PS: In addition to the bug that I subscribed you to earlier, Alex Chen also
filed 3 others that look to be related and cover Win32 OSD code which you
understand a lot better than I do. If you want to receive all bug emails like
Ralph and I currently do you should go to the URL below and check the "I want
to receive these notifications by e-mail." box:
https://bugs.launchpad.net/epics-base/+subscribe
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it. If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence. -- Bertrand Russell
- Re: bazaar end of line conversion J. Lewis Muir
RE: EPICS internals talks? Jeff Hill
<2011>
2025
2026
<2011>
2025
2026
