2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Gateway / CAS include issue
To: EPICS Core Talk <[email protected]>
Date: Fri, 06 May 2011 10:56:07 +0200
Hi.
Preparing to package the CA Gateway I find the Gateway needs casCtx.h (which in turn pulls in caHdrLargeArray.h), because it needs to know which event mask the exterior client used in a subscription.
casCtx.h and caHdrLargeArray.h are not installed as include files by CAS.
To make compilation work, the Gateway Makefile adds BASE/src/cas/generic to the include path.
Of course, this does not work nicely with binary packages, where the "...-dev" development package, which is a build dependency of the Gateway package, contains (installed) include files and libraries, but no sources.
What are the different stakeholders' opinions?
Is casCtx.h a public interface of CAS?
The Gateway is an important client app and undoubtedly needs it: Should it be made public? Or should the functionality rather be included in one of the existing public interfaces?
Should - as a workaround to allow packaging the Gateway- the epics-dev package just install the two header files?
~Ralph
RE: Gateway / CAS include issue Jeff Hill
Prev: Patch release R3.14.12.1 proposal Andrew Johnson
Next: RE: Gateway / CAS include issue Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
