Good points, Ben. I concur.
- Bruce
----- Reply message -----
Date: Tue, Aug 9, 2011 3:25 pm
Subject: c++ static initialization
To: "[email protected]" <[email protected]>
Hi Jeff
you asked for opinions, here is mine:
Am Dienstag, 9. August 2011, um 22:42:37 schrieb Jeff Hill:
> Ref: http://www.parashift.com/c++-faq-lite/ctors.html#faq-10.14
> Of course C++ is really different from C in that some significant code can
> run during static initialization. The above FAQ mentions how to avoid some
> really serious issues. All of this is pretty common knowledge, but one has
> to be careful, and I have definitely seen this bug biting in EPICS base
> before.
(1) Static objects should be avoided wherever possible.
(2) If static objects are used, the constructor should be trivial, i.e. not
perform anything except setting members to default values.
(3) Non-trivial initialization for complex objects should be done in a regular
method either lazily ("Construct On First Use") or by an explicit call from
some startup routine. The latter has the advantage of a well-defined order of
initialization; the former is sometimes more convenient.
> However there is still a related issue which should be well understood; not
> everyone agrees if threads should be started during C++ static
> initialization or not.
(4) Starting threads inside static initialization is a bad idea and should not
be allowed (see rule 2).
> If multiple threads are running during c++ static
> initialization then the solution in the above FAQ doesn't apply and the
> only solution is epicsThreadOnce,
(5) epicsThreadOnce should also be avoided wherever possible. Using it means
objects cannot be freely passed between threads which is detriment to
composability.
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: c++ static initialization Benjamin Franksen
Re: c++ static initialization Eric Norum
<2011>
2025
2026
RE: c++ static initialization Jeff Hill
c++ 0x initialization of local (block scoped) static variables Jeff Hill
<2011>
2025
2026
