On Aug 9, 2011, at 3:24 PM, Benjamin Franksen wrote:
> Hi Jeff
> you asked for opinions, here is mine:
> (1) Static objects should be avoided wherever possible.
> (2) If static objects are used, the constructor should be trivial, i.e. not
> perform anything except setting members to default values.
Static initializers are often used to register iocsh commands. I think that this is acceptable and should be documented as such.
> (3) Non-trivial initialization for complex objects should be done in a regular
> method either lazily ("Construct On First Use") or by an explicit call from
> some startup routine. The latter has the advantage of a well-defined order of
> initialization; the former is sometimes more convenient.
Eric Norum
[email protected]
- c++ static initialization Jeff Hill
- Re: c++ static initialization Benjamin Franksen
Re: c++ static initialization Hill, Bruce
Re: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base mdavidsaver
<2011>
2025
2026
Re: c++ static initialization Andrew Johnson
<2011>
2025
2026
