2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~epics-core/epics-base/rebased-atomics into lp:epics-base
To: Jeff Hill <[email protected]>
Date: Tue, 06 Sep 2011 15:26:20 -0000
Hi Jeff,
On 2011-09-02 you wrote:
> Committed a fix, but I am unable to build for this version of Solaris here
>  so we may need to iterate.
/opt/SUNWspro/bin/CC -c  -D_POSIX_C_SOURCE=199506L  -D_XOPEN_SOURCE=500
-DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w           -xcode=pic32  -
I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -
I../../../src/libCom/osi/compiler/default -I. -
I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -
I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -
I../../../src/libCom/bucketLib -I../../../src/libCom/calc -
I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -
I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -
I../../../src/libCom/ellLib -I../../../src/libCom/env -
I../../../src/libCom/error -I../../../src/libCom/fdmgr -
I../../../src/libCom/flex -I../../../src/libCom/freeList -
I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -
I../../../src/libCom/log -I../../../src/libCom/macLib -
I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/ring
-I../../../src/libCom/taskwd -I../../../src/libCom/timer -
I../../../src/libCom/tsDefs -I../../../src/libCom/yacc -
I../../../include/compiler/solStudio -I../../../include/os/solaris -
I../../../include        ../../../src/libCom/osi/os/posix/epicsAtomicOSD.cpp
"../../../src/libCom/osi/os/solaris/epicsAtomicOSD.h", line 67: Error: Formal
argument 1 of type volatile unsigned long* in call to
atomic_cas_ulong(volatile unsigned long*, unsigned long, unsigned long) is
being passed unsigned*.
"../../../src/libCom/osi/os/solaris/epicsAtomicOSD.h", line 97: Error: Formal
atomic_inc_ulong_nv(volatile unsigned long*) is being passed unsigned*.
"../../../src/libCom/osi/os/solaris/epicsAtomicOSD.h", line 116: Error: Formal
atomic_dec_ulong_nv(volatile unsigned long*) is being passed unsigned*.
"../../../src/libCom/osi/os/solaris/epicsAtomicOSD.h", line 136: Error: Formal
atomic_add_long_nv(volatile unsigned long*, long) is being passed unsigned*.
"../../../src/libCom/osi/os/solaris/epicsAtomicOSD.h", line 147: Error: Formal
5 Error(s) detected.
> The _nv versions are necessary because, in our interface, we return the
>  result of the atomic operation to the user.
Not a problem, I was just making sure that was a conscious decision of yours,
although I thought it probably was; the comment said "on some platforms" and
you added the epicsAtomicPerformTest.c code so we can easily measure that.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
https://code.launchpad.net/~epics-core/epics-base/rebased-atomics/+merge/73915
Your team EPICS Core Developers is subscribed to branch lp:epics-base.
Re: [Merge] lp:~epics-core/epics-base/rebased-atomics into lp:epics-base Jeff Hill
Prev: RE: Atomic operation library and spin-lock for the epics ring buffer Williams Jr., Ernest L.
Next: Re: [Merge] lp:~epics-core/epics-base/rebased-atomics into lp:epics-base Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] lp:~epics-core/epics-base/rebased-atomics into lp:epics-base Jeff Hill
