2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Atomic operation library and spin-lock for the epics ring buffer
From: "Williams Jr., Ernest L." <[email protected]>
To: Jeff Hill <[email protected]>, "Kim, Kukhee" <[email protected]>, "[email protected]" <[email protected]>
Cc: "'EPICS Core Talk'" <[email protected]>, "Rogind, Debbie" <[email protected]>
Date: Sun, 4 Sep 2011 03:43:45 -0700
vxWorks 6.8 does indeed provide spin locks.
Cheers,
Ernest
Sent: Wednesday, August 31, 2011 6:08 PM
To: Kim, Kukhee; [email protected]
Cc: [email protected]; Williams Jr., Ernest L.; Rogind, Debbie; 'EPICS Core Talk'
Hi Kukee,
> Do you have any plan to work on the spin-lock?
> Actually, my parallel-callbacks for SMP requires the spin-lock.
I implemented the atomic library because I needed primitive
set/get/incr/decr features for smart pointer reference counting, and also
the compare-and-swap features are useful when I need to be certain that lazy
initialization is only done once.
I wasn’t thinking about implementing spin-locks because they are typically
provided by the OS as some kind of mutex primitive. It's certainly true that
we could implement portable spin locks now that we have portable atomics.
I seem to recall that, on windows, the fast in-process version of their
mutex primitive is a spin-lock hybrid (spin first and then fall back to
using the OS to block for lock release notification). I can guess that the
OS implementers might have some unique advantages over user level code for
implementing such hybrid approaches, but of course a user-land hybrid could
have some unique advantages also because it might completely avoid the
change mode to kernel system call overhead. Considering this further I
wouldn’t be shocked to discover that the windows critical section is
actually spinning in user-land and only changing mode to kernel after the
spin count decrements down to zero.
Nevertheless, it might be very interesting to run some benchmarks. I have a
lot on my plate so if you would like to look into this, that would be great!
Have a look at libCom/test/epicsAtomicPerform and libCom/test/epicsMutexTest
for some preexisting performance measurements.
Thanks and best regards,
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: Kim, Kukhee [mailto:[email protected]]
> Sent: Wednesday, August 31, 2011 2:14 PM
> To: [email protected]; [email protected]
> Subject: Atomic operation library and spin-lock for the epics ring buffer
> Hi Jeff;
> I am watching your series of releases which are related with the atomic
> operation.
> I think, we are ready to work for the spin-lock issue on the epics ring
> buffer.
> Please, let me know, if there is anything I can do.
> Thank you.
> Best regards,
> Kukhee
> Kukhee Kim
> SLAC National Accelerator Laboratory
> 2575 Sand Hill Rd, MS 64
> Menlo Park, CA 94025
> Email: [email protected]
> Phone: (650)926-4912
RE: Atomic operation library and spin-lock for the epics ring buffer Jeff Hill
Prev: Re: [Merge] lp:~epics-core/epics-base/rebased-atomics into lp:epics-base Jeff Hill
Next: Re: [Merge] lp:~epics-core/epics-base/rebased-atomics into lp:epics-base Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Atomic operation library and spin-lock for the epics ring buffer Jeff Hill
Next: [Merge] lp:~epics-core/epics-base/rebased-atomics into lp:epics-base Andrew Johnson
