2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: "spinlock" API
To: [email protected]
Date: Tue, 12 Jun 2012 10:13:31 -0400
On 6/11/2012 6:31 PM, Michael Davidsaver wrote:
On 6/11/2012 5:16 PM, Andrew Johnson wrote:
Can we design the default implementation to use atomic variables instead of
mutexes, unless there really is no alternative?
To be honest, I'm a little unsure what the performance implications of a spinlock implementation would be when task preemption can't be disabled.
Just to be clear, I'm thinking of starvation issues like priority inversion which can arise when the OS scheduler does not "know" about the locking.
On a workstation OS the act
of taking or releasing a mutex always requires a context switch, whereas an
atomic operation does not.
Is this true? I thought that a syscall was required, but that the full context switch only occurs if the lock is contested.
http://sourceware.org/git/?p=glibc.git;a=blob;f=nptl/pthread_mutex_lock.c#l44
It seems that glibc can actually avoid a syscall in some cases. This is implemented with an atomic test operation.
http://sourceware.org/git/?p=glibc.git;a=blob;f=nptl/lowlevellock.h
Michael
Re: "spinlock" API Andrew Johnson
"spinlock" API Michael Davidsaver
Re: "spinlock" API Michael Davidsaver
Prev: Re: "spinlock" API Michael Davidsaver
Next: Re: "spinlock" API Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 26 Nov 2012 · Home · News · About · Talk · Base · Modules · Extensions ·
