On 6/11/2012 5:16 PM, Andrew Johnson wrote:
Can we design the default implementation to use atomic variables instead of
mutexes, unless there really is no alternative?
To be honest, I'm a little unsure what the performance implications of a
spinlock implementation would be when task preemption can't be disabled.
On a workstation OS the act
of taking or releasing a mutex always requires a context switch, whereas an
atomic operation does not.
Is this true? I thought that a syscall was required, but that the full
context switch only occurs if the lock is contested.
http://sourceware.org/git/?p=glibc.git;a=blob;f=nptl/pthread_mutex_lock.c#l44
Spin-lock operations are supposed to be lighter
than a mutex ones on SMP, and that aspect of your suggestion is bothering me.
Maybe this should be called something other than "spinlock"?
What I want is something which allows for granular locking and is safe
to use from an ISR (when applicable). A spin lock is the only primitive
I know of which can do this in a RT or kernel environment. Outside of
this environment I don't care if it sleeps or not (I can't prevent this
anyway).
I'm also depending on the recursive behavior of both epicsMutex and
epicsInterruptLock.
Does this seem like an unusual use case?
Michael
- Re: "spinlock" API Michael Davidsaver
- "spinlock" API Michael Davidsaver
- Re: "spinlock" API Andrew Johnson
<2012>
2025
2026
<2012>
2025
2026
