2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base
Date: Tue, 03 Jul 2012 13:35:21 -0000
> [...] The _main_ thread gets its epicsThreadOSD structure created and
> added to pthreadList inside the once() routine in od/posix/osdThread.c before
> epicsThreadHooksInit() is run.  The Init() routine cannot call any other
> epicsThread... routines such as epicsThreadGetIdSelf() because once() hasn't
> finished yet.
I don't like all thread start hooks to inherit this limitation, so I implemented this using a second default hook, that is exclusively used for _main_.
So - if I did not miss anything - the list seems to be worked through, again.
~Ralph
https://code.launchpad.net/~ralph-lange/epics-base/thread-hooks/+merge/112806
Your team EPICS Core Developers is requested to review the proposed merge of lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base.
Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base Andrew Johnson
Prev: Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base Ralph Lange
Next: Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 26 Nov 2012 · Home · News · About · Talk · Base · Modules · Extensions ·
