Subject: |
Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base |
Andrew Johnson <[email protected]> |
To: |
Ralph Lange <[email protected]> |
Date: |
Mon, 02 Jul 2012 21:30:26 -0000 |
Sorry, a few more, although they're minor.
Please don't mark new API routines with epicsShareAPI; I'm trying to phase that out since almost nobody needs to use Pascal calling conventions on Windows any more. It's really only needed for routines that may be called by Visual Basic (if there are any users of that left), so it may still be necessary on CA API routines but not really on most others.
This may be more of a discussion point. Here's my output from epicsThreadShowAll:
epics> epicsThreadShowAll
NAME EPICS ID LWP ID OSIPRI OSSPRI STATE
_main_ 0x10b1060 0 0 0 OK
errlog 0x113c830 20849 10 0 OK
taskwd 0x113cc80 20850 10 0 OK
timerQueue 0x113d5e0 20851 70 0 OK
cbLow 0x113d8c0 20852 59 0 OK
cbMedium 0x113db90 20853 64 0 OK
cbHigh 0x113de60 20854 71 0 OK
dbCaLink 0x113e300 20855 50 0 OK
scanOnce 0x113ea10 20856 70 0 OK
scan-10 0x114d670 20857 60 0 OK
scan-5 0x114d8b0 20858 61 0 OK
scan-2 0x114daf0 20859 62 0 OK
scan-1 0x114dd30 20860 63 0 OK
scan-0.5 0x114df70 20861 64 0 OK
scan-0.2 0x114e1b0 20862 65 0 OK
scan-0.1 0x114e3f0 20863 66 0 OK
CAS-TCP 0x114ebc0 20864 18 0 OK
CAS-beacon 0x7f043c000990 20865 17 0 OK
CAS-UDP 0x7f0440000970 20866 16 0 OK
The _main_ thread is not started using epicsThreadCreate() and thus never runs the thread_hook, so we don't know its LWP ID. It would be nice if we could see it here. The _main_ thread gets its epicsThreadOSD structure created and added to pthreadList inside the once() routine in od/posix/osdThread.c before epicsThreadHooksInit() is run. The Init() routine cannot call any other epicsThread... routines such as epicsThreadGetIdSelf() because once() hasn't finished yet. Maybe epicsThreadHooksInit() could take main's epicsThreadId as an argument and (if non-zero) call the StartHook for it?
I think we can safely forget about calling _main_'s ExitHook, which brings up the interesting question of whether ExitHook is actually needed -- any StartHook can register an epicsAtThreadExit() routine if it needs to do clean-up. If we were to remove the ExitHooks we would never have problems with an ExitHook being called for a thread for which where there was no corresponding StartHook. It also means that the ExitHook routines would be run in the reverse order of the StartHook routines, whereas at the moment the order is the same.
- Andrew
https://code.launchpad.net/~ralph-lange/epics-base/thread-hooks/+merge/112806
Your team EPICS Core Developers is requested to review the proposed merge of lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base.
- Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base Ralph Lange
- [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base Ralph Lange
Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base Andrew Johnson
<2012>
2025
2026
<2012>
2025
2026
