2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base
Date: Tue, 03 Jul 2012 11:12:19 -0000
> Please don't mark new API routines with epicsShareAPI; I'm trying to phase
> that out [...]
Will do.
> This may be more of a discussion point.  Here's my output from
> epicsThreadShowAll:
> epics> epicsThreadShowAll
>             NAME     EPICS ID   LWP ID   OSIPRI  OSSPRI  STATE
>           _main_    0x10b1060        0      0       0       OK
>           errlog    0x113c830    20849     10       0       OK
> The _main_ thread is not started using epicsThreadCreate() and thus never runs
> the thread_hook, so we don't know its LWP ID.  It would be nice if we could
> see it here.
I had considered this, then decided against, as the POSIX implementation shows the POSIX thread id as 0, and I wanted to stay minimally invasive.
If you think this is a good idea (I do), I will add that.
> I think we can safely forget about calling _main_'s ExitHook, which brings up
> the interesting question of whether ExitHook is actually needed -- any
> StartHook can register an epicsAtThreadExit() routine if it needs to do clean-
> up.  If we were to remove the ExitHooks we would never have problems with an
> ExitHook being called for a thread for which where there was no corresponding
> StartHook.
Good! That was my initial approach, and I added the ExitHook routines only out of a gut feeling that I wold have to justify if I didn't.
The argument about an exit hook being called where the start hook wasn't added at thread creation time is an excellent one.
> It also means that the ExitHook routines would be run in the
> reverse order of the StartHook routines, whereas at the moment the order is
> the same.
Not true. They are run in correct (reverse) order, which is covered by the test. Never mind.
~Ralph
https://code.launchpad.net/~ralph-lange/epics-base/thread-hooks/+merge/112806
Your team EPICS Core Developers is requested to review the proposed merge of lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base.
Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base Andrew Johnson
Prev: Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base Ralph Lange
Next: Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base Andrew Johnson
ANJ, 26 Nov 2012 · Home · News · About · Talk · Base · Modules · Extensions ·
