2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: double buffered waveformRecord
To: [email protected]
Date: Wed, 23 Jan 2013 12:01:28 -0500
On 1/23/2013 10:02 AM, Michael Davidsaver wrote:
On 1/22/2013 8:39 PM, Andrew Johnson wrote:
You can simplify it even more; use &prec->val instead of &prec->bptr as the field identifier to db_post_event() because cvt_dbaddr() doesn't need to change the paddr->pfield value at all then, it's already pointing to the val field on entry.
Ok, I'll try this.
Updated
https://code.launchpad.net/~epics-core/epics-base/array-opt
double buffered waveformRecord Michael Davidsaver
Re: double buffered waveformRecord Andrew Johnson
Re: double buffered waveformRecord Michael Davidsaver
Re: double buffered waveformRecord Ralph Lange
Prev: Re: double buffered waveformRecord Michael Davidsaver
Next: Re: [Merge] lp:~epics-core/epics-base/spinlocks into lp:epics-base Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
