2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Enumerated string comparisons
To: <[email protected]>
Date: Thu, 10 Oct 2013 00:58:16 +0200
Am Mittwoch, 9. Oktober 2013, 14:17:36 schrieb Michael Davidsaver:
> On 10/09/2013 11:17 AM, Benjamin Franksen wrote:
> > Am Mittwoch, 9. Oktober 2013, 16:38:53 schrieb Johnson, Andrew N.:
> >> Question for core developers: Should we modify the Enum string
> >> parser
> >> to try using case-independent or other fuzzy string comparisons if
> >> a
> >> string value doesn't match using the case-dependent comparison or
> >> after trying to convert the string to an integer? We could make the
> >> IOC dwim ("do what I mean", a Perl term) in the case below, but the
> >> result is a less precise database so I'm not sure if this is a good
> >> idea or not and how far we should take it.
> > I share your reservations about making the parser more dwim. My main
> > objective is that it makes the specification more complex.
> Me too.  It is occasionally annoying, but I think better in the long
> term, to have strict matching.
I would vote for strict matching *if* we had an established convention
how to name choices. Unfortunately this is not the case and for reasons
of tradition and compatibility it is probably not going to happen.
Therefore I see a case for some very limited sort of dwimming, namely:
(1) Case-insensitive matching.
(2) Identifying underline '_' and space ' '.
Both points listed have a simple, straight-forward specification.
And for both we lack an established convention: some choices are upper
case, some lower, some mixed; some choices use underline to separate
words, some use space. This makes the exact spelling of the choice names
hard to remember.
On the other hand, we might actually chose to establish a convention. My
favourite candidate would be to use all lower case and space as a word
separator. That would mean changing lots of menu definitions and now the
problem becomes one of compatibility. That could be solved by an
extension of the dbd syntax that allows to define aliases for menu
choice names.
Cheers
Ben
"Make it so they have to reboot after every typo." -- Scott Adams
Attachment: signature.asc
Description: This is a digitally signed message part.
Re: Enumerated string comparisons Eric Norum
Re: Enumerated string comparisons Benjamin Franksen
Re: Enumerated string comparisons Michael Davidsaver
Prev: Re: Enumerated string comparisons Michael Davidsaver
Next: Re: Enumerated string comparisons Eric Norum
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
