2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Status of epicsShareAPI
To: <[email protected]>
Date: Thu, 18 Sep 2014 10:03:00 -0500
Hi Ben,
On 09/18/2014 04:23 AM, Benjamin Franksen wrote:
> This comment is in shareLib.h (base 3.14.12.2):
>  * epicsShareAPI is deprecated for new routines, don't use it!
>  * In a future major release (R3.15) we will remove this keyword
>  * from most EPICS APIs, although CA may continue to use it.
>  * This is a major release though, since it affects the order
>  * that arguments are pushed onto the stack on Windows and we
>  * don't want a replacement DLL to silent cause mayhem...
> This leaves me guessing what support modules should do if they are
> supposed to run with 3.14 and 3.15: use epicsShareAPI or not? In the
> sequencer I have removed them for version 2.2 and I wonder now if that
> could cause problems..,
> Looking at the current 3.15 sources I see header files where it is still
> present. What's the status?
The epicsShareAPI was needed to allow some Windows older code such as
Visual Basic to call routines in libCom and libCa; on Windows compilers
it expands out to __stdcall
    http://en.wikipedia.org/wiki/X86_calling_conventions
Note that __stdcall does not permit varargs to be used because the code
being called is responsible for removing arguments from the stack,
whereas in the __cdecl convention the caller does that.
For code that does not implement a public API there is no reason to use
epicsShareAPI. The only time when it might be worth considering is when
you are creating an API that might be used on Windows by languages that
only support the __stdcall convention. I have removed epicsShareAPI from
many of the internal APIs inside the IOC.
I don't intend to remove the keyword, so whether you use it is up to
you; the declarations in cadef.h and some of the libCom headers will
probably continue to use it for the foreseeable future.
HTH,
- Andrew
Re: Status of epicsShareAPI Benjamin Franksen
Prev: Status of epicsShareAPI Benjamin Franksen
Next: Re: Status of epicsShareAPI Benjamin Franksen
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 18 Sep 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
