On 11/17/2014 06:24 PM, Benjamin Franksen wrote:
>> Since you are running the latest, can you arrange to set the global
>> variable atExitDebug=1 (defined in epicsExit.c)? This should give some
>> clue about where in the exit sequence things are crashing.
> It ends now with:
> ...as before...
> Results
> Tests: 24
> Passed: 24 = 100.00%
> Instance 0 of sequencer program "bittypesTest" terminated
> atExit 0x4055f0((nil))
> atExit dbProcessNotifyExit((nil))
Ok, so I ran your unittest :) and see the same. I think this is an
actual bug which arises because dbProcessNotifyExit() doesn't block
until pending operations complete.
In this case the pending operation arising from seq_pvPut() as CA put
with callback operations now use dbNotify in 3.15.
Michael
- 3.15.0.2: Shutdown issues Ralph Lange
- Re: 3.15.0.2: Shutdown issues Benjamin Franksen
- Re: 3.15.0.2: Shutdown issues Michael Davidsaver
Jenkins build is back to normal : epics-base-3.15-win64s #99 APS Jenkins
Jenkins build is back to normal : epics-base-3.15-win32s #98 APS Jenkins
<2014>
2025
2026
<2014>
2025
2026
