On 05/05/2015 03:43 AM, Ralph Lange wrote:
> The RPM check assumes the standard scenario where the 'build' target
> builds and the 'install' target installs. So you can safely have the
> debug information in the libraries contain the build location path,
> because the install moves it to a different location - and that new
> location is what the check-buildroot checks against.
Is this check really being done before debug symbols are (or would be)
stripped? As I think about this, I would expect that this situation
would be handled by checking after the creation of a *-debuginfo .rpm
(using the ELF .gnu_debuglink extension).
- Re: Weird behavior when linking libgdd Ralph Lange
- Weird behavior when linking libgdd Ralph Lange
- Re: Weird behavior when linking libgdd Andrew Johnson
<2015>
2025
2026
<2015>
2025
2026
