On 05/05/2015 13:26, Michael Davidsaver wrote:
On 05/05/2015 03:43 AM, Ralph Lange wrote:
The RPM check assumes the standard scenario where the 'build' target
builds and the 'install' target installs. So you can safely have the
debug information in the libraries contain the build location path,
because the install moves it to a different location - and that new
location is what the check-buildroot checks against.
Is this check really being done before debug symbols are (or would be)
stripped? As I think about this, I would expect that this situation
would be handled by checking after the creation of a *-debuginfo .rpm
(using the ELF .gnu_debuglink extension).
The check is being done after stripping. But:
Only the shared libraries are stripped.
The test fails for the static library and the debuginfo parts. The
shared library passes.
(This sounds silly. I know. Don't ask me.)
~Ralph
- Re: Weird behavior when linking libgdd Michael Davidsaver
- Weird behavior when linking libgdd Ralph Lange
- Re: Weird behavior when linking libgdd Andrew Johnson
- Re: Weird behavior when linking libgdd Ralph Lange
<2015>
2025
2026
<2015>
2025
2026
