2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ../../../src/ioc/rsrv/online_notify.c: CA beacon routing
To: Torsten Bögershausen <[email protected]>
Cc: EPICS Core-Talk <[email protected]>
Date: Tue, 26 May 2015 11:19:03 +0000
Hi Torsten,
On May 26, 2015, at 7:36 AM, Torsten Bögershausen <[email protected]> wrote:
> Running BASE_3.15.1 under Mac OS X 10.9 there are lots these messages:
> ../../../src/ioc/rsrv/online_notify.c: CA beacon routing (connect to "192.168.0.255:5065") error was "Connection refused"
> Is this a known issue ?
That message probably means that your network router is sending back an ICMP error whenever the IOC sends out a broadcast beacon. Is this running on a permanently connected workstation that happens to live behind a NAT box, or is it a laptop with a temporary connection? If the only clients that need to connect to this are found on the local machine you could set EPICS_CA_AUTO_ADDR_LIST to NO and EPICS_CA_ADDR_LIST to localhost before starting the IOC which should stop the messages.
The beacon sending code in RSRV is not terribly good at limiting the number of error messages it prints from this kind of error, it could use some improvement.
- Andrew
Sent from my iPad
../../../src/ioc/rsrv/online_notify.c: CA beacon routing Torsten Bögershausen
Prev: Re: ../../../src/ioc/rsrv/online_notify.c: CA beacon routing Michael Davidsaver
Next: Re: ../../../src/ioc/rsrv/online_notify.c: CA beacon routing Torsten Bögershausen
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ../../../src/ioc/rsrv/online_notify.c: CA beacon routing Torsten Bögershausen
Next: Build failed in Jenkins: epics-base-3.15-cyg64 #204 APS Jenkins
