2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ../../../src/ioc/rsrv/online_notify.c: CA beacon routing
To: <[email protected]>, <[email protected]>
Date: Tue, 26 May 2015 16:56:43 +0200
It's a my Mac laptop behind a NAT (in this case an Apple Time Capsule, if that matters)
Setting the 2 variables did help, (and Linux didn't complain)
Thank for the help
On 26/05/15 13:18, Michael Davidsaver wrote:
On 05/26/2015 02:36 AM, Torsten Bögershausen wrote:
Hej,
Running BASE_3.15.1 under Mac OS X 10.9 there are lots these messages:
../../../src/ioc/rsrv/online_notify.c: CA beacon routing (connect to
"192.168.0.255:5065") error was "Connection refused"
Is this a known issue ?
The error is almost certainly due to a local firewall rule.  You can
avoid the message by setting
export EPICS_CA_AUTO_ADDR_LIST=NO
export EPICS_CA_ADDR_LIST=192.168.X.255
where X is the subnet (not 0) to which CA broadcasts should be sent.
../../../src/ioc/rsrv/online_notify.c: CA beacon routing Torsten Bögershausen
Re: ../../../src/ioc/rsrv/online_notify.c: CA beacon routing Michael Davidsaver
Prev: Re: ../../../src/ioc/rsrv/online_notify.c: CA beacon routing Johnson, Andrew N.
Next: Jenkins build is back to stable : epics-base-3.15 #204 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ../../../src/ioc/rsrv/online_notify.c: CA beacon routing Michael Davidsaver
Next: Re: ../../../src/ioc/rsrv/online_notify.c: CA beacon routing Johnson, Andrew N.
