Subject: |
Re: Build failed in Jenkins: epics-base-3.16-linux32-test #13 |
Andrew Johnson <[email protected]> |
To: |
Date: |
Mon, 15 Feb 2016 18:07:46 -0600 |
On 02/15/2016 05:33 PM, Michael Davidsaver wrote:
> On 02/12/2016 12:33 PM, Andrew Johnson wrote:
>> On 02/12/2016 11:06 AM, APS Jenkins wrote:
>>> src/std/rec/test/O.linux-x86/arrayOpTest.tap ............. ok
>>> src/std/rec/test/O.linux-x86/asTest.tap .................. ok
>>> Bailout called. Further testing stopped: testMonitorWait() exceeds timeout
>>> FAILED--Further testing stopped: testMonitorWait() exceeds timeout
>> My fix was just to re-run the tests; given that this failure has
>> happened before on a different architecture, I think the 10 second
>> timeout delay in testMonitorWait() is just too short for a busy build
>> slave. Since the effect of failure is to kill all further testing I have
>> bumped it all the way up to 60 seconds.
> It's happened again. From the .tap log the timeout is a symptom of a
> previous failure. I'm guessing this was the case previously.
This time it failed on the linux-x86_64 Jenkins master CPU; previously
it was on the linux-x86 (i.e. 32-bit) build slave, so the two are not
quite the same.
>> 1..10
>> ## EPICS R3.16.0-DEV $$Date$$
>> ## EPICS Base built Feb 15 2016
>> ok 1 - dbGetField("rec:ai", 8) -> 0.000000e+00 == 0.000000e+00
>> ok 2 - dbGetField("rec:ai.INP", 0) -> "0" == "0"
>> not ok 3 - dbPutField(rec:link1.PROC, 5, ...) == -1
>> Bail out! testMonitorWait() exceeded 60 second timeout
> I haven't yet been able to replicate this locally.
IIRC previous failures didn't show any failed tests before testAbort()
was called, so this may be a different problem and not just a case of a
too-busy CPU. Could there be something racy in the above test?
- Andrew
There are only two hard problems in distributed systems:
2. Exactly-once delivery
1. Guaranteed order of messages
-- Mathias Verraes
- Re: Build failed in Jenkins: epics-base-3.16-linux32-test #13 Michael Davidsaver
- Build failed in Jenkins: epics-base-3.16-linux32-test #13 APS Jenkins
- Re: Build failed in Jenkins: epics-base-3.16-linux32-test #13 Andrew Johnson
<2016>
2025
2026
<2016>
2025
2026
