On 03/16/2016 02:56 AM, Torsten Bögershausen wrote:
> In general, yes.
> But: This is really compiler dependent.
> A better approach would be to go through the code base, and rework the problematic code,
> step by step.
FYI, the fix Andrew mentions would probably entail changing all record
struct definitions to compose dbCommon. Which is doable as this is
generated code (cf. dbdToRecordtypeH.pl).
> typedef struct {
> dbCommon com;
> } longinRecord;
However, I don't know of a way to do this* without breaking existing
code which accesses common fields through a specific pointer.
> longinRecord *prec = ...
> prec->scan = ...
would have to be changed to use "prec->com.scan".
I suppose we could add and start start encouraging the use of a macro to
access dbCommon fields, but this would be a lot of churn...
* for C++ it might be tempting to think about using inheritance, but
this would run afoul of the fact that offset() is undefined for non-POD
types in c++98.
- Strict aliasing blog-post Andrew Johnson
- Re: Strict aliasing blog-post Torsten Bögershausen
Re: Strict aliasing blog-post Michael Davidsaver
<2016>
2025
2026
CA Gateway moved to GitHub Ralph Lange
<2016>
2025
2026
