2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build problem in pvData with VS 2015
Date: Fri, 9 Sep 2016 22:36:16 +0000
Folks,
I am testing the master branch of pvDataCPP.  I built successfully on linux-x86, vxWorks-ppc32, window-x64-static with Visual Studio 2010, win32-x86-mingw, and win32-x86-mingw-static.
However, I got the following errors when I built on Visual Studio 2015, windows-x64-static.
make[2]: Entering directory 'H:/epics/pvPackageCPP-3.15/pvData/src/O.windows-x64-static-vs2015'
cl -EHsc -GR                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355        -MT  -TP  -I. -I../O.Common -I. -I. -I..
-I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/monitor -I../../include/compiler/msvc -I../../include/os/W
IN32 -I../../include    -IH:/epics/base-3.15.4/include/compiler/msvc -IH:/epics/base-3.15.4/include/os/WIN32 -IH:/epics/base-3.15.4/include   -IH:/epics/pvPackageCPP-3.15/pvDatabas
e/include   -IH:/epics/pvPackageCPP-3.15/pvaSrv/include   -IH:/epics/pvPackageCPP-3.15/pvaClient/include   -IH:/epics/pvPackageCPP-3.15/pvAccess/include   -IH:/epics/pvPackageCPP-3
.15/normativeTypes/include   -IH:/epics/pvPackageCPP-3.15/pvData/include   -IH:/epics/pvPackageCPP-3.15/pvCommon/include        -c ../../src/misc/bitSet.cpp
bitSet.cpp
C:\Program Files (x86)\Windows Kits\8.1\include\um\dbghelp.h(1544): warning C4091: 'typedef ': ignored on left of '' when no variable is declared
C:\Program Files (x86)\Windows Kits\8.1\include\um\dbghelp.h(3190): warning C4091: 'typedef ': ignored on left of '' when no variable is declared
../../src/misc/bitSet.cpp(71): error C2039: 'max': is not a member of 'std'
..\pv/pvIntrospect.h(1312): note: see declaration of 'std'
../../src/misc/bitSet.cpp(71): error C3861: 'max': identifier not found
../../src/misc/bitSet.cpp(178): warning C4267: 'return': conversion from 'size_t' to 'epics::pvData::int32', possible loss of data
../../src/misc/bitSet.cpp(195): warning C4267: 'return': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
../../src/misc/bitSet.cpp(203): error C2039: 'min': is not a member of 'std'
../../src/misc/bitSet.cpp(203): error C3861: 'min': identifier not found
../../src/misc/bitSet.cpp(217): error C2039: 'max': is not a member of 'std'
../../src/misc/bitSet.cpp(217): error C3861: 'max': identifier not found
../../src/misc/bitSet.cpp(229): error C2039: 'max': is not a member of 'std'
../../src/misc/bitSet.cpp(229): error C3861: 'max': identifier not found
../../src/misc/bitSet.cpp(254): error C2039: 'min': is not a member of 'std'
../../src/misc/bitSet.cpp(254): error C3861: 'min': identifier not found
../../src/misc/bitSet.cpp(255): error C2039: 'max': is not a member of 'std'
../../src/misc/bitSet.cpp(255): error C3861: 'max': identifier not found
../../src/misc/bitSet.cpp(287): warning C4267: 'initializing': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
H:/epics/base-3.15.4/configure/RULES_BUILD:234: recipe for target 'bitSet.obj' failed
make[2]: *** [bitSet.obj] Error 2
make[2]: Leaving directory 'H:/epics/pvPackageCPP-3.15/pvData/src/O.windows-x64-static-vs2015'
H:/epics/base-3.15.4/configure/RULES_ARCHS:61: recipe for target 'install.windows-x64-static-vs2015' failed
make[1]: *** [install.windows-x64-static-vs2015] Error 2
make[1]: Leaving directory 'H:/epics/pvPackageCPP-3.15/pvData/src'
H:/epics/base-3.15.4/configure/RULES_DIRS:88: recipe for target 'src.install' failed
make: *** [src.install] Error 2
A Google search provided the solution, which is to include <algorithm>.
Here is the fix:
corvette:epics/pvPackageCPP-3.15/pvData>git diff
diff --git a/src/misc/bitSet.cpp b/src/misc/bitSet.cpp
index f9b6798..596ad11 100644
--- a/src/misc/bitSet.cpp
+++ b/src/misc/bitSet.cpp
@@ -10,6 +10,7 @@
#include <stdio.h>
#include <iostream>
#include <stdexcept>
+#include <algorithm>
With this change pvData compiles with Visual Studio 2015.
EPICS 3.15.4 on RTEMS rtems-4.11.99.0 (PowerPC/Generic (classic FPU)/beatnik) Heinz Junkes
Prev: Re: Fix for building 3.15.4 on windows-x64-static Heinz Junkes
Next: EPICS 3.15.4 on RTEMS rtems-4.11.99.0 (PowerPC/Generic (classic FPU)/beatnik) Heinz Junkes
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Errors when running "make -sj clean" on windows-x64 in top-level of pvPackageCPP Johnson, Andrew N.
ANJ, 18 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
