I run in exactly the same issue while porting EPICS 3.15 base to RTEMS 4.12.
I have to switch off the optimization in libCom/calc/postfix.c to get
libComTestHarness.boot to run successfully.
—— libCom/calc/postfix.c —
* Copyright (c) 2010 UChicago Argonne LLC, as Operator of Argonne
* National Laboratory.
* Copyright (c) 2002 The Regents of the University of California, as
* Operator of Los Alamos National Laboratory.
* EPICS BASE is distributed subject to a Software License Agreement found
* in file LICENSE that is included with this distribution.
* Subroutines used to convert an infix expression to a postfix expression
* Original Author: Bob Dalesio
* Date: 12-12-86
#include <stdio.h>
#include <string.h>
#include <ctype.h>
#define epicsExportSharedSymbols
#include "dbDefs.h"
#include "epicsAssert.h"
#include "epicsStdlib.h"
#include "epicsString.h"
#include "epicsTypes.h"
#include "postfix.h"
#include "postfixPvt.h"
#include "shareLib.h"
#pragma GCC push_options
#pragma GCC optimize ("O0")
/* declarations for postfix */
/* element types */
typedef enum {
OPERAND,
case ISNAN:
printf("\t%s, %d arg(s)\n", opcodes[(int) op], *++pinst);
pinst++;
break;
default:
printf("\t%s\n", opcodes[(int) op]);
pinst++;
#pragma GCC pop_options
As this is (until now) the only place I had to switch off -03 I would prefer solution 3
Heinz
> On 08 Sep 2016, at 18:26, Mark Rivers <[email protected]> wrote:
> It seems to me there are 4 ways to solve the problem:
> 1) The existing 3.15.4. solution which is to set HOST_OPT=NO. This solution is bad because it sets /MTd flag, leading to different versions of the C runtime library from what is expected. Note that the existing solution also has a #pragma optimize() in calcPerform.c but not in online_notify.c, so it is not consistent. When was the #pragma optimize() added to calcPerform.c, and what is the commit comment? Why was the same thing not done for online_notify.c?
> 2) The solution I proposed yesterday. As in the existing solution, this is in the CONFIG_SITE file, only for 64-bit static builds. It is better than the existing solution because it only removes the -GL flag, and leaves other optimizations enabled. It is clean because it requires no modification of any source code files, except removing the #pragma from calcPerform.c which is nice but not necessary. Modifying calcPerform.c removes the warning messages that are generated because of the #pragma optimize():
> " base-3.15.4\src\libcom\calc\calcperform.c(47) warning C4748: /GS can not protect parameters and local variables from local buffer overrun because optimizations are disabled in function"
> 3) Modify the Makefile in each directory that has a problem. This has the advantage of not modifying the source code, yet allows being specific to a particular source file. Disadvantages:
> - By redefining OPT_CFLAGS_YES or OPT_CXXFLAGS_YES these may be specific to a particular version of base.
> - It would require some additional changes to base to allow only doing this for Visual Studio 2010.
> - Since we don't know what triggers the compiler error small changes to a source file may introduce the problem into a file that previously compiled OK. This may be done by someone who is not testing on VS 2010 with 64-bit static builds, and so may not be discovered until it is too late. The Makefile would then need to be modified.
> 4) Modify each source code file that has the problem to use #pragma optimize().
> Disadvantages:
> - Requires changing 2 files in base, and at least 5 files in motor, perhaps many more, and perhaps more files in synApps that have not yet been tested because of the errors in motor.
> - All that really needs to be done is to disable program-wide optimization (/GL flag), but I cannot find a #pragma to do this. This means that local optimization must be disabled, which results in the following warning every time that function is linked into a program:
> "warning C4748: /GS can not protect parameters and local variables from local buffer overrun because optimizations are disabled in function"
> - How do we only disable optimization for 3.15, not 3.14?
> On balance I like solution 2. It modifies only a single file (except removing the #pragma from calcPerform.c which is nice but not necessary), and appears to be robust against future modifications to source files. But I'm open to persuasion!
> Mark
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf Of Andrew Johnson
> Sent: Thursday, September 08, 2016 10:34 AM
> To: [email protected]
> Subject: Re: Fix for building 3.15.4 on windows-x64-static
> On 09/08/2016 09:20 AM, Mark Rivers wrote:
>> Searching for the presence of "Visual Studio 10.0" in the PATH
>> environment variable might work.
> If the build system really needs to know which compiler version it's
> using I would much rather we have the user tell it that in their
> CONFIG_SITE.Common.win* file(s). The build system has to run any kind of
> per-compiler test every time it reads a Makefile, and calling out to a
> Perl script to do this kind of test every time is probably going to slow
> the build measurably.
> On the other hand doing this kind of thing using the pre-processor and a
> #pragma optimize() setting is fast and localized, so I would much prefer
> that we stick with that solution if it can do what we need. You can tell
> whether you're building a dynamic binary there by the presence of the
> EPICS_BUILD_DLL macro.
> - Andrew
> Arguing for surveillance because you have nothing to hide is no
> different than making the claim, "I don't care about freedom of
> speech because I have nothing to say." -- Edward Snowdon
smime.p7s
Description: S/MIME cryptographic signature
- Fix for building 3.15.4 on windows-x64-static Mark Rivers
- RE: Fix for building 3.15.4 on windows-x64-static Mark Rivers
- Re: Fix for building 3.15.4 on windows-x64-static Ralph Lange
- Re: Fix for building 3.15.4 on windows-x64-static Andrew Johnson
Build problem in pvData with VS 2015 Mark Rivers
<2016>
2025
2026
<2016>
2025
2026
