Hi Michael,
A couple of points.
* The recGblCheckDeadband() function accepts monitor mask as
(unsigned*), which happens to be the same as (epicsUInt32*). In my mind
though this should be explicit and the 'monitor_mask' local in
aiRecord.c should be 'unsigned'.
* Changing a local loop index from 'int i' to 'epicsInt32 i' doesn't
seem to me so useful. Better to check if it can be made unsigned or size_t.
* In permissiveRecord.c you change some locals from 'unsigned short' to
epicsUInt16 which is fine, but you also initialize them to zero when
they were previously not initialized. In this case it's a no-op as the
zeros are immediately replaced. In general I think it's better to leave
locals uninitialized unless the value will be used.
gcc at least will in many cases warn about possible unconditional use of
uninitialized locals. I like to give the compiler an opportunity to
tell me when I'm making a mistake :)
Also, I'd rather not see the type repeated four times. So better to
make this:
epicsUInt16 val = prec->val,
oval = prec->oval,
wflg = prec->wflg;
oflg = prec->oflg;
Thanks for your comments and explanation. It is the real one that I
would like to listen from like you. Thank you.
I will re-think and re-do to create the patch file according to your
comments and suggestions.
Han
- Patch file for Records which use consistent epics data types Jeong Han Lee
- Re: Patch file for Records which use consistent epics data types Michael Davidsaver
Jenkins build is back to normal : epics-base-3.16-win64-test #50 APS Jenkins
<2017>
2025
2026
Build failed in Jenkins: epics-base-3.16-mac-test #78 APS Jenkins
<2017>
2025
2026
ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
