2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS 7.0.1-pre1
To: <[email protected]>
Date: Mon, 20 Nov 2017 11:41:37 -0600
On 11/20/2017 11:30 AM, Hartman, Steven M. wrote:
>> On Nov 20, 2017, at 11:05 AM, Timo Korhonen <[email protected]> wrote:
>> Everything seems to be going fine until trying to create the
>> .gitattributes file. After that, no files could be created.
>> However, even those files that tar claimed to be able to create were not
>> there. Directories are but they are empty.
> Yes, I see the same on my Mac.
>> x ./base-7.0.1-pre1/
>> x ./base-7.0.1-pre1/.gitattributes: Can't create
>> ‘base-7.0.1-pre1/.gitattributes'
> If you look at output, you will see that this is actually the second time it tries to extract .gitattributes . . .
> $ grep -n gitattribute mactar.out
> 3:x ./base-7.0.1-pre1/.gitattributes
> 2648:x ./base-7.0.1-pre1/.gitattributes: Can’t
>  create 'base-7.0.1-pre1/.gitattributes'
> In the tar file, we see . . .
> $ tar ztvf base-7.0.1-pre1.tar.gz | grep gitattributes
> -rw-rw-r--  0 anj    aesctl    111 Nov 16 12:55 ./base-7.0.1-pre1/.gitattributes
> hrw-rw-r—  0 anj    aesctl      0 Nov 16 12:55 ./base-7.0.1-pre1/.gitattributes link to ./base-7.0.1-pre1/.gitattributes
> Apparently, the bsd tar on the mac doesn’t like that link (or the others in the tarfile).
I have an updated tarfile for the same tag, generated with the newer
version of the make-tar.sh script so it excludes a few more files than
before (no .gitignore files for instance). Should I replace the existing
tarfile and its GPG signature file?
BTW, does anyone ever bother to check GPG signatures?
I don't know why the original had those duplicated entries, the new
version without duplicates was run with exactly the same copies of git
and tar (so Michael's speculation about the tar version doesn't seem to
be right).
- Andrew
Re: EPICS 7.0.1-pre1 Michael Davidsaver
EPICS 7.0.1-pre1 Andrew Johnson
Re: EPICS 7.0.1-pre1 Timo Korhonen
Re: EPICS 7.0.1-pre1 Heinz Junkes
Re: EPICS 7.0.1-pre1 Hartman, Steven M.
Prev: Re: EPICS 7.0.1-pre1 Hartman, Steven M.
Next: Re: EPICS 7.0.1-pre1 Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
