I could build EPICS 7 for vxWorks 6.6, vxWorks 6.7 and ELDK 4.2 after
this fix. I checked the resulting libraries and executables for any
occurrence of (undefined) FieldName(const FieldName&) symbols. There are
none. So it seems the compiler wants to have the definition but never
actually uses it.
On 23.11.2017 14:21, Dirk Zimoch wrote:
This is my fix in pvif.h line 290:
#if defined(__GNUC__)&&__GNUC__*100+__GNUC_MINOR__<403
// workaround for gcc bug https://gcc.gnu.org/bugs/#cxx_rvalbind
public:
#else
private:
#endif
FieldName(const FieldName&);
FieldName& operator=(const FieldName&);
On 23.11.2017 12:03, Dirk Zimoch wrote:
On 23.11.2017 11:19, Dirk Zimoch wrote:
Clang 3.4.2 gives an interesting hint with its warnings. It seems that
this call creates a temporary, for which of course a copy is needed. If
you wanted to detect accidental copies, this is such a case.
I have analyzed the code a bit.
The message was:
"C++98 requires an accessible copy constructor for class 'FieldName'
when binding a reference to a temporary"
The line in question is:
pvif(channel->pv->builder->attach(channel->pv->chan, pvf, FieldName()))
This is the constructor call of pvif in the constructor of PDBSinglePut.
It is true, that a temporary is used here. FieldName() creates an object
that falls out of scope immediately after the attach() call.
The compiler cannot know what builder->attach() will do with with the
temporary. It has to expect the worst, which is to keep a reference to
the temporary FieldName object after the attach() call has returned.
Since this would then reference an invalid object.
So maybe the compiler rather implicitly creates a copy of which
builder->attach can keep a reference, like this: attach(new
FieldName(FieldName()))
I need to check the C++ standard to see what the documented behavior is
in such a case.
- EPICS 7.0.1-pre1 Andrew Johnson
- Re: EPICS 7.0.1-pre1 Dirk Zimoch
- Re: EPICS 7.0.1-pre1 (pdbsingle.cpp) Michael Davidsaver
- Re: EPICS 7.0.1-pre1 (pdbsingle.cpp) Dirk Zimoch
EPICS 7 makeBaseApp Timo Korhonen
<2017>
2025
2026
<2017>
2025
2026
ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
