> On Nov 26, 2017, at 10:19 AM, Heinz Junkes <[email protected]> wrote:
> make runtests on OS-X (10.13.1 High Sierra) works well except at the very end:
I tried on Mac 10.11.6 and saw related (?) errors in the pva2pva tests . . .
testweak.t .. ok
testtest.t .. dyld: Library not loaded: /Users/sh3/epics7/base-7.0.1-pre1/lib/darwin-x86/libtestutils.dylib
Referenced from: /Users/sh3/epics7/base-7.0.1-pre1/modules/pva2pva/testApp/O.darwin-x86/./testtest
Reason: image not found
testtest.t .. No subtests run
testmon.t ... dyld: Library not loaded: /Users/sh3/epics7/base-7.0.1-pre1/lib/darwin-x86/libtestutils.dylib
Referenced from: /Users/sh3/epics7/base-7.0.1-pre1/modules/pva2pva/testApp/O.darwin-x86/./testmon
testmon.t ... No subtests run
testpvif.t .. dyld: Library not loaded: /Users/sh3/epics7/base-7.0.1-pre1/lib/darwin-x86/libtestutils.dylib
Referenced from: /Users/sh3/epics7/base-7.0.1-pre1/modules/pva2pva/testApp/O.darwin-x86/./testpvif
testpvif.t .. No subtests run
testpdb.t ... dyld: Library not loaded: /Users/sh3/epics7/base-7.0.1-pre1/lib/darwin-x86/libtestutils.dylib
Referenced from: /Users/sh3/epics7/base-7.0.1-pre1/modules/pva2pva/testApp/O.darwin-x86/./testpdb
testpdb.t ... No subtests run
Test Summary Report
testtest.t (Wstat: 5 Tests: 0 Failed: 0)
Non-zero wait status: 5
Parse errors: No plan found in TAP output
testmon.t (Wstat: 5 Tests: 0 Failed: 0)
testpvif.t (Wstat: 5 Tests: 0 Failed: 0)
testpdb.t (Wstat: 5 Tests: 0 Failed: 0)
Files=5, Tests=37, 2 wallclock secs ( 0.03 usr 0.01 sys + 0.04 cusr 0.02 csys = 0.10 CPU)
Result: FAIL
Failed 4/5 test programs. 0/37 subtests failed.
This seems to be a build system problem. After that test failure, I can . . .
cd modules/pva2pva/testApp ; make clean ; make
And then
make runtests
And the tests will pass.
In the original build, modules/pva2pva/testApp/O.darwin-x86/testtest is trying to link to the nonexistent lib/darwin-x86/libtestutils.dylib, while in the re-build it is using the library found in modules/pva2pva/testApp/O.darwin-x86
From the make output . . .
c++ -o testtest -L/Users/sh3/epics7/base-7.0.1-pre1/lib/darwin-x86 -arch x86_64 testtest.o -ltestutils -lp2pcore -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
. . . vs . . .
c++ -o testtest -L/Users/sh3/epics7/base-7.0.1-pre1/modules/pva2pva/testApp/O.darwin-x86 -L/Users/sh3/epics7/base-7.0.1-pre1/lib/darwin-x86 -arch x86_64 testtest.o -ltestutils -lp2pcore -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
Should libtestutils.dylib be getting installed?
$ find . -name libtestutils.\*
./lib/darwin-x86/libtestutils.a
./modules/pva2pva/testApp/O.darwin-x86/libtestutils.a
./modules/pva2pva/testApp/O.darwin-x86/libtestutils.dylib
Looking at Heinz’s output again, his error is different. He has an installed /usr/local/lib/libtestutils.dylib which is referencing a nonexistent /usr/local/opt/jsoncpp/lib/libjsoncpp.11.dylib.
Heinz— Can you confirm that /usr/local/lib/libtestutils.dylib was installed from the current release and not left over from a prior build? (I don’t have a libjsoncpp on my system.)
Steven Hartman
[email protected]
- Re: EPICS 7.0.1-pre1 Andrew Johnson
- EPICS 7.0.1-pre1 Andrew Johnson
- Re: EPICS 7.0.1-pre1 Heinz Junkes
Re: EPICS 7.0.1-pre1 (spinlock.hpp) Andrew Johnson
Re: EPICS 7.0.1-pre1 Michael Davidsaver
<2017>
2025
2026
<2017>
2025
2026
