On 11/27/2017 04:04 PM, Hartman, Steven M. wrote:
>> On Nov 26, 2017, at 10:19 AM, Heinz Junkes <[email protected]> wrote:
>> make runtests on OS-X (10.13.1 High Sierra) works well except at the very end:
> I tried on Mac 10.11.6 and saw related (?) errors in the pva2pva tests . . .
I get the same errors when trying to run the test programs in
pva2pva/testApp.
> This seems to be a build system problem. After that test failure, I can . . .
> cd modules/pva2pva/testApp ; make clean ; make
> And then
> make runtests
> And the tests will pass.
Interesting, that doesn't fix the problem for me (probably with a
different MacOS version though, not sure exactly which). What does fix
it for me is to edit modules/pva2pva/testApp/Makefile and change
> TESTLIBRARY += testutils
into
but in theory that shouldn't be necessary. The first version tells
GNUmake to build the library but not install it. The second version
installs the library.
Ahh, this was the RULES_TARGET issue that I found last week and fixed in
3.15 and 3.16 but haven't merged up into 7.0 yet.
- Andrew
- Re: EPICS 7.0.1-pre1 Andrew Johnson
- EPICS 7.0.1-pre1 Andrew Johnson
- Re: EPICS 7.0.1-pre1 Heinz Junkes
- Re: EPICS 7.0.1-pre1 Hartman, Steven M.
Re: EPICS 7.0.1-pre1 Michael Davidsaver
<2017>
2025
2026
<2017>
2025
2026
