2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS 7.0.1-pre1
To: <[email protected]>
Date: Mon, 27 Nov 2017 17:05:18 -0600
On 11/27/2017 04:22 PM, Andrew Johnson wrote:
> Ahh, this was the RULES_TARGET issue that I found last week and fixed in
> 3.15 and 3.16 but haven't merged up into 7.0 yet.
Nope, I was looking at an out-of-date working tree, I did merge it up
already.
The libtestutils.dylib file only exists in the O.darwin-x86 directory,
so why does this command-line
> c++ -o testtest  -L/Users/anj/Software/base-7.0/modules/pva2pva/testApp/O.darwin-x86 -L/Users/anj/Software/base-7.0/lib/darwin-x86        -arch x86_64               testtest.o    -ltestutils -lp2pcore -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
put this load command into the testtest executable (amongst others)?
> Load command 12
>           cmd LC_LOAD_DYLIB
>       cmdsize 88
>          name /Users/anj/Software/base-7.0/lib/darwin-x86/libtestutils.dylib (offset 24)
>    time stamp 2 Wed Dec 31 18:00:02 1969
>       current version 0.0.0
> compatibility version 0.0.0
The file named there definitely does not exist.
I agree this isn't worth chasing right now. I would suggest applying
these changes instead:
diff --git a/testApp/Makefile b/testApp/Makefile
index fe01b35..3c740a8 100644
--- a/testApp/Makefile
+++ b/testApp/Makefile
@@ -14,12 +14,6 @@ p2pTestIoc_DBD += base.dbd
 # Tests explicitly create/destory PDB provider
 #p2pTestIoc_DBD += qsrv.dbd
-TESTLIBRARY += testutils
-testutils_SRCS += utilities.cpp
-testutils_LIBS += pvAccess pvData
-testutils_LIBS += $(EPICS_BASE_IOC_LIBS)
 TESTPROD_HOST += testweak
 testweak_SRCS += testweak.cpp
 testweak_LIBS += Com
@@ -27,13 +21,15 @@ TESTS += testweak
 TESTPROD_HOST += testtest
 testtest_SRCS += testtest.cpp
-testtest_LIBS += testutils p2pcore pvAccess pvData
+testtest_SRCS += utilities.cpp
+testtest_LIBS += p2pcore pvAccess pvData
 testtest_LIBS += $(EPICS_BASE_IOC_LIBS)
 TESTS += testtest
 TESTPROD_HOST += testmon
 testmon_SRCS += testmon.cpp
-testmon_LIBS += testutils p2pcore pvAccess pvData
+testmon_SRCS += utilities.cpp
+testmon_LIBS += p2pcore pvAccess pvData
 testmon_LIBS += $(EPICS_BASE_IOC_LIBS)
 TESTS += testmon
@@ -41,26 +37,30 @@ TESTS += testmon
 TESTPROD_HOST += testpvif
 testpvif_SRCS += testpvif.cpp
 testpvif_SRCS += p2pTestIoc_registerRecordDeviceDriver.cpp
-testpvif_LIBS += testutils qsrv pvAccess pvData
+testpvif_SRCS += utilities.cpp
+testpvif_LIBS += qsrv pvAccess pvData
 testpvif_LIBS += $(EPICS_BASE_IOC_LIBS)
 TESTS += testpvif
 TESTPROD_HOST += testpdb
 testpdb_SRCS += testpdb.cpp
 testpdb_SRCS += p2pTestIoc_registerRecordDeviceDriver.cpp
-testpdb_LIBS += testutils qsrv pvAccess pvData
+testpdb_SRCS += utilities.cpp
+testpdb_LIBS += qsrv pvAccess pvData
 testpdb_LIBS += $(EPICS_BASE_IOC_LIBS)
 TESTS += testpdb
 PROD_HOST += check_consist
 check_consist_SRCS += check_consist.cpp
-check_consist_LIBS += testutils pvAccess pvData
+check_consist_SRCS += utilities.cpp
+check_consist_LIBS += pvAccess pvData
 check_consist_LIBS += $(EPICS_BASE_IOC_LIBS)
 #TESTPROD_HOST += testpvalink
 testpvalink_SRCS += testpvalink.cpp
 testpvalink_SRCS += p2pTestIoc_registerRecordDeviceDriver.cpp
-testpvalink_LIBS += testutils qsrv pvAccess pvData
+testpvalink_SRCS += utilities.cpp
+testpvalink_LIBS += qsrv pvAccess pvData
 testpvalink_LIBS += $(EPICS_BASE_IOC_LIBS)
 #TESTS += testpvalink
- Andrew
EPICS 7.0.1-pre1 Andrew Johnson
Re: EPICS 7.0.1-pre1 Heinz Junkes
Re: EPICS 7.0.1-pre1 Hartman, Steven M.
Re: EPICS 7.0.1-pre1 Andrew Johnson
Prev: Re: EPICS 7.0.1-pre1 Andrew Johnson
Next: Re: EPICS 7.0.1-pre1 (spinlock.hpp) Dirk Zimoch
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS 7.0.1-pre1 Michael Davidsaver
