2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS 7.0.1-pre1 (spinlock.hpp)
Date: Tue, 28 Nov 2017 09:59:03 +0100
Since vxWorks 6.2 and 6.3 do not build anyway, this fix is obsolete.
On 27.11.2017 19:06, Andrew Johnson wrote:
Hi Dirk,
On 11/24/2017 01:33 AM, Dirk Zimoch wrote:
So far I needed only that one file.
I just added it to the master branch of the libcom submodule. If you're
testing by hand you'll need to do 'git submodule update --remote' to get
the latest versions of all the submodules, I haven't updated that module
version in the core module yet.
I will set up a Jenkis server in the next few days. However I fear due
to PSI networking regulations it will not be accessible from outside
PSI. Is it OK to send the messages to core-talk?
I usually wait until I have a job building without errors before I
direct its messages to core-talk, to try and cut down the noise from
Jenkins while getting it configured correctly.
- Andrew
EPICS 7.0.1-pre1 Andrew Johnson
Re: EPICS 7.0.1-pre1 Dirk Zimoch
Re: EPICS 7.0.1-pre1 (spinlock.hpp) Dirk Zimoch
Re: EPICS 7.0.1-pre1 (spinlock.hpp) Johnson, Andrew N.
Re: EPICS 7.0.1-pre1 (spinlock.hpp) Andrew Johnson
Prev: Re: EPICS 7.0.1-pre1 Andrew Johnson
Next: Re: EPICS 7.0.1-pre1 Heinz Junkes
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS 7.0.1-pre1 (spinlock.hpp) Andrew Johnson
Next: Re: EPICS 7.0.1-pre1 (client.cpp) Dirk Zimoch
