2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS 7.0.1-pre1 -- vxWorks 6.2
To: "Hartman, Steven M." <[email protected]>, Dirk Zimoch <[email protected]>
Date: Tue, 28 Nov 2017 16:46:00 +0000
Referring to Dirk's request earlier in this chain:
So it would be nice to have an option in one of the CONFIG files to
declare that a specific architecture should build EPICS 7 without PVA
support.
If I understand the intention right, he would like to be able to build the
EPICS 7 base for many architectures but so that not all of them are
required to support PVA.
I think that is a legitimate request: this way he can keep up with the
other updates in the base and does not have to abandon (at least
immediately) those architectures that are not able to support PVA.
I think this could make the adoption of EPICS 7 easier not only for Dirk
but for other sites, too. The change does not look impossible to me.
Timo
On 28/11/17 17:27, "[email protected] on behalf of Hartman,
Steven M." <[email protected] on behalf of [email protected]>
wrote:
>Hi Dirk—
>Andrew has been testing EPICS 7 with vxWorks 6.9 so that is the only
>version that has been known to be supported. Thanks for your testing and
>investigation with earlier versions of vxWorks (and embedded Linux).
>If I followed the email chain correctly, you now have patches to enable
>build with vxWorks 6.3, 6.6 and 6.7. Which version(s) of vxWorks do you
>anticipate being able to provide ongoing testing (with a continuous
>integration server) and help with troubleshooting?
>The EPICS 7.0.1 release candidate is coming soon, but additional
>supported targets can added later.
>Thanks,
>Steven Hartman
>[email protected]
Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Andrew Johnson
EPICS 7.0.1-pre1 Andrew Johnson
Re: EPICS 7.0.1-pre1 Dirk Zimoch
Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Dirk Zimoch
Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Hartman, Steven M.
Prev: Re: git question Dirk Zimoch
Next: Re: EPICS 7.0.1-pre1 (epicsException.h) Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Dirk Zimoch
Next: Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Andrew Johnson
