2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Doxygen documentation outside source files
To: EPICS Core Talk <[email protected]>
Date: Wed, 13 Dec 2017 08:57:34 +0100
Follow-up to yesterday's meeting:
If you look at the end of this paragraph
the file extensions for other files that may contain Doxygen blocks to be included in the generated documentation, while being excluded from the file list may be .dox, .txt or .doc
So - that would make .dox appropriate for files that contains only Doxygen blocks, while restructured text (that we were talking about IIRC) should probably have .txt.
Would you agree?
~Ralph
Re: Doxygen documentation outside source files Andrew Johnson
Prev: Jenkins build is back to normal : epics-master-windows » STATIC,win64 #27 APS Jenkins
Next: converting strings to integer Dirk Zimoch
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Doxygen documentation outside source files Andrew Johnson
