2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: converting strings to integer
Date: Wed, 13 Dec 2017 14:00:58 +0100
Hello everyone,
I noticed that I can use hex numbers in DOL with EPICS 7 but not with 3.16.1, 3.15.5 or earlier.
What about adding this option to 3.15/3.16?
It should be sufficient to switch in dbFastLinkConv.c from base 10 to base 0. This would generally allow hex (or octal) to string conversion through links.
Does this make sense?
Is there a risk?
Dirk
Re: converting strings to integer Andrew Johnson
Prev: Doxygen documentation outside source files Ralph Lange
Next: Re: Doxygen documentation outside source files Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Doxygen documentation outside source files Andrew Johnson
Next: Re: converting strings to integer Andrew Johnson
