2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Doxygen documentation outside source files
To: <[email protected]>
Date: Wed, 13 Dec 2017 10:12:48 -0600
Hi Ralph,
On 12/13/2017 01:57 AM, Ralph Lange wrote:
> Follow-up to yesterday's meeting:
> If you look at the end of this paragraph
> https://www.stack.nl/~dimitri/doxygen/manual/docblocks.html#structuralcommands
> the file extensions for other files that may contain Doxygen blocks to
> be included in the generated documentation, while being excluded from
> the file list may be .dox, .txt or .doc
> So - that would make .dox appropriate for files that contains only
> Doxygen blocks, while restructured text (that we were talking about
> IIRC) should probably have .txt.
I do like .dox for text intended for doxygen. However we publish Release
Notes as separate stand-alone files so they don't belong in a .dox file.
I want us to to do some unification of our in-tree documentation across
the different modules for the next release so this will be useful for
that (I'm not advocating making any changes before the final 7.0.1 though).
I also want us to generate Doxyfiles by expanding macros in them (mostly
for file paths and version numbers) — I did some work on that earlier in
the year, but it may need a bit of re-thinking to handle submodules
properly.
- Andrew
Doxygen documentation outside source files Ralph Lange
Prev: converting strings to integer Dirk Zimoch
Next: Re: converting strings to integer Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Doxygen documentation outside source files Ralph Lange
Next: converting strings to integer Dirk Zimoch
