2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem building example application on windows-x64
To: 'Michael Davidsaver' <[email protected]>, 'Andrew Johnson' <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Thu, 28 Dec 2017 16:42:03 +0000
Done.
> -----Original Message-----
> From: Michael Davidsaver [mailto:[email protected]]
> Sent: Thursday, December 28, 2017 10:04 AM
> To: Mark Rivers; 'Andrew Johnson'
> Cc: '[email protected]'
> Subject: Re: Problem building example application on windows-x64
> I don't really understand what I'm seeing here.  Andrew or Mark,
> can one of you open a ticket for this build failure?
> https://bugs.launchpad.net/epics-base/+filebug
> On 12/27/2017 04:46 PM, Mark Rivers wrote:
> > Building EPICS base 7.0.1.1 with VS 2015, windows-x64-static failed as follows:
> > forceBadAllocException.cpp
> > process_begin: CreateProcess(NULL, rc -l 0x409 -I. -I../O.Common -I. -
> I../../src/osi/compiler/msvc -I../../src/osi/compiler/default -I. -I../../src/osi/os/WIN32 -
> I../../src/osi/os/
> > default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -
> I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/e
> > nv -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -
> I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/os
> > i -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -
> I../../src/yajl -IH:/epics-devel/base-7.0.1/include/compiler/msvc -IH:/e
> > pics-devel/base-7.0.1/include/os/WIN32 -IH:/epics-devel/base-7.0.1/include -IH:/epics-
> devel/base-7.0.1/include/compiler/msvc -IH:/epics-devel/base-7.0.1/include/os/WIN32 -
> IH:/epics
> > -devel/base-7.0.1/include -fo Com.res ../Com.rc, ...) failed.
> > make (e=2): The system cannot find the file specified.
> > H:/epics-devel/base-7.0.1/configure/RULES_BUILD:242: recipe for target 'Com.res'
> failed
> > make[4]: *** [Com.res] Error 2
> > make[4]: *** Waiting for unfinished jobs....
> > iocLogServer.c
> > ../../src/log/iocLogServer.c(418): warning C4244: 'function': conversion from 'SOCKET' to
> 'int', possible loss of data
> > H:/epics-devel/base-7.0.1/configure/RULES_ARCHS:58: recipe for target
> 'install.windows-x64-static-vs2015' failed
> > make[3]: *** [install.windows-x64-static-vs2015] Error 2
> > H:/epics-devel/base-7.0.1/configure/RULES_DIRS:84: recipe for target 'src.install' failed
> > make[2]: *** [src.install] Error 2
> > ../configure/RULES_DIRS:84: recipe for target 'libcom.install' failed
> > make[1]: *** [libcom.install] Error 2
> > configure/RULES_DIRS:84: recipe for target 'modules.install' failed
> > make: *** [modules.install] Error 2
> > Any idea what is wrong?
> > Thanks,
> > Mark
> > *From:*Mark Rivers
> > *Sent:* Wednesday, December 27, 2017 3:15 PM
> > *To:* 'Andrew Johnson'; [email protected]
> > *Subject:* RE: Problem building example application on windows-x64
> > OK, that patch let me get the example application to compile.
> > However, there are problems when running it.  The behavior I see is different on
> windows-x64 and windows-x64-static.
> > - On windows-x64 the IOC application runs OK but when I try to exit the application I
> get the error I reported in my first message today, i.e. epicsSocketDestroy errors.  ^C will
> not kill the IOC application, I need to use the Task Manager.  This is a serious problem, and
> as I said earlier it affects other IOCs such as simDetector.
> > J:\epics\devel\example\iocBoot\ioctest>..\..\bin\windows-x64\test.exe st.cmd
> > #!../../bin/windows-x64-static/test
> > < envPaths
> > epicsEnvSet("IOC","ioctest")
> > epicsEnvSet("TOP","J:/epics/devel/example")
> > epicsEnvSet("EPICS_BASE","H:/epics-devel/base-7.0.1")
> > cd "J:/epics/devel/example"
> > ## Register all support components
> > dbLoadDatabase "dbd/test.dbd"
> > test_registerRecordDeviceDriver pdbbase
> > ## Load record instances
> > dbLoadTemplate "db/user.substitutions"
> > dbLoadRecords "db/testVersion.db", "user=rivers"
> > dbLoadRecords "db/dbSubExample.db", "user=rivers"
> > #var mySubDebug 1
> > #traceIocInit
> > cd "J:/epics/devel/example/iocBoot/ioctest"
> > iocInit
> > Starting iocInit
> > ## EPICS R7.0.1.1
> > ## EPICS Base built Dec 16 2017
> > iocRun: All initialization complete
> > 2017-12-27T14:52:54.595 No broadcast addresses found or specified - empty address list!
> > ## Start any sequence programs
> > #seq sncExample, "user=rivers"
> > epics>
> > epics>
> > epics>
> > epics>
> > epics> exit
> > epicsSocketDestroy: failed to close a socket because "WINSOCK Error 10093"
> > 2017-12-27T14:53:16.250 Receive thread for UDP socket 0.0.0.0:0 has not exited.
> > 2017-12-27T14:53:21.296 Receive thread for UDP socket 164.54.160.31:5076 has not
> exited.
> > 2017-12-27T14:53:26.333 Receive thread for UDP socket 0.0.0.0:5076 has not exited.
> > On windows-x64-static the IOC crashes immediately, without even starting to execute the
> st.cmd file:
> > J:\epics\devel\example>make -sj clean uninstall
> > devXxxSoft.c
> > xxxRecord.c
> > testHello.c
> > dbSubExample.c
> > devtestVersion.c
> > initTrace.c
> > testMain.cpp
> > test_registerRecordDeviceDriver.cpp
> > ../devtestVersion.c(27) : warning C4267: '=' : conversion from 'size_t' to 'epicsUInt32',
> > ../xxxRecord.c(211) : warning C4244: '=' : conversion from 'epicsFloat64' to 'float',
> > Appending initTrace.obj
> > Appending testHello.obj
> > Appending devtestVersion.obj
> > Appending dbSubExample.obj
> > Appending devXxxSoft.obj
> > Appending xxxRecord.obj
> > J:\epics\devel\example>cd iocBoot\ioctest
> > J:\epics\devel\example\iocBoot\ioctest>..\..\bin\windows-x64-static\test.exe st.cmd
> > At that point Windows pops up a dialog box telling me that test.exe has
> crashed.  Opening the Visual Studio debugger tells me that it is an access violation on
> address 0.
> > Is there a test in EPICS base that instantiates the example IOC?
> > Mark
> >> From: [email protected] <mailto:[email protected]>
> [mailto:[email protected]] On Behalf
> >> Of Andrew Johnson
> >> Sent: Wednesday, December 27, 2017 1:04 PM
> >> To: [email protected] <mailto:[email protected]>
> >> Hi Mark,
> >> On 12/27/2017 12:05 PM, Mark Rivers wrote:
> >> > I just did this again, but running makeBaseApp.pl with Windows rather
> >> > than Linux.  I get the same problem. It looks like the problem is that
> >> > testVersion.h is changing because the timestamp is incrementing by 1
> >> > second between the time it is created and checked?
> >> I agree; it seems to be a problem with the genVersionHeader.pl script
> >> that Michael added in 3.16.1 and the dependency rules. This is the
> >> relevant part of your build log:
> >> > perl -CSD H:/epics-devel/base-7.0.1/bin/windows-x64/genVersionHeader.pl
> >> > -t ../../.. -N testVERSION -V "" ../O.Common/testVersion.h
> >> > Updating VCS header ../O.Common/testVersion.h
> >> >     testVERSION = "2017-12-27T11:39:33"
> >> > perl -CSD H:/epics-devel/base-7.0.1/bin/windows-x64/mkmf.pl  -m
> >> > devtestVersion.d -I. -I../O.Common -I. -I. -I..
> >> > -I../../../include/compiler/msvc -I../../../include/os/WIN32
> >> > -I../../../include -IH:/epics-devel/base-7.0.1/include/compiler/msvc
> >> > -IH:/epics-devel/base-7.0.1/include        devtestVersion.obj
> >> > ../devtestVersion.c
> >> >     testVERSION = "2017-12-27T11:39:34"
> >> > ../devtestVersion.c
> >> >     testVERSION = "2017-12-27T11:39:35"
> >> whereas on Linux I get:
> >> > perl -CSD /home/phoebus/ANJ/epics/base/7.0/bin/linux-x86_64/genVersionHeader.pl
> >> >     testVERSION = "2017-12-27T12:08:23-0600"
> >> > /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -
> >> DUSE_TYPED_RSET
> >> > -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64
> >> > -Wpointer-arith -fvisibility=hidden -fPIC -I. -I../O.Common -I. -I. -I..
> >> > -I../../../include/compiler/gcc -I../../../include/os/Linux
> >> -I../../../include
> >> > -I/home/phoebus/ANJ/epics/base/7.0/include/compiler/gcc
> >> > -I/home/phoebus/ANJ/epics/base/7.0/include/os/Linux
> >> > -I/home/phoebus/ANJ/epics/base/7.0/include        -MM -MF devtestVersion.d
> >> > ../devtestVersion.c
> >> > Keeping VCS header ../O.Common/testVersion.h
> >> There seems to be a mismatch between the assumptions that script makes
> >> about file-system modification times and how GNUmake works on Windows.
> >> The old DOS FAT file-system had a time-stamp granularity of 2 seconds
> >> and that has resulted in some workarounds being added to GNUmake on
> >> Windows, e.g. see http://www.delorie.com/djgpp/v2faq/faq22_18.html or
> >> there may be a delay added at the end of the phase-1 run before GNUmake
> >> re-reads the Makefiles - that might explain what's happening here.
> >> Michael: How about we drop the seconds field completely from the build
> >> date/time-stamp? That should prevent this kind of problem from
> >> recurring. It would still trigger a re-creation of the header whenever
> >> there is a roll-over, but that should only happen once, not continuously
> >> like Mark is seeing.
> >> Mark: If you want to try out that fix, edit
> >> base-7.0/src/tools/genVersionHeader.pl and make this change:
> >> > diff --git a/src/tools/genVersionHeader.pl b/src/tools/genVersionHeader.pl
> >> > index 5851ea8..8e50fec 100644
> >> > --- a/src/tools/genVersionHeader.pl
> >> > +++ b/src/tools/genVersionHeader.pl
> >> > @@ -19,7 +19,7 @@ use POSIX qw(strftime);
> >> >  use strict;
> >> >  # RFC 8601 date+time w/ zone (eg "2014-08-29T09:42:47-0700")
> >> > -my $tfmt = '%Y-%m-%dT%H:%M:%S';
> >> > +my $tfmt = '%Y-%m-%dT%H:%M';
> >> >  $tfmt .= '%z' unless $^O eq 'MSWin32'; # %z returns zone name on Windows
> >> >  my $now = strftime($tfmt, localtime);
> >> - Andrew
> >> Arguing for surveillance because you have nothing to hide is no
> >> different than making the claim, "I don't care about freedom of
> >> speech because I have nothing to say." -- Edward Snowdon
Problem building example application on windows-x64 Mark Rivers
RE: Problem building example application on windows-x64 Mark Rivers
Re: Problem building example application on windows-x64 Andrew Johnson
Re: Problem building example application on windows-x64 Michael Davidsaver
Prev: genVersionHeader.pl timestamp granularity (was Re: Problem building example application on windows-x64) Michael Davidsaver
Next: Re: Problem building example application on windows-x64 Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem building example application on windows-x64 Michael Davidsaver
ANJ, 28 Dec 2017 · Home · News · About · Talk · Base · Modules · Extensions ·
