2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem building base with parallel make on Visual Studio 2010
To: 'Andrew Johnson' <[email protected]>, "'[email protected]'" <[email protected]>
Date: Wed, 3 Jan 2018 17:13:32 +0000
It is some sort of file permission problem.
On the windows-x64 arch it builds fine:
H:\epics-devel\base-7.0.1\modules\pvData\testApp>make -sj8
testThread.cpp
testEvent.cpp
Finished generating code
H:\epics-devel\base-7.0.1\modules\pvData\testApp>set EPICS_HOST_ARCH=windows-x64-static
H:\epics-devel\base-7.0.1\modules\pvData\testApp>make -sj clean
Cannot create O.windows-x64-static/Makefile at H:/epics-devel/base-7.0.1/bin/windows-x64-static/makeMakefile.pl line 41.
H:/epics-devel/base-7.0.1/configure/RULES_ARCHS:67: recipe for target 'O.windows-x64-static' failed
make: *** [O.windows-x64-static] Error 2
make: *** Waiting for unfinished jobs....
There does not appear to be an O.windows-x764-static directory there, either as viewed by Linux or Windows:
H:\epics-devel\base-7.0.1\modules\pvData\testApp>dir
Volume in drive H is local_rw
Volume Serial Number is 6DDD-530A
Directory of H:\epics-devel\base-7.0.1\modules\pvData\testApp
01/03/2018  11:07 AM    <DIR>          .
12/04/2017  11:41 AM    <DIR>          ..
12/04/2017  11:41 AM               797 Makefile
12/04/2017  11:41 AM    <DIR>          copy
12/04/2017  11:41 AM    <DIR>          misc
12/04/2017  11:41 AM    <DIR>          property
12/04/2017  11:41 AM    <DIR>          pv
12/04/2017  11:41 AM             2,034 pvDataAllTests.c
12/04/2017  11:41 AM               183 qemuRunTest.sh
12/04/2017  11:41 AM             2,706 rtemsConfig.c
12/04/2017  11:41 AM               988 rtemsTestHarness.c
12/30/2017  09:04 AM    <DIR>          O.vxWorks-ppc32
12/30/2017  09:04 AM    <DIR>          O.linux-x86
12/30/2017  09:02 AM    <DIR>          O.linux-x86_64
12/21/2017  08:12 AM    <DIR>          O.win32-x86-static
12/28/2017  10:49 AM    <DIR>          O.windows-x64-static-vs2017
01/03/2018  11:02 AM    <DIR>          O.windows-x64
01/03/2018  11:07 AM    <DIR>          O.Common
               5 File(s)          6,708 bytes
              13 Dir(s)  721,399,201,792 bytes free
corvette:modules/pvData/testApp>ls -l
total 92
-rw-rw-r-- 1 epics domain users  797 Dec  4 11:41 Makefile
drwxrwxrwx 2 epics domain users    6 Jan  3 11:07 O.Common
drwxrwxr-x 2 epics domain users 8192 Dec 30 09:04 O.linux-x86
drwxrwxr-x 2 epics domain users 8192 Dec 30 09:02 O.linux-x86_64
drwxrwxr-x 2 epics domain users 4096 Dec 30 09:04 O.vxWorks-ppc32
drwxrwxrwx 2 epics domain users 8192 Dec 21 08:12 O.win32-x86-static
drwxrwxrwx 2 epics domain users 8192 Jan  3 11:02 O.windows-x64
drwxrwxrwx 2 epics domain users 8192 Dec 28 10:49 O.windows-x64-static-vs2017
drwxrwxr-x 2 epics domain users   70 Dec  4 11:41 copy
drwxrwxr-x 2 epics domain users 4096 Dec  4 11:41 misc
drwxrwxr-x 2 epics domain users   44 Dec  4 11:41 property
drwxrwxr-x 2 epics domain users 4096 Dec  4 11:41 pv
-rw-rw-r-- 1 epics domain users 2034 Dec  4 11:41 pvDataAllTests.c
-rwxrwxr-x 1 epics domain users  183 Dec  4 11:41 qemuRunTest.sh
-rw-rw-r-- 1 epics domain users 2706 Dec  4 11:41 rtemsConfig.c
-rw-rw-r-- 1 epics domain users  988 Dec  4 11:41 rtemsTestHarness.c
Trying to delete a really non-existent directory leads to this error:
H:\epics-devel\base-7.0.1\modules\pvData\testApp>rmdir junk
The system cannot find the file specified.
Trying to delete O.windows-x64-static leads to this error:
H:\epics-devel\base-7.0.1\modules\pvData\testApp>rmdir O.windows-x64-static
Access is denied.
Time to reboot I guess. J
Sent: Wednesday, January 03, 2018 8:56 AM
To: 'Andrew Johnson'; '[email protected]'
I then ran make –sj8 again and most things built, but there was still an error in modules\pvData\testApp.
I then went to than directory and did make clean and make, but there are errors in both make and and make clean.
H:\epics-devel\base-7.0.1>cd modules\pvData\testApp
make -C O.windows-x64-static -f ../Makefile TOP=../.. \
    T_A=windows-x64-static install
make[1]: *** O.windows-x64-static: Permission denied.  Stop.
H:/epics-devel/base-7.0.1/configure/RULES_ARCHS:58: recipe for target 'install.windows-x64-static' failed
make: *** [install.windows-x64-static] Error 2
H:\epics-devel\base-7.0.1\modules\pvData\testApp>make clean
perl -CSD -MExtUtils::Command -e rm_rf O.windows-x64-static O.Common
cannot chdir to child for O.windows-x64-static: No such file or directory at C:/Perl64/lib/ExtUtils/Command.pm line 134
perl -CSD -MExtUtils::Command -e mkpath O.Common
01/03/2018  08:50 AM    <DIR>          .
12/30/2017  08:09 AM    <DIR>          O.windows-x64
01/03/2018  08:30 AM    <DIR>          O.windows-x64-static
01/03/2018  08:50 AM    <DIR>          O.Common
              14 Dir(s)  721,399,009,280 bytes free
H:\epics-devel\base-7.0.1\modules\pvData\testApp>dir O.windows-x64-static
               0 File(s)              0 bytes
               1 Dir(s)  721,399,009,280 bytes free
It seems to be complaining that there is no O.windows-x64-static directory, but there is?
What could be wrong?
Sent: Wednesday, January 03, 2018 8:45 AM
Subject: Problem building base with parallel make on Visual Studio 2010
I sometimes get the following error when building base 7.0.1.1 on Visual Studio (2010, 2017)
I do the following:
make –sj clean
make –sj8
Appending PVScalar.obj
Appending PVField.obj
Appending FieldCreateFactory.obj
Appending TypeFunc.obj
Appending valueBuilder.obj
Appending pvdVersion.obj
Appending reftrack.obj
Appending debugPtr.obj
Appending pvUnitTest.obj
Appending parseToPOD.obj
Appending typeCast.obj
Appending localStaticLock.obj
Appending status.obj
Appending timer.obj
Appending timeFunction.obj
Appending executor.obj
Appending event.obj
Appending serializeHelper.obj
Appending epicsException.obj
Appending bitSet.obj
Appending byteBuffer.obj
make[4]: *** O.windows-x64-static: Permission denied.  Stop.
make[3]: *** [install.windows-x64-static] Error 2
H:/epics-devel/base-7.0.1/configure/RULES_DIRS:84: recipe for target 'testApp.install' failed
make[2]: *** [testApp.install] Error 2
make[2]: *** Waiting for unfinished jobs....
unittest.cpp
H:\epics-devel\base-7.0.1\include\pv/pvData.h(534) : warning C4800: 'char' : forcing value to bool 'true' or 'false' (performance warning)
H:\epics-devel\base-7.0.1\include\pv/pvData.h(583) : warning C4250: 'epics::pvData::PVString' : inherits 'epics::pvData::PVScalarValue<T>::epics::pvData::PVScalarValue<T>::deserial
ize' via dominance
        with
            T=std::string
        H:\epics-devel\base-7.0.1\include\pv/pvData.h(488) : see declaration of 'epics::pvData::PVScalarValue<T>::deserialize'
        with
            T=std::string
../configure/RULES_DIRS:84: recipe for target 'pvData.install' failed
make[1]: *** [pvData.install] Error 2
make[1]: *** Waiting for unfinished jobs....
H:/epics-devel/base-7.0.1/bin/windows-x64-static/e_flex.exe: fatal internal error, error occurred when deleting temporary action file
H:/epics-devel/base-7.0.1/bin/windows-x64-static/e_flex.exe: fatal internal error, error occurred when closing skeleton file
H:/epics-devel/base-7.0.1/bin/windows-x64-static/e_flex.exe: fatal internal error, error occurred when closing skeleton file♪◙H:/epics-devel/base-7.0.1/bin/windows-x64-static/e_fle
It looks like perhaps 2 make threads are trying to access the same temporary file?
RE: Problem building base with parallel make on Visual Studio 2010 Mark Rivers
Prev: RE: Problem building base with parallel make on Visual Studio 2010 Mark Rivers
Next: RE: Problem building base with parallel make on Visual Studio 2010 Mark Rivers
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 03 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
