2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RPRO inconsistency
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS core-talk <[email protected]>
Date: Mon, 22 Jan 2018 21:34:07 -0800
On 01/22/2018 06:12 PM, Johnson, Andrew N. wrote:
> Hi Michael,
> I think you are right about the subtlety of this issue, I seem to remember wanting to make that change many years ago but was persuaded (or I discovered) it would be a bad idea. I think it relates to preventing infinite loops using DB links — if you make that change I suspect a record that FLNKs to itself will eat up 100% of a UP CPU.
yup...  this isn't as simple as I had hoped.  Still, I'd like to explore if this can be fixed.
So down the rabbit hole I go...
https://code.launchpad.net/~epics-core/epics-base/+git/prop-putf/+merge/336468
An attempt to fix this for the specific use case I care about.  When
a scan chain containing async records is originally triggered by
remote user action via. dbPutField().
RPRO inconsistency Michael Davidsaver
Re: RPRO inconsistency Johnson, Andrew N.
Prev: Re: RPRO inconsistency Johnson, Andrew N.
Next: Problems with parallel make in base 7.0.1.1 on Visual Studio 2015 and Visual Studio 2017 when HOST_OP=NO Mark Rivers
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: areaDetector developers meeting @ APS Mark Rivers
ANJ, 23 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
