2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem with eflex crashing when building base 7.0.1.1 on Visual Studio 2015
To: 'Andrew Johnson' <[email protected]>, EPICS core-talk <[email protected]>
Date: Tue, 23 Jan 2018 14:46:39 +0000
Hi Andrew,
I sometimes have a problem with eflex crashing when building with parallel make on Visual Studio 2015.  This is without HOST_OPT=NO to avoid the problem I reported a few minutes ago.
ntutilsTest.cpp
H:/epics-devel/base-7.0.1/include\pv/pvData.h(534): warning C4800: 'char': forcing value to bool 'true' or 'false' (performance warning)
H:/epics-devel/base-7.0.1/include\pv/pvData.h(583): warning C4250: 'epics::pvData::PVString': inherits 'epics::pvData::PVScalarValue<std::string>::epics::pvData::PVScalarValue<std:
:string>::deserialize' via dominance
:string>::deserialize' via dominanceH:/epics-devel/base-7.0.1/include\pv/pvData.h(488): note: see declaration of 'epics::pvData::PVScalarValue<std::string>::deserialize'
H:/epics-devel/base-7.0.1/bin/windows-x64-static-vs2015/e_flex.exe: fatal internal error, error occurred when closing skeleton file
Windows pops up dialog boxes with error as shown in the attachment.
When I opened the Visual Studio debugger it reported that the error in eflex was a stack overflow.
Note that running make again to pick up where it left off does not fix the problem
\epics-devel\base-7.0.1>make -sj8
LoadTemplate.c
line_notify.c
rvIocRegister.c
/../../src/ioc/dbtemplate/dbLoadTemplate_lex.l(310): warning C4244: '=': conversion from '__int64' to 'int', possible loss of data
/../../src/ioc/dbStatic/dbLex.l(48): error C2065: 'tokenINCLUDE': undeclared identifier
/../../src/ioc/dbStatic/dbLex.l(49): error C2065: 'tokenPATH': undeclared identifier
/../../src/ioc/dbStatic/dbLex.l(50): error C2065: 'tokenADDPATH': undeclared identifier
/../../src/ioc/dbStatic/dbLex.l(51): error C2065: 'tokenMENU': undeclared identifier
/../../src/ioc/dbStatic/dbLex.l(52): error C2065: 'tokenCHOICE': undeclared identifier
/../../src/ioc/dbStatic/dbLex.l(53): error C2065: 'tokenRECORDTYPE': undeclared identifier
/../../src/ioc/dbStatic/dbLex.l(54): error C2065: 'tokenFIELD': undeclared identifier
/../../src/ioc/dbStatic/dbLex.l(55): error C2065: 'tokenDEVICE': undeclared identifier
/../../src/ioc/dbStatic/dbLex.l(56): error C2065: 'tokenDRIVER': undeclared identifier
/../../src/ioc/dbStatic/dbLex.l(57): error C2065: 'tokenLINK': undeclared identifier
/../../src/ioc/dbStatic/dbLex.l(58): error C2065: 'tokenBREAKTABLE': undeclared identifier
I had to go into modules/database/src/ioc, run make clean there, and then go back to the top and run make –sj8 again (without running make clean first).  The second time eflex did not crash.
Attachment: eflex.png
Description: eflex.png
Prev: Problems with parallel make in base 7.0.1.1 on Visual Studio 2015 and Visual Studio 2017 when HOST_OP=NO Mark Rivers
Next: RE: Problems with parallel make in base 7.0.1.1 on Visual Studio 2015 and Visual Studio 2017 when HOST_OP=NO Mark Rivers
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problems with parallel make in base 7.0.1.1 on Visual Studio 2015 and Visual Studio 2017 when HOST_OP=NO Andrew Johnson
Next: Re: Problem with the iptables DNAT filter Michael Davidsaver
ANJ, 01 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
