2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problems with parallel make in base 7.0.1.1 on Visual Studio 2015 and Visual Studio 2017 when HOST_OP=NO
To: 'Andrew Johnson' <[email protected]>
Cc: 'EPICS core-talk' <[email protected]>
Date: Tue, 23 Jan 2018 17:03:41 +0000
Hi Andrew,
I can fix this issue on Visual Studio 2015 (and presumably 2017) by changing CONFIG_SITE.Common.windows-x64-static to add the /FS flag when compiling for debug.
# Temporarily enable debugging
HOST_OPT = NO
OPT_CFLAGS_NO += /FS
OPT_CXXFLAGS_NO += /FS
However, that generates an error if using Visual Studio 2010.
H:\epics-devel\base-7.0.1>make -sj8
cl : Command line error D8021 : invalid numeric argument '/FS'
So we need a way to add the /FS flag to OPT_C[XX]FLAGS_NO only for Visual Studio 2013 and later (that is where MSDN indicates the /FS flag was added).
Sent: Tuesday, January 23, 2018 8:32 AM
Cc: EPICS core-talk <[email protected]>
Subject: Problems with parallel make in base 7.0.1.1 on Visual Studio 2015 and Visual Studio 2017 when HOST_OP=NO
Hi Andrew,
I am trying to build base 7.0.1.1 with the following configuration:
-          windows-x64-static architecture
-          CONFIG_SITE.Common.windows-x64-static contains HOST_OPT=NO to enable debugging.  Note that there is a windows-x64-debug architecture in base, but there is no windows-x64-static-debug, so I just changed the CONFIG_SITE file.
-          Parallel make (make –sj8)
The above settings work OK for Visual Studio 2010, but they fail with Visual Studio 2015 and Visual Studio 2017.  If I remove the HOST_OPT=NO then this problem does not occur.
Here is the output for Visual Studio 2015.
H:\epics-devel\base-7.0.1>make -sj clean
dfa.c
ccl.c
epicsTempFile.cpp
gen.c
misc.c
ecs.c
nfa.c
../../src/flex/ecs.c: fatal error C1041: cannot open program database 'H:\epics-devel\base-7.0.1\modules\libcom\src\O.windows-x64-static-vs2015\vc140.pdb'; if multiple CL.EXE write  to the same .PDB file, please use /FS
../../src/osi/os/WIN32/epicsTempFile.cpp: fatal error C1041: cannot open program database 'H:\epics-devel\base-7.0.1\modules\libcom\src\O.windows-x64-static-vs2015\vc140.pdb'; if multiple CL.EXE write to the same .PDB file, please use /FS
../../src/flex/misc.c: fatal error C1041: cannot open program database 'H:\epics-devel\base-7.0.1\modules\libcom\src\O.windows-x64-static-vs2015\vc140.pdb'; if multiple CL.EXE write to the same .PDB file, please use /FS
../../src/flex/dfa.c: fatal error C1041: cannot open program database 'H:\epics-devel\base-7.0.1\modules\libcom\src\O.windows-x64-static-vs2015\vc140.pdb'; if multiple CL.EXE write to the same .PDB file, please use /FS
../../src/flex/gen.c: fatal error C1041: cannot open program database 'H:\epics-devel\base-7.0.1\modules\libcom\src\O.windows-x64-static-vs2015\vc140.pdb'; if multiple CL.EXE write to the same .PDB file, please use /FS
../../src/flex/nfa.c: fatal error C1041: cannot open program database 'H:\epics-devel\base-7.0.1\modules\libcom\src\O.windows-x64-static-vs2015\vc140.pdb'; if multiple CL.EXE write to the same .PDB file, please use /FS
make[4]: INTERNAL: Exiting with 3 jobserver tokens (should be 0)!
sym.c
../../src/flex/sym.c: fatal error C1041: cannot open program database 'H:\epics-devel\base-7.0.1\modules\libcom\src\O.windows-x64-static-vs2015\vc140.pdb'; if multiple CL.EXE write to the same .PDB file, please use /FS
make reaped child pid 37264320, still waiting for pid 37265184
H:/epics-devel/base-7.0.1/configure/RULES_ARCHS:58: recipe for target 'install.windows-x64-static-vs2015' failed
RE: Problems with parallel make in base 7.0.1.1 on Visual Studio 2015 and Visual Studio 2017 when HOST_OP=NO freddie.akeroyd
Problems with parallel make in base 7.0.1.1 on Visual Studio 2015 and Visual Studio 2017 when HOST_OP=NO Mark Rivers
Prev: Problem with eflex crashing when building base 7.0.1.1 on Visual Studio 2015 Mark Rivers
Next: RE: Problems with parallel make in base 7.0.1.1 on Visual Studio 2015 and Visual Studio 2017 when HOST_OP=NO freddie.akeroyd
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Problems with parallel make in base 7.0.1.1 on Visual Studio 2015 and Visual Studio 2017 when HOST_OP=NO Mark Rivers
ANJ, 26 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
