2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Scanning on event number fails with EPICS 3.16
To: EPICS core-talk <[email protected]>
Date: Tue, 13 Feb 2018 15:44:53 +0100
Tests completed.
Merge request: https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/337644
Dirk
On 12.02.2018 09:05, Dirk Zimoch wrote:
I have pushed a new version to https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+ref/named-events-backward-compatibility.
Now the logic is like this:
NULL is no event.
Leading and trailing spaces (isspace()) are trimmed.
An empty string is no event.
A numeric but not finite (inf, nan) value is no event.
A numeric value that converts (rounds towards zero) to an integer in the range 1 ... 255 is a numeric event.
A numeric value that converts to 0 is no event.
A numeric event is then converted to a decimal integer string.
All other events are named events.
I have modified scanpel so that it prints every existing event, even if no record uses it. The function now accepts glob patterns for filtering.
epics> postEvent "bla"
epics> postEvent "Injection"
epics> postEvent "2.00000"
epics> postEvent "Nan"
epics> postEvent "inf
epics> postEvent "-inf"
epics> postEvent "info"
epics> postEvent "0xff"
epics> scanpel
Event "255"
Event "info"
Event "2"
Event "Injection"
Event "bla"
epics> scanpel "2*"
Event "255"
Event "2"
If that look OK for you, I will make a merge request.
I am still working on the tests...
Dirk
On 08.02.2018 17:48, Andrew Johnson wrote:
Hi Dirk,
On 02/08/2018 07:23 AM, Dirk Zimoch wrote:
Attached is a patch file for dbScan.c which should fix the problem and
restore backward compatibility.
I have created (and quickly tested) it with EPICS 7 but I guess it
should work with 3.16 as well.
Please work against the 3.15 branch, since that was where we introduced
your named events work. We will merge it up into the later branches from
there.
The hack is to treat "x.000000" and "x" as the same event name if x is
an integer between 0 and 255. ("0" and "0.000000" are no event at all
now just like "").
I don't like the string comparisons since they would silently break if
the number of decimal digits generated by the double → string conversion
gets changed.
Better to parse the string properly into a double — look at the
epicsParseDouble() routine declared in epicsStdlib.h and documented at
https://epics.anl.gov/base/R3-15/5-docs/AppDevGuide/libComOSIlibraries.html#x21-84700020.13
— then either round or truncate the fractional part.
- Andrew
Re: Scanning on event number fails with EPICS 3.16 Andrew Johnson
Re: Scanning on event number fails with EPICS 3.16 Dirk Zimoch
Prev: Re: Scanning on event number fails with EPICS 3.16 Dirk Zimoch
Next: Re: EPICS 7 Documentation or just README.examples for the V4 part. Williams Jr., Ernest L.
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: bundling linenoise with base Benjamin Franksen
ANJ, 16 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
