2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: obscure EPICS+RTEMS makefile problem
To: Michael Davidsaver <[email protected]>
Cc: EPICS core-talk <[email protected]>
Date: Wed, 18 Apr 2018 04:31:41 +0000
Why wouldn’t you put the workaround in the file CONFIG.Common.RTEMS where you don’t need a conditional test?
I haven’t looked into why you’re only just noticing this now, but there are a few possibilities that I could come up with.
- Andrew
Sent from my iPad
> On Apr 17, 2018, at 8:44 PM, Michael Davidsaver <[email protected]> wrote:
> I realized that both Base and RTEMS define a Make macro $(MKDIR).
> Unfortunately the RTEMS definition lacks a '-p'.  So using this
> to create eg '../O.Common/' will fail if it already exists.
>> configure/os/CONFIG.UnixCommon.Common:MKDIR = mkdir -p
>> make/host.cfg:MKDIR=mkdir
> The later is included through configure/os/CONFIG.Common.RTEMS
> This is being done to generate headers with module version numbers
> in the PVA modules.  I'm wondering why I'm only finding this now?
> My workaround:
>> include $(TOP)/configure/CONFIG
>> ifeq ($(OS_CLASS),RTEMS)
>> MKDIR = mkdir -p
>> endif
Re: obscure EPICS+RTEMS makefile problem Michael Davidsaver
Prev: PVA links alpha Michael Davidsaver
Next: Re: obscure EPICS+RTEMS makefile problem Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: obscure EPICS+RTEMS makefile problem Michael Davidsaver
ANJ, 18 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
